ENEDED
Please put me on the second list for a Nichia. Thanks.
Hi.
My 219C arrived today.
Works as promised, no problems.
Very nice light.
Thanks freeme
i might do spring bypass.
Ceiling bounce test shows 30% more Lux compared to my MT03 hmmm looking good both using freshly charged 30Q.
Well, it’s 9k to 12k. 30% sounds about right. Were you just confirming this for our sake?
not sure what you are getting at, is there something wrong with sharing my own finding here?
MT03 is known not making true 9K lumens, i am just giving a reference here as to how bright the light is. I think the MF01 Nichia is not making 11K lumens from the figure i got. I does look brighter to the eyes though.
btw. Did the test again now i only get only 15% (650 vs 750 Lux) with slightly used batteries (4.09v) Currently charging the battery to see if my initial reading was an error or the full battery did gave higher result
You just seemed to say something random. I was confused.
The MF01 nichia version is only about 7,000. Way less than the xp-g3 version.
I thought the MT03 really did 9k lumen.
sorry if the posts seems random and confusing.
i think the MF01 nichia is making more than 7000 Lumens but i have no way of measuring the exact figure myself it looks brighter than my MT03 and the Lux support this.
If I’m not mistaken, there is only one person reporting about 7000 lumens for the Nichia version. So I hope rizky’s measurement is more representative.
I did the ceiling bounce again MT03(650Lux) and MF01(808Lux) both on freshly charged 30Q so 25% difference compared to MT03. If my MT03 is making 8000L the MF01 in theory should be making 10K Lumens. Now if my MT03 is making true 9K lumens then the MF01 Nichia is making 11250Lumens the later seems more comparable to the given specs. But the lumens is droping rapidly on MF01 and can be as low as 15% gain over the MT03 in the first minutes or two.
this is not true, the springs on the review light are from bronze alloy and are fully compressed with brass button soldered to unprotected cells
so the windings short each other, no need for a bypass
on the production light the spacing is larger in the carrier so it fits as well high drain cells with PCB like Klarus and some other brands have
if you use unprotected cells in the production light a spring bypass should gain a little longer runtime as well as turbo longer availiable
if its done right nothing to loose by a proper spring bypass
This is post claiming around 7425 lumens
This post have beamshot
From the beamshot and my MF-01 Nichia, I have feeling should be more than 7k, sorry can’t provide exact number for this.
I’ve only had a chance to try it out once, but to my eyes, my MF-01 Nichia has to be putting out at least 10k lumens at startup (maybe more). It’s plenty bright, although it is a little warmer than I expected for some reason. Overall, it’s a very nice light.
Yeah, that’s the post I remember. It’s the only actual number I remember hearing about. So you guys are thinking the Nichia version is doing closer to 10k or 11k?
No one knows if his light is working properly or how accurately his light meter reads neutral white lights.
I just received my nichia light and have only used it a little with protected cells. Compared to my 4000+ lumen mountain bike setup and my MT07 there’s no way its only making 7000 lumens. Judging by how slowly it’s heating up in turbo switching to good unprotected cells will bump up the output even more.
My light’s completely awesome, smaller and brighter than I was expecting.
Hello. Please code for mf01 xp-g3
Just for fun this is another Ceiling bounce test that i made.
Convoy L6 running Narsil drawing 10.5A at the Tail : 421 Lux
Astrolux MF01 : 808 Lux
Haikelite MT03: 650Lux
Not sure how many Lumens OTF on the L6 maybe 5000? if its true then my Haikelite MT03 is making 7700L and my MF01 is making 9600Lumens.
Hallo.Nice that you are here, which model nichia or cree do you like it?
Greetings to all the flashaholic around the world :wink:
I would like code for 219c.
Indicate your LED choice (XPG3 / 219C) in you reply if possible.
Edit your previous post instead of creating a new request.
Notification List
Updated on Sep 23, 2017
  1. andrewmac
  2. danggitbai
  3. Kingjohn
  4. cheesecheeks
  5. Sergeantrecrut
  6. cyropro
  7. heatwaves
  8. Lou_Menn
  9. Robsva96 - XPG3
  10. Dralf
  11. Nicolicous - XPG3
  12. Phantom1
  13. ramptosd - XPG3
  14. laythaws
  15. BeardedRaleigh - XPG3
  16. Sukoi
  17. Wieselflinkpro - XPG3
  18. gastonpatagonico -219C
  19. sammubara
  20. qandeel - 219C
  21. Ilmatic - 219C
  22. Ilmatic - XP-G3
  23. tantrik77 - 219C
  24. watamu - 219C
  25. rafalklis - 219C
  26. CJ Avlis - 219C
  27. jamaya - 219C
  28. Mr.Beam - 219C
  29. Mr.Beam - 219C
  30. maildroid - XPG3
  31. Wolpi - XPG3
  32. andrewmac XPG3
  33. southland - 219C
  34. xxx - XPG3
  35. mrheosuper - XPG3
  36. atbglenn - XPG3
  37. Nicolicous - XPG3
  38. FG1 - 219C
  39. ersecu - XPG3
  40. xdouang - XPG3
  41. thommy - XPG3
  42. Itsme - XPG3
  43. sammubara
  44. Lou_Menn
  45. FG1
  46. Sledgestone - 219C
  47. Bruno28 - XPG3
  48. baka - XPG3
  49. JIGHEADWORM - 219C
There will be some changes made to the MF-01 driver, to eliminate uneven brightness issues that a handful users have experienced with the units. We need to address to it before we could resume MF-01 sale.
