I’m back to report that the Solarforce L2-PC-2 pocket clip that others have recommended works great on the D1!
I spent a few minutes removing the lanyard clip and enlarging the hole to slip past the tail threads. I used a Dremel with a small sanding drum and cooled the clip periodically with a damp rag.
To make up for the gap created by the clip, I formed a piece of 14 AWG copper wire into a circle, flattened it, and fit it into the tailcap.
I removed the tail o-ring, slid the clip on, then replaced the o-ring. Seems like it would still keep water out.
The tailcap tightens down snugly and still allows the clip to rotate with a little effort. I’m very pleased with the fit.
I got two of the clips from Amazon for about $16 shipped.
Mine both have the SOLARFORCE logo etched on them. Others have mentioned they got blank ones.
That is an awesome engineering accomplishment you achieved. That is one thing I wish I had on my D4. I see there is a pocket clip available for the D4 now in case you were unaware. It doesn’t appear to be available separately though.
Thanks! I can’t take credit for the idea. I just wanted to post a photo showing how the Solarforce clip interacts with the larger head of the D1.
Several other members have posted about fitting a ‘captive’ pocket clip on their D4. I liked these as opposed to the ‘clip-on’ clips that others have found compatible.
Thanks for compiling this. I been having a hard time searching for and finding photos of clips people are using on their D4. Hard to find stuff in threads.
I was curious also, do you think somehow with such a smallish reflector the extra output (lumens) would cause the difference. I know that an xpl hi should theoretically out throw a domed sst-40. I am a novice when it comes to modifying flashlights, although I am trying to learn, so I could very likely be wrong.
I need some SST40 emitters? Where do you get them? Mountain Electronics is out of stock. :weary: I guess maybe Kaidomain? Anyone know of any vendors selling 5000K SST40?
