ENEDED
Yeah I have my eyes on X80 :slight_smile: but the price is steep
I am using Samsung 30Q ( fresh cell and fully charged ) and I have no way to measure the lumen , but it seems to my eyes that
my MF-01 is not as bright as the result shown above in level 2 3 ( 804lm> 1524 lm ).
I mean when I step up , it not as bright as double figure here. It is more like 804lm — > 1000lm. ( just a tad brighter ).
I also compare with my other light which has solid 1500 lm. It appears that MF-01 has less bright than 1500lm.
It is so,the price is steep.So,I look for the DX80,if the full review will be positive.It is cheaper with a coupon,plus it has way more intensity.
Going from 800 to 1500 lumens is not going to look twice as bright to your eyes, more like 30% brighter. Only way to know is with a measuring device.
Got my MF01 today. It works perfectly. Was happily surprised that it uses high CRI (>90) 219Cs. I thought it used the standard CRI80 219C 5000K.
The tint is absolutely beautiful, no shift to speak of and no other anomalies. The UI is quite the step up from the disaster that was the S42. All in all a superb light for the GB price!
Some PWM (or other flickering) evident on a cellphone camera on all modes except low but not visible to the eye. Didn’t have time to scope that out yet.
Output is not quite what is claimed, but I don’t care. For comparison, it produces 45% more lumens (35% more at 30 sec) than the Noctigon Meteor M43 equipped with CRI80 219Cs. My lumen measurement seem to be about 5-15% less than other people’s, but mine is calibrated with a reference halogen bulb and I use a spectrophotometer instead of a lux meter.
Output with Samsung 25R (lowest IR of any of my cells):
Throw:
0 sec: 44575 cd
30 sec: 40648 cd
Tint in different output modes (click for higher res):
Tint in different parts of the beam on turbo (click for higher res):
CRI data on turbo:
I’m always impressed by your emitter data.
Even though I can’t understand it. Lol
Count me in for the 2nd batch, 219c flavour thanks Freeme :+1:
interested in improved nichia
Interested
Thank you maukka. That got my attention. Interested in one 219C from the 2nd wave.
Thanks for your excellent measurements maukka!
If I’m not mistaken, this makes the MF-01 the brightest high CRI (stock) light on the market.
Maukka: You don’t happen to have a set of VTC6:s, so you could check the output with them?
I do, but the 25Rs perform better at 0-60 sec. Just tested them the other day with the Q8. I’m getting some new VTC6s and VTC5As in the mail and will get back to the output.
So far there does seem to be a huge spread in output though…
Interested in a Nichia version.
Thanks
Thanks!
(VTC6 generally performs better than 25R in my lights, but then again my 25R:s are older than my VTC6:s.)
Thank you maukka, the wonderful measurement data :+1:
Although it is yellowish in visual observation, it is still about 5000K.
Hyvää iltaa maukka,
and thank you for your report.
To all other, I am sure maukka´s calibrated reference is more correct than mine (none calibrated value with a conversion factor of 26.47.) but I will give you the numbers I have from today when my XP-G3 arrived.
I used eight ORBTRONIC ORB25 (fully charged) for this check (IR 26-30), but this is only «fire up» values, not 30sec out.
- and yes, I can burn the light in both ends :slight_smile: it works very well…
So here comes the number, both from the 219C and the XP-G3
291C (lx/lumen values)……………………………XP-G3 (lx/lumen values)
17 lx / 44 lm…………………………………………4 lx / 10 lm
273 lx / 722 lm………………………………………329 lx / 870 lm
572 lx / 1514 lm………………………………………702 lx / 1858 lm
1886 lx / 4992 lm……………………………………2440 lx / 6458 lm
3770 lx / 9979 lm……………………………………4470 lx / 11832 lm
So no matter how we turn the numbers, they are going in all directions, both between my number and maukka´s number.
Also level vice with reference to the advertised number.
So most probably there will be differences from light to light also!!??
Hope there are some use for my number whether they are right or wrong.
@maukka Thank you for sharing your >90 CRI test results!!! I didn't even know 90CRI 219C emitter existed in the first place. No wonder my sample tint looks more pleasing than my triple 219C 80CRI built.
Clemence is selling 219C CRI90 (R9050) from 2700K to 5000K in his shop : Virence.
Kaidomain is selling 219C CRI90 (R9050) 4000K
“emitters swaaaaaap”
Greetings! Please add me to the 219 Nichia list.
Thanks, Charlie
