Hmm. There’s no way to really make it brighter and run cooler other than just putting in more efficient LEDs. They could just push the drivers harder and make it throttle at a much slower rate or down to a higher brightness.
If your name is already in the list (post #2),you don't have notify me if you wish to swap between tints. Supplied coupon will be valid for both tints anyway.
It should read : You are correct, the DQG CW is way more “yellow/greenish” than the MF-01 XP-G3. Skip this: You are correct, the DQG NW is way more “yellow/greenish” than the MF-01 XP-G3.
Then I think we are on the same page…
But when we are talking about the MF-01:
One of the battery carrier are drawing the batteris uneaven.
(acttually, one was at 3.84v, two was at 3.98v while the last was at 4.20v !!)
The other one works fine, drawing the batteries even.
Well my second MF01 showed up today. The three clusters of 219C emitters are evenly lit on low output unlike my first sample. Turbo output is also around 10000 lumens, so I’m very happy. Take it for a spin tonight.
i did the same bypass the main spring and didn’t notice any improvement, i guess the spring is compress in the way that it creates a short path and no bypass is needed or maybe the spring is good enough.
Okay, so the xp-g3 MF01 is a more cool white. This sounds pretty good to me. I was afraid the xp-g3 was gonna be yellow and green tinted like my dqg. Now I may consider getting one. Hmmm.
There has been 3 or 4 people report the same battery voltages. Only 3 of your cells are making contact. You need to check that none of the white discs are too high for your batteries.
The problem found, had to measure around the board, one of the two brass contacts (+) had come loose.
Had to find out my old solder bolt and put some heat on the brass contact surface and got it fasten for contact again.
The problem was then resolved. made a “dry run” and checked that the batteries were equally discharged and everything was ok.
Thanks for the pointing out JasonWW and L4M4. <span class=“high. to were “discs” white the of None BTW:”>
Freemee, I thought I asked to put on the second list (missed out on the GB, too slow), but don’t see my name.
Just one torch, now that I know code will work for Nichia or Cree. It will be Nichia provided same LEDs will be used. I am happy with small price increase for some improvements. Will the tube be knurled and match the MF02, I would prefer that ?
By the way. is the MF02 delayed, last time I looked you didn’t have a date ?
