Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
With both of my today arrived lights I only got around 4000 Lumens with Samsung 30Q Solder-Top and Protected Imalent from the DT70. Is there something wrong with them?
Or is my lightbox badly adjusted? But I got similar readings on the BLF A6 compared to what was written here and similar readings here and on TLF with the Astrolux MF-01 Nichia.
The ring is brass not copper, but doesn't explain anything, don't think. Hhmm, I'll have to check the ones I got - maybe didn't notice/look for it. I'd probably use some 600 GRIT paper on them if the isop. alcohol didn't work. Maybe just not cleaned up from the manu process.
Isn’t that contact ring brass, not copper?
The dark smear could come from the contact ring, or it could be carried on whatever cutting tool they used (maybe it’s scorched lubricant?)
There are a lot of different brass alloys. If it’s a “free cutting brass” alloy, containing lead, the lead will smear out across the surface under contact — it’s a feature lubricating the cutters.
If that’s the source of the dark mark, a combination of vinegar and hydrogen peroxide will clean the surface:
http://brewingrabble.com/resources/surface-lead.htm
Interesting data point: on my previously bad/flickering switch board i replaced the resistor and both LEDs (same reel, should be same properties) and one of them was still dimmer than the other. I’m thinking now that it is due to the traces in the board itself rather than the LEDs being mismatched.
Are there any oshpark board designs or there I can try as a replacement for this illuminated switch?
TheMiller posted somewhere in here, or the Q8 mod thread (moving so fast it’s hard to find), that Thorfire is redesigning the switch board. I would imagine, they would offer you one when it’s complete.
I would take you up on that bet The Miller, sadly my flashlight spending money is tied up at the moment. Have a good weekend, I am sure this whole situation has a lot for you to deal with. I’ll do my best not bother you with further apparently unanswerable questions . It is what it is and you deserve a break
traces cant be the issue, just 1 resistor for both means even the slightest difference in Vf makes on dimmer
Cree LEDs of the same reel usually have quite the same Vf,
but for those tiny SMD LEDs the emitting area is a lot smaller, so they may vary a lot more
Unsoldered LEDs and switch just holding my temp stabilized iron at 300°C at the other side
also skillet might work well
then cut the trace to one LED and add a resistor
add solder paste
add resistor and wire
2 white LEDs with 19.1kOhms each
With solder blobed 30Qs you should definitely get 6k+ out of the box.
Either your reading is off or your batteries are not fully charged or both your lights are under performing - but that seems a lot.
Try tightening both ends of the flashlights and see if it gets better. Some clean up could help too, according to reports. Seems odd that the two lights are both so low…
Whilst not as cheap, these are Aussie options, with fast delivery and good customer service too.
4,000 at 30 secs sounds pretty low if using 4 30Q ST's. Here's # taken at 30 secs on fully charged 30Q BT's from Banggood (large top):
5,440 4,930 5,290 5,035 4,780 4,770
Maybe my PVC light box is a little high - think djozz sees about 200 lumens lower from past comparisons at these levels. I was expecting in the range of 5,500 lumens, as I saw with the prototypes. But the good news is with tweaking, the 4,780 light did 5,170 with cleanups and screws replaced, and did 6,150 with the fully modded tail PCB from the prototype.
More to come...
StephenK
Wow, thats double the price at least, ill keep them in mind but ill keep looking for now.
i ordered these on the 20th.
ssschen, can you link the ones you ordered and let me know what shipping option you took please.
Of topic @ Tom. You mentioned somewhere you had a soft spot for a triple with no pill you modified. Was it the HD2010 triple?
My second Q8 arrived today.
It does have the mismatched SW LED’s when sitting in standby state, unlike the first one.
It has an intermittent problem.
It will sometimes not shut off.
The first time I turned it on, I ran it up the ramping about half ways. Released the SW and immediately ramped it down to ML. Ran it back up and down a couple or so times. Then hit the SW to turn it off. It stayed on. I hot the SW again. Nothing. I untwisted the body from the head a quarter turn and it went off. Of Course it would.
Turned on. Turned off. that time all was okay. Since then I have done many of the tricks it is capable of; battery level check, OK. Four click lock out and back in, OK. Double click to jump to turbo, OK. I let it run on turbo to check the timeout; 3 minutes, so OK.
A couple of times during these trials it would not turn off. Clicking the SW caused the SW LED to flash, but the light remained on. Sometimes after several clicks it would go off. Sometimes I would give up after a half dozen clicks and turn it off by loosening the body to head.
Sometimes, when it will not turn off the LED’s will flash and be very slightly brighter, then with the next click go back down. This is with the light on ML.
I attempted to make a video. Naturally the light worked fine during that time. I’ll try again later. I have both lights with 30Q’s, one in left hand, one in the right hand, clicking in unison. The good light, #1, works flawlessly but #2 hiccups every so often.
Sure would like #2 to work reliably.
Hmm MtnDon that is a new thing.
Yet is seems tied to the switch assembly again.
Will update OP tomorrow.
Yep - dunno why, still like the rough, not so pretty, but great performance of a HD2010. So found some great deal on a triple version, so couldn't turn it down.
Found it: Beamtech BT-4000 form TMART for $22 - back in April 2015.
Hhmm, MtnDon's issue sure sounds like a mechanical switch problem. The description sounds like one click acts as 2 clicks, but hard to say.
To save me reading through hundreds of posts has anyone got a link to a pouch/holster for the Q8 that is either available in the UK or will ship to the UK without incurring high shipping charges please :wink:
I think there was a smoke grenade pouch available for people in the US only ?
One of mine has just now done that too. I'd double-clicked to turbo to see what the noise was in the back garden & then grabbed the 2nd one & did the same, after a few seconds of having fun beam waving I shut them both off, only the 1st one wouldn't turn off.
I could ramp up & down no problem just couldn't switch off, I unscrewed the head then re-tightened and it has been fine since, I can't repeat the issue. :shrug:
One more possible issue: earlier today after maybe 11 hours without use I noticed both switches were no longer illuminated while in standby, turning on then off brought them both back to life and again, it hasn't happened since.
I bought this one
I heard that THIS POUCH works with the Q8 from a poster in the Astrolux MF-01 thread.
Ha! Beat me to it MtnDon!
