Today i received my Q8 (free shipping option) and this is how the package came out of the typical grey plastic Banggood bag
So i could not wait to try it, so put some new and fullly charged 30Q’s in it and i noticed the unbalanced switch indicator LED’s.
Then played a little while with it, and man, i love it! I love the ramping, love the size, love the tint, it’s a winner!
Luckily the indicator LEDs do not show any signs of intermittent flickering or such.
One thing that annoyed me is that i did not notice a small burr on the end that touches the head on the PCB, which resulted in a scratch on the PCB (poor picture)
Even my wife, (who thinks i already own too much lights) said it is a nice light, well thats a compliment for her
Nice!
Great news finally a real production Q8 in the hands of another team member! Awesome for we all know Djozz has no problem saying how it is.
Sorry, very good to go into the weekend with others being positive and nice too of course, but joy not all the weight of answering about production Q8 lights is on Toms shoulders!
Cheers all poured myself a drink 50% red fruit syrop and 50% decent Cognac to celebrate, cheers
Good weekend all!
I purchased three Q8’s and 2/3 had this black stuff on the ring. There wasn’t much but it was noticeable, almost made it look like there was impurities in the copper – Isopropyl alcohol barely did anything to remove it.
I ended up using Acetone and cotton swabs and I had to scrub quite vigorously to get it off, it was amazing seeing how dirty the acetone swab was when I had cleaned it with isopropyl seconds before and the isopropyl swab came off clean.
I managed to get almost 100% of it off, but I feel like after putting my lights back together and using them that a small amount came back, I’m starting to believe it’s part of the button tops rubbing on the copper and leaving metal there.
Maybe they were dirty from Thorfire testing the lights with 18650s before shipping? Maybe Thorfire is using 18650s with crappy quality button tops or solder blobs?
Now copper should be softer than whatever the button tops are made of, but maybe the button tops are nickel plated or something? Plus solder is definitely soft enough to be affected by copper.
EDIT: The ring is brass not copper, duh me. I honestly thought it might have been brass considering the color, but I figured it was copper due to its better conductivity. Brass is only 28% as conductive as copper, but copper oxidizes… man if only we could have silver plated copper lol.
With both of my today arrived lights I only got around 4000 Lumens with Samsung 30Q Solder-Top and Protected Imalent from the DT70. Is there something wrong with them?
Or is my lightbox badly adjusted? But I got similar readings on the BLF A6 compared to what was written here and similar readings here and on TLF with the Astrolux MF-01 Nichia.
The ring is brass not copper, but doesn't explain anything, don't think. Hhmm, I'll have to check the ones I got - maybe didn't notice/look for it. I'd probably use some 600 GRIT paper on them if the isop. alcohol didn't work. Maybe just not cleaned up from the manu process.
The dark smear could come from the contact ring, or it could be carried on whatever cutting tool they used (maybe it’s scorched lubricant?)
There are a lot of different brass alloys. If it’s a “free cutting brass” alloy, containing lead, the lead will smear out across the surface under contact — it’s a feature lubricating the cutters.
If that’s the source of the dark mark, a combination of vinegar and hydrogen peroxide will clean the surface: http://brewingrabble.com/resources/surface-lead.htm
Interesting data point: on my previously bad/flickering switch board i replaced the resistor and both LEDs (same reel, should be same properties) and one of them was still dimmer than the other. I’m thinking now that it is due to the traces in the board itself rather than the LEDs being mismatched.
Are there any oshpark board designs or there I can try as a replacement for this illuminated switch?
TheMiller posted somewhere in here, or the Q8 mod thread (moving so fast it’s hard to find), that Thorfire is redesigning the switch board. I would imagine, they would offer you one when it’s complete.
I would take you up on that bet The Miller, sadly my flashlight spending money is tied up at the moment. Have a good weekend, I am sure this whole situation has a lot for you to deal with. I’ll do my best not bother you with further apparently unanswerable questions . It is what it is and you deserve a break
traces cant be the issue, just 1 resistor for both means even the slightest difference in Vf makes on dimmer
Cree LEDs of the same reel usually have quite the same Vf,
but for those tiny SMD LEDs the emitting area is a lot smaller, so they may vary a lot more
Unsoldered LEDs and switch just holding my temp stabilized iron at 300°C at the other side
also skillet might work well
With solder blobed 30Qs you should definitely get 6k+ out of the box.
Either your reading is off or your batteries are not fully charged or both your lights are under performing - but that seems a lot.
Try tightening both ends of the flashlights and see if it gets better. Some clean up could help too, according to reports. Seems odd that the two lights are both so low…
4,000 at 30 secs sounds pretty low if using 4 30Q ST's. Here's # taken at 30 secs on fully charged 30Q BT's from Banggood (large top):
5,440 4,930 5,290 5,035 4,780 4,770
Maybe my PVC light box is a little high - think djozz sees about 200 lumens lower from past comparisons at these levels. I was expecting in the range of 5,500 lumens, as I saw with the prototypes. But the good news is with tweaking, the 4,780 light did 5,170 with cleanups and screws replaced, and did 6,150 with the fully modded tail PCB from the prototype.
