Joey)!! How is it going? Good to see you man.
You better make sure those batteries are charged buddy……. looks like your Q8(s) will be taking flight before too long…. headed straight at you.
Make sure you have your Eclipse Glasses handy too… your gonna need them.
Mine is without bigger problems, some small but not that important.
button leds: one 50% brighter than other, but work - can live with it, but would like to fix that
driver screws: not stripped, look ok to me
tail pcb screws: one really stripped, 2 stripped but usable, one looks ok - don’t care, will replace them probably someday
emitters: 2 centered, 2 off centre? - looks like mistake when soldering? not really a problem to me
reflector: few dust pieces - nothing I care about
brass ring: almost no dirt
driver and tube contact: full circle - I would say perfect
outside: no scratches
Conclusion: nothing to complain about really, but I would like to fix button leds if possible
I need to remember all configuration button combinations some day, but ramping is so easy to use anyone can do it without problem. My dad got it the first time I explained.
Question:
Should button leds be on when light is on? Mine are on when light off, and off when light on.
My brothers light came in today, all looks good. No buggered up screws, the LEDS are both similar brightness. I’ll burn them in for him for 24 hours or so to prove them. I think all of the bad switch LEDs have failed in the first few hours. If I’m wrong could someone please let me know?
XXX-Man, actually two non properly flowed LEDs seem like an issue to me.
How handy are you?
Would be good to at least see how they are mounted, the cooling of the LEDs goes through the little DTP part of the ledboard.
Hang in there, solutions are being debated and we will wait for the first 500 to arrive to know exactly how many are affected.
BrianK check manual, if you can’t turn them on you have the issue too and need to be added to the OP list.
Please report
Yeah but for some reason 1024 is such a nice round number while 768 doesn’t do it for me
TM, mine are on and working perfectly and I burned them in for 24 hours so I think I’m good. But I’d like them on permanently and not turning off when the light is switched on. I don’t see anything labeled that in the information I have.
