Thorfire and Astrolux are flashlight brand names. Astrolux is the house brand name used for Banggood products.
Not everyone wants to buy directly from Banggood because you have to set up a special account just for them. But there are many thousands people already signed up to Aliexpress because they sell all kinds of stuff like clothes and jewelry, etc… It’s easy for all those people to buy banggood products through that Elfeland store.
Aliexpress is like Ebay. They sale all kinds of stuff. So banggood decided to have a store there just like a lot of company’s have stores on ebay. Does that make sense?
Hmm. There’s no way to really make it brighter and run cooler other than just putting in more efficient LEDs. They could just push the drivers harder and make it throttle at a much slower rate or down to a higher brightness.
If your name is already in the list (post #2),you don't have notify me if you wish to swap between tints. Supplied coupon will be valid for both tints anyway.
It should read : You are correct, the DQG CW is way more “yellow/greenish” than the MF-01 XP-G3. Skip this: You are correct, the DQG NW is way more “yellow/greenish” than the MF-01 XP-G3.
Then I think we are on the same page…
But when we are talking about the MF-01:
One of the battery carrier are drawing the batteris uneaven.
(acttually, one was at 3.84v, two was at 3.98v while the last was at 4.20v !!)
The other one works fine, drawing the batteries even.
Well my second MF01 showed up today. The three clusters of 219C emitters are evenly lit on low output unlike my first sample. Turbo output is also around 10000 lumens, so I’m very happy. Take it for a spin tonight.
i did the same bypass the main spring and didn’t notice any improvement, i guess the spring is compress in the way that it creates a short path and no bypass is needed or maybe the spring is good enough.
Okay, so the xp-g3 MF01 is a more cool white. This sounds pretty good to me. I was afraid the xp-g3 was gonna be yellow and green tinted like my dqg. Now I may consider getting one. Hmmm.
There has been 3 or 4 people report the same battery voltages. Only 3 of your cells are making contact. You need to check that none of the white discs are too high for your batteries.
