ENEDED
interested nichia
(Purchase) Link please
I am looking for MF01 because it does not come with a holster.
It seems that MF02 comes with a holster, but is there selling schedule for MF01?
if i order an XPG3 from BG right now will it be the upgraded “fixed” version?
Indicate your LED choice (XPG3 / 219C) in you reply if possible.
Edit your previous post instead of creating a new request.
Notification List
Updated on Sep 27, 2017
  1. andrewmac
  2. danggitbai
  3. Kingjohn
  4. cheesecheeks
  5. Sergeantrecrut
  6. cyropro
  7. heatwaves
  8. Lou_Menn
  9. Robsva96 - XPG3
  10. Dralf
  11. Nicolicous - XPG3
  12. Phantom1
  13. ramptosd - XPG3
  14. laythaws
  15. BeardedRaleigh - XPG3
  16. Sukoi
  17. Wieselflinkpro - XPG3
  18. gastonpatagonico -219C
  19. sammubara
  20. qandeel - 219C
  21. Ilmatic - 219C
  22. Ilmatic - XP-G3
  23. tantrik77 - 219C
  24. watamu - 219C
  25. rafalklis - 219C
  26. CJ Avlis - 219C
  27. jamaya - 219C
  28. Mr.Beam - 219C
  29. Mr.Beam - 219C
  30. maildroid - XPG3
  31. Wolpi - XPG3
  32. andrewmac XPG3
  33. southland - 219C
  34. xxx - XPG3
  35. mrheosuper - 219C
  36. atbglenn - XPG3
  37. Nicolicous - XPG3
  38. FG1 - 219C
  39. ersecu - XPG3
  40. xdouang - XPG3
  41. thommy - XPG3
  42. Itsme - XPG3
  43. sammubara
  44. Lou_Menn
  45. FG1
  46. Sledgestone - 219C
  47. Bruno28 - XPG3
  48. baka - XPG3
  49. JIGHEADWORM - 219C
  50. Runar123 - 219C
  51. Soldier - XPG3
  52. keengeorge - 219C
  53. danggitbai
  54. Mattfox27
  55. zoysiamo - 219C
  56. adsum - 219C
  57. djypo - 219C
  58. fireblade893 - 219C
  59. schroeck - XPG3
  60. Flomotion - XPG3
  61. Tom Tom - XPG3
  62. Tom Tom - 219C
  63. EagleShield -219C
  64. JamesB - 219C
  65. Bo4ka - 219C
  66. Ozythemandias
  67. ImA4Wheelr - 219C
  68. Charledflash - 219C
  69. puccio1969 - 219C
  70. Mindaugass - 219C
  71. kahvitahra - 219C
  72. flasky - 219C
  73. X0R - 219C
  74. mickscott - XP-G3
  75. mickscott - 219C
  76. zifzif - 219C
  77. BT100 - 219C
  78. Moe_Suki
  79. FlashPilot - 219C
  80. Tally-ho - 219C
  81. sandro - 219C
The Mateminco MT-18 is a lesser quality light. I’ve also seen it sell for about $50.
The Astrolux MF01 is supposed to be an upgraded and improved version and have higher overall quality.
[quote=silicoon]
[quote=Ozythemandias]
Would you mind explaining what you mean?
I will double check with them for XP-G3.
They’re not the only ones who lost money on this, as of now. :frowning: I still have to yet receive any message from the MF-01 team, nor any further from customer service. I mean, I can understand slow shipping from China, because of distance. But, it’s been a week now since I’ve contacted BG. Slow CS via email does not inspire confidence that my issue will ever be resolved. Freeme, is there anything you can do to help with this?
You will be receiving a replacement for its head, but i am not sure about its time frame.
Hi
Yesterday arrived my 219C
Interested in 219C
Thanks for letting me know! Well, I guess I’ll have to wait until the 219Cs are back in stock, at least.
Any luck finding out?
@freemee: i should be on the list for a Nichia but dont find my name…
Im surprised that freeme read all comments and changed my choice when i mentioned that
Good work freeme
Well I got back from an hour and a half midnight walk with my MF-01 (219C 5000K 90+ CRI) and M43 (219C 5000K 80+ CRI). Some thoughts:
1) Beam profile of the MF-01 is pretty much the same (to my eyes) as that of the M43, so it’s just fabulous!
2) Light output of MF-01 is clearly more than M43. Both ceiling bounce test and throw value show about 50% increase in brightness for the MF-01; roughly 10000 lumens. Nice!
3) A/B comparison is required, but colour rendering of MF-01 is indeed a bit better than that of M43: colours of green leaves are definitely a bit more vivid.
4) Parasitic drain with green breathing light on is about 3 mA @ 4.2V. Since this light is a battery indicator I don’t see this as a problem.
5) Thermal management of M43 is much better than that of MF-01. MF-01 steps down to a fairly low value. I have read it should be about 2500 lumens, but to my eyes it was more like 1500~2000 lumens. M43 is able to maintain a much higher output for a longer period of time, even though the body is smaller. This is a good example of engineering brilliance of the Meteor.
6) red light comes on at 3.4V (6.8V for two cells in series), just like the specs of Astrolux. Resting voltage of cells when I got home was 3.67V. Using HKJ’s data for 30Q at 10A (roughly the draw when turbo), you get 3.4V (with sag).
7) Resting voltage of all four cells when I got home was identical to 0.001V. So I have no carrier contact problem, as mentioned by some other members.
8) One cluster of 6 emitters is a tad brighter than the other two clusters. This is visible in lowest mode. The light has got three discrete drivers, so I don’t see this as a problem.
9) Lowest mode is about 5 lumens or so.
10) Minor gripe with carrier: the four rods are sort of rubberised. When removing the cells, you’re pushing the cell against the two rubberised rods, resulting in resistance due to friction. This makes it difficult to remove the cells. It feels like you have super stiff springs. A different finish of the rods is preferred. An even minor detail of the carrier: I prefer hex screws instead of the current Phillips screws.
11) lock-out, and un-lock unfortunately (for me) does not reset mode memory, so the light will still come on in the mode you were before lock-out.
12) Light has a nice satin finish. I like this a lot.
Conclusion: I hope most people will have a good functioning sample like mine. And assuming you get a good sample, there is no other way for me to conclude that this light is an absolute must, must, must buy. Especially for $70~80,- it’s absolutely fabulous, and I certainly don’t mind my personal observation regarding thermal management, and the UI that won’t let you start from low. My second MF-01 is lost somewhere, but it’s coming my way. If things don’t turn sour, I will certainly be getting the MF-02 as well. Two thumbs up for the MF-01. :+1: :+1:
- Update 2017/9/27 -
I checked output with cell voltage of 30Q = 3.67V
Ceiling bounce test compared to M43 shows that MF-01 actually produces less in turbo than M43! Turbo output of M43 is constant as a function of cell voltage until about 3.5V.
MF-01 at V = 3.67V has turbo output of about 6250 lumens. Level 4 (=high) output produces about 3800 lumens.
:partying_face:
Just realised that my name isn’t on the list. I noted my interest in another 219c in post #1258. Thanks.
Edit, change to 219c on #4 slot. Ty
[quote=silicoon]
At aliexpress, 219C also enters the cart.
Time sale is over in 3 hours.
I do not know whether it will be back orders or cancellation.
