Just curious, which one to short-circuit for flashing/updating the ZL1100 firmware — the ones circled in red? (probably not the blue nor the yellow one)
Do they need to keep shorted for the whole duration of flash updating, or only when first connecting to the PC?
Also, which micro-USB to plug and connect to the PC? The power/data micro-USB (labeled “1” in pic above). Or the “2”
The two small round pads next to the power input micro usb on the side (1), which also connects to the pc. The pads are a bit hidden. There’s three, one square and two circular.
Those who own the ZL1100, does the fan on the base of the unit impede airflow? If the unit is on a table or other surface, the airflow is blocked, has nowhere to escape, so does the ZL1100 get hot?
There’s an “upadated” ZY 1270. The new version comes with the latest FW and sports a larger screen, it now looks similar to the ZY 1276, the color being the differentiator.
There’s more info on the larger screen, as well as an extra screen, look up ZY 1276 to get an idea on the layout. Seems the new FW is optimised for the larger screen, I’m assuming thats why there are 2 FW’s for the 1270 and 1271, as you can buy the outer panels which has the larger screen cut out.
There’s also an updated ZY 1271 with the same increase in screen size.
I’m planning to order the 1276. I’m not sure I have a use for the extra full-size USB of the 1270. I don’t have much use for the USB-C on the 1276, but I probably will in the future. I’m open to feedback if I’m misguided though.
Yes, Franky Tong. When I bought my 1270 off him (couple weeks ago) I was expecting the older version, where the lcd cutout doesn’t go all the way to the edge.
I was pleasantly surprised to see the updated version when I received it, which was very quick postage. The image on his ebay site is of the older version. I didn’t realise there was a new version until it arrived, I googled and only found 1 picture of the updated version, posted in my previous msg.
You might want to send him a msg before hand just to be sure. His ebay id is f-t-2000
You should order your YZXStudios from Franky soon, since he’s leaving Hong Kong and will stop selling them soon. His ebay store will still be open, but for mostly multimeter leads and other stuff that doesn’t need such involved customer service.
That’s also what I noticed… I need to place the ZL1100 on some sort of stand (maybe a wooden wedge or something) that will hold the tester, so as not to obstruct the fan flow ventilation…
As for the ZY1276, this is one of the meters with a nice large display (the other being the Power-Z FL001, which may be slightly inferior to the ZY1276 [haven’t seen any comparison reviews other than from the YZXStudio official store in China’s Taobao site). I think the Kotomi Pro, aka Power-Z KT001 also has a big display. The new meters right now (see the “USB power devices request for review message thread” for more info) have smaller displays, like the Power-Z KM001 or the ZY1275 (these devices I’ve not seen in non-Chinese webpages yet though… being released just a few months ago)
I’m just wondering, the ZL1100 can be connected to the PC via the micro-USB to USB port to output data.
Could it perhaps be supported by the free DataExplorer software for graphing purpose?
The ZL1100 load tester requires an independent power source for it to function, maybe it’s possible to put 3x1.5v (=4.5v) LR44 (or similar like CR2025) cells in series in a battery holder (preferably also with an on/off switch) and convert output to micro-USB to serve as independent power source for the ZL1100 — anyone has did such a mod?
The range can get confusing, especially when the translation isn’t the best when it comes to specs and reviews.
There are new meters hitting the market, yet they tend to all look similar and have similar functionality. I guess not much you can do about that.
I wonder where to from here, good times ahead for us techies.
I love my ZYxxxx devices, also the bluetooth option, therefore I wrote a small app (now in a very early alpha stage) and would like to share you this pre-version. Comments are welcome.
That looks very neat! None of my Win10 laptops with bluetooth connect to any of my ZY meters. They just say Try connecting your device again after entering the pin (1234). An Android phone connects just fine. I haven’t wired a USB-Serial adapter to them either so I can’t unfortunately test your software. Could you make it work with the ZL1100 load?
Here’s a graph and a snippet of the log it automatically saves (very nice!). I’d like the graph to automatically span the whole test period and not just the last 41 seconds or so. But of course I can use any spreadsheet to do that from the log file.
edit: I noticed the FTDI serial-usb adapter causes a small error in the current measurement as can also be seen from the log above. It reads 0.99A at 1A and 1.98A at 2A. When I remove the connection to pc, it is good again.
