off topic, but here we are... OTSM isn't just about boot. The power switch is acting exactly like an eswitch during much of the situation, because the mcu is still powered by the cap and running and there is no reboot.
Example the light is on steady. Someone clicks "off" to do a medium click, clicking back on in 0.6 s. What should happen is the software sees the off, goes into sleep cycles, sees the on, notes the 0.6 seconds, THEN does SOFT reboot (doesn't actually reboot the mcu at all, just restarts the code from a direct jmp call to main -- and stack pointer reset--, however this does disable interrupts briefly if I recall correctly) with a medium press condition.
Ok, but if the initial off is quick off on off, then the code would see that on as a mediumshort press, would do the soft reboot, interrupts would likely be disabled missing the final off, and the light would try to run full power for 0.6 seconds off the cap without battery support. It would drain, and restart triggering a long press condition.
There are several very possible variations. But they don't happen. I think the difference is the big cap. VERY high frequency bouncing won't bring the cap down enough to trigger anyway. The switch needs to stay low for about 1ms to drain the cap enough to trigger. By then maybe it's done bouncing. Definitely it's possible to resolve this in hardware. I'm not convinced that's enough RC to do it, but it might be, seeing as there's no problem.
In fact the similarity between OTSM and eswitch is exactly what led me to add experimental e-switch support to bistro-HD. It uses the exact same code, with just a little more logic for different sequences. It mght be that I got either lucky or more clever than I remember and I blocked against these cases in software in some ways I forgot(I did think about it some) or never realized. If so I did it very succinctly. Or it may be it's the hardware.
My friend gds95 received his and he has 2 different brightness indicator LEDs and he was upset I even pointed it out, but he knows to look out for the indicator acting funky so it can be reported if it becomes an issue.
Exactly. It doesn’t need debounce logic because the signal doesn’t bounce. It does all that at a hardware level before the MCU firmware sees anything.
Older driver designs bounced, but that was fixed long before anyone here tried OTSM… and it wasn’t related to the switch; it bounced because of ringing from PWM on the FET.
October first is Chinese National day followed by Golden Week Holiday. This means almost all of China is not working September 30th till October 8th due to travels and having a holiday.
Thorfire aims at sending out the Q8 before that, but to be on the safe side it is better to expect shipping at the latest inline with what the Banggood listing said from the beginning October 10th.
Of course we will announce it when shipping is about to commence.
I think lower current through the switch leds will solve the problem. Guess they blew up from overheating (no big news I guess)
Can’t they just swap the resistors and leave the leds the same?
Some people have gone to a higher current and got non working leds to work again. Swapping the 15k resistor with a 10k.
There is still something wonky about the pcb, though. Something is making the leds be different brightnesses even when the leds are swapped for a matched set.
Then there are the rare switch issues when turning off the light which might be related to the switch. We don’t know yet.
So I think TF is smart to just swap to a different switch assembly pcb. It might fix several things at once.
A question for The Miller, as he is in contact with Thorfire
So Thorfire are sending out the next batch with a different switch assembly fitted to alleviate the problems some have had with lights in the first 500 batch.
What is happening about the first 500 batch ?
Are TF sending out replacement switch assemblies to those members that purchased in the first 500 ?
I bought 3 lights from the first 500, all of which seem to work fine, but some are now reporting that with more use their previously non issue lights have now started to develop switch issues.
My lights have only seen about 30 minutes use max so far & have & are working fine but from what others are reporting it is quite possible that with more use they may also develop switch issues.
Just wondering if TF are going to do something for those of us that bought lights from the first 500 batch ?
Ingredients for my Q8 lanyard:
1.) Screw with ribbon from a smartphone tripod, too long on it’s own,
2.) Rubber washer found in my spare parts box, drilled for a larger diameter,
3.) Spider (not required).
The problem with that is a certain percentage of people want the switch light to work and expect it to work. They also can’t work on it themselves. So it has to be fixed it under warranty of some type.
Lukily the number of folks that have a problem is very tiny.
I am not going to get into an argument & what you say above is correct Rapidlux, however, everybody who bought the Q8 bought a light that was meant to have a working problem free indicator switch.
Price doesn”t come in to it.
Everybody paid the same $40 so why should people who bought in the first 500 batch have to put up with issues & non functionality that those who didn”t buy in the first 500 don”t have to ?
If every light sold had the same switch & therefore potentially the same problems fair enough but as TF are aware of a problem & have halted production/shipping so as to fit a different switch to the next batches of lights to cure this problem surely something should be done for the first 500.
And when a sold product has a known problem, manifested or potential, all of the product are repaired/ replaced/upgraded not just the ones that are exhibiting the problem.
I am not expecting TF to send me 3 new lights but TBH would expect them to send me 3 new switch assemblies to fit myself so that I have lights that are the same as everyone who didn”t buy in the first 500 batch.
I’ll second that. When my light comes I will be expecting the switch to start causing issues, it will always be on my mind even if it never happens, so a new switch assembly sent to me would be peace of mind, and the establishment of trust, maybe even the trigger for a second Q8 purchase, one to keep stock, one to experiment with and compare.
Issue(s) are being collected
when ALL 500 are in we can tell what the issues are and then how to find a solution for those affected.
I will not go deeper into it now, it is not constructive for theoretical and I do NOT want to debate with hundreds of people what they think is best and should be done, we are on top of things and this should suffice so please do not force me to put time into explaining why we want to know all the issues before getting to a solution, sure a lot will say it is not the proper way to go, fine cool, keep it to yourself or PM me if you feel like this AND have reported an issue!
Oh talking about time, I have prepared an answer so people who think it is cool to email Thorfire and/or Banggood receive a nice reply pointing them to me. You could just have respect for the clear text in the OP stating we are the ones to ask things to and the info is in the topic (important for all means topic title change with date now), Wasting time (person A forwarding mail to person B, person B forwarding to me, me reply to B, B forward to A) of all involved and people not involved seems like a sign of utter disrespect for others only to fill the need of a personal reaction with the same information that has been posted here.
Time is the only universal currency, but alas nobody gets change.
Issues with switch leds not working all seem to pop up within a day or two. Please report on it.
Issues with not turning off are too vague to be put in the OP now. Please report on it further, I will start clicking away on my proto to see if I can find some patern.
And come on, if you don’t have an issue do not ask what the solution is IF your light maybe gets an issue, let’s keep posting about issues to people HAVING them shall we?
Fairly easy, HAVE an issue, please report the greater the detail the better.
When WE HAVE news we post, when we have questions about issues we post
If you DON’T have an issue, cool, just leave posting about both issue and solution to others
Thanks
