I have a Fluke 189 and 289. To be honest, I use the 189 most of the time. It’s got an easier to read display contrast wise. It’s been professionally calibrated about a year ago. The 289 was sent back to fluke to have the leaky super capacitor replaced under warranty about 2 years ago. While it was there, they calibrated it and updated the firmware.
My 189 which I’ve owned since 1999 still has a good supercapacitor. Have you checked your 289? It is a known issue with that model. Luckily mine didn’t damage the circuit board because it was just starting to leak. Fluke was really good about taking care of the problem.
It needed to leak a lot more before it could do any damage, but now it is removed. It did not work anyway.
This means it looses the time each time I replaces batteries (I already did that) and that is not really a problem for me. If I need to do some offline logging with time stamps I will have to use another meter.
Hi Ven, how are you buddy? I purchased my Fluke 62 Mini years ago before all the cheap Chinese IR meters came out. I remember it wasn’t cheap. I can only imagine how expensive Fluke thermal imaging meters cost. BTW, I purchased my Fluke meters when I had a decent paying job. Today I’m retired, and very careful how I spend my money. If I already didn’t own them, I’d be looking for much less expensive electronic measuring tools.
Shunt is often used about a resistor when it is used for current measurement.
Burden voltage is the voltage drop in a DMM when it is used for measuring current. If you are measuring current from a 1.2V battery with a 200mV burden voltage (At the actual current) your load will only see 1V, i.e. the DMM will affect the result.
Yes, but if only used for flashlights you can get something cheaper that is just as good. With the Fluke you also pays for safety when using it at mains voltage.
I bought the Fluke 17B+ about over a year ago after AvE´s review.
Mainly, because I had done it all for like 10 years on a 10$ multimeter, so I thought it´s about time…
Has been working well and I like that it is AA-powered and not 9V (which I had to replace to my older MM quite often).
Fluke is very reliable and expensive, but not the only game in town. I have a some of Fluke meters, including 8846A (A very high end DMM) and like them, but recently I have looked more at Keysight, they are also expensive, but not as bad as Fluke and they do also know a lot about making very good test equipment (I do use a lot of other brands).
Just had a quick look at the keysight brand and do look good, Quick look at the U1241C and cost wise seem around Fluke prices here in the UK. Will save for future reference ! Thanks HKJ :+1: my wallet just loves you
Keysight is not cheap, but you get more for the money than you do with Fluke.
Try comparing functions in the DMM with a similar priced Fluke.
You do also get a usb cable with the meter, Fluke only has that for the most expensive DMM’s and it cost extra.
Good to know HKJ thanks again. The down side would be name snobbery , definitely not a deciding factor but Fluke just sits easier with me when spending higher amounts of money. Maybe a confidence thing, also having to try and explain why i bought a MM called Keysight to everyone who notices would grow old fast. Trying to get work colleagues to understand spending £100’s on a less known brand(to some) makes sense. I am not a Fluke snob for sure, i use the Di-Log in work, but to think of some negatives that can/do happen in the work place.
I have had to take some flashlights home, one of them I got sick of trying to explain a copper cryos bezels advantages and hi cri nichia’s ! It was like a man magnet, shiny copper and they come over asking endless questions with puzzled looks as to “why?” lol Some get it, others dont and go off thinking their 8lm 3xD cell is more useful behind a discoloured,dust filled cracked plastic lens………
I look forward to more MM reviews in the future, i think they make a perfect addition and complement your reviews nicely :+1:
