Got Haikelite MF02 today. This light has a really hopeless UI. I thought about reflowing the LED with XHP35 HI, but it won’t work, a full driver swap is needed to make it a good light.
But nevertheless it has a solution to one hardness that I have with D4 UI, which is shared by Andúril.
As a new user of this UI, I would frequently start turbo, want to step back, click once instead of twice and pollute the mode memory with turbo.
Now I don’t make this error, but nevertheless I often have problems to return from turbo. I keep double-clicking, the mode doesn’t change. I don’t really know why. Maybe I somehow have turbo memorized too? After a few trials I unscrew the battery tube.
MF02 steps down from turbo with 1 click. That’s way more natural for me. And if you want tu turn off, you just click again. You can do it very fast, a regular 2-click turns it off.
As we’re on it, I have another note.
I really like mode memory. But only as long as the light’s memory is not longer than mine. Today I blasted myself with a high level again. Not directly, but the reflection from the earth was painful nevertheless.
I believe adding a time limit to mode memory would largely solve the problem.
The driver already uses the temperature’s derivative to decide what to do. It works pretty well, especially in the newest version. That’s how it starts steering before reaching the turn.
I ran into some click-detection issues in the D4 code… issues which have been in every open-source e-switch light I’ve seen for years. In the D4 it seemed to have difficulty detecting very fast clicks or very fast double clicks. I’ve also heard about some similar issues in the Q8, where once in a while, on some lights, clicks just don’t register.
That’s part of why FSM is a complete from-scratch rewrite using different techniques. One of the things it fixes is click detection.
That doesn’t happen in Anduril. It was one of the first things I fixed. Double click to jump up, single click to turn off, and the next single click goes to the previously-memorized value… not turbo.
However, there is one caveat to that — if the ramp ceiling is lower than turbo, and the user does a double-click from off to reach the ceiling, then does a double-click to reach true turbo, it will then remember the ceiling level. This can be avoided though, by turning the light on with a single click and then doing a double click to true turbo. Or by setting the ceiling to the highest level.
I’m undecided on whether that should change, whether return-from-true-turbo should always return to the brightness the user was at before, or if it should specifically exclude moon and turbo from that.
The driver can’t measure time while it’s off, so making memory time out isn’t very feasible unless I increase the standby power significantly to keep the WDT active. There are features I’d like to try which require this though, like an alarm clock mode and a locator flash, so it’s on the todo list.
Thanks for the answers TK.
I’d like to add that the memorization of turbo when I wanted to return to regular mode only aggravated the problem that I had anyway - that the action that was natural for me did something different from what I wanted.
I trained myself to do it right now, but I strongly feel I would have been happier with MT02 style return from turbo.
I’ve been using Andúril on a BLF Q8 and an Emisar D1 for a few days now.
In short, I love Andúril and I want it on all of my lights! :heart_eyes:
I have some ideas for changes and additional features. I know nothing about programming or the time, effort, and space these features may require, so I’m not gonna hold back.
My favorite features
moonlight mode during lockout
adjustable momentary output
momentary disabled only by power cycling
double click from turbo returns to previous output level
memory for previously used strobe mode
adjustable brightness for bike flasher
‘Lightning Storm’ mode
Ramping
option to disable click & hold for ramping down? (ramp changes directions like Narsil)
option to disable blink at max regulated output?
Good Night mode
option to adjust starting output level?
option to adjust time until power off?
Possible bug
dimming bike flasher to minimum enables an unbelievably low steady output
I’m not sure what TempCheck is telling me. On a Q8:
room temperature light - 8 long blinks
after 15 sec turbo - 1 long blink, 1 short blink
after 30 sec turbo - 1 long blink, 2 long blinks
after 1.5 min turbo - 1 long blink, 7 long blinks
after 3 min turbo - 1 long blink, 9 long blinks
More blinkies, please! I realize these are silly and may take up valuable space. If not implemented officially, I may need to learn some C.
party strobe with random brightness / speed changes
defective lightbulb mode
candle mode
other fun blinky modes TK is holding out on :partying_face:
How about a ’Muggle Mode?’ I’d like to hand the light to someone and say “Click to turn it on and off. Hold the button to adjust the brightness.”
Part of the fun of owning awesome flashlights is sharing them, especially with muggles. I’ve discovered that many of them, even after training, will randomly mash buttons and enter config mode within seconds of holding the light. Some have been known to turn the light off and forget where they put it. An optional beacon mode at ‘power off’ would help shorten hide-n-seek times.
Some ideas for ‘Muggle Mode’
uses preset, adjustable ceiling level
disables true turbo
option to disable double-click shortcut, or become shortcut to ceiling
memory works the same as usual
disables click & hold to ramp down, holding the button allows ramping both up & down (like Narsil)
disables advanced features and config modes
disables blinks at max regulated output and at ceiling
option to disable power off, instead entering a beacon mode
If I knew anything about programming, my list of suggestions would probably be much shorter.
Andúril is my new favorite UI, and I would happily use it as-is until TK’s next ’greatest UI ever.’
Reversing — perhaps a compile-time option. After using reversing for a few years and non-reversing for a month or two, I’ve found I like non-reversing better. But it would be a good option at build time.
Blink at max — also a compile-time option. I already added one for blink at moon and blink at channel boundaries, so this fits right in.
Maybe, if there’s room.
Already fixed. This happened because it picks the burst ramp level by multiplying the steady ramp level by 2. At the very bottom of the ramp, though, levels 1 and 2 are actually the same thing, so the burst didn’t change the brightness at all. Easily fixed by using a floor level of 2 instead of 1.
I also increased the bike flasher ceiling so it can run brighter than before.
It should blink out the MCU temperature in C. So, it thinks your room temperature is 8 C, and after 3 minutes on turbo it got up to 19 C. The attiny85 sensor isn’t calibrated though, so this value can be off by quite a bit. Mostly it’s useful as a way to find out what the MCU sees, which can help with setting a temperature limit. But on a Q8, it’ll take quite a while to get hot enough for thermal regulation to activate.
If there’s room. Perhaps on an inconvenient click sequence, like 8 clicks from off?
It’s something I want to try, at least. Not sure if it’ll be in a build for production purposes.
You’re very welcome! Thank you for the excellent UIs!
I think I prefer non-reversing too. If it’s a compile-time option, would it be universal or could reversing be enabled independently for muggle mode?
I meant, “could the blink at channel boundaries be removed?” Compile-time option is fine. I think I’d prefer no blinks at moon, turbo, or boundaries but that’s just me. I know some folks are particular about knowing what circuit they’re on.
That’s what I thought, but the scale and the short blink was throwing me off. I think I understand now that a short blink is a zero. One long, one short = 10 C?
Sounds good. Can it be disabled only by power cycling, like momentary?
Ok!
Thanks again for being open to feedback. As I said before, I’m more than thrilled with Andúril as it is! :+1:
You seem to have omitted any mention of additional blinky modes. I *know* you mentioned ‘defective light bulb mode’ somewhere but now I can’t find it… ^:)
Added reversing to Anduril. Made EV_tick always send 0 while in “hold” state.
Rearranged some build options and made sure the build still works if some are turned off.
Fixed issue where double-click-from-off followed by double-click-to-true-turbo would overwrite memory with the ceiling level. (should make Agro happy)
Fleshed out build options to blink at floor, ceiling, and channel boundaries.
Adjusted bike flasher floor and ceiling: floor high enough to make sure it always blinks, ceiling can be higher than halfway up the ramp.
The reversing thing is slightly different than Narsil and Ferrero Rocher. I wanted to make it more predictable without having to remember anything, so if it has been more than a second since the last user input, a “hold” will always go up. However, if the last “hold” went up, there is a 1-second window where the next hold will go down instead. Also, “hold” at the ceiling level always goes down.
So… it reverses, but it doesn’t stay reversed long enough to confuse a goldfish.
I’ll probably leave it enabled by default, since it no longer has the issue with forgetting what direction it’ll go.
As for muggle mode, I’m thinking it’ll be similar to momentary mode where it has no exits (even for “off”). It’ll be very very limited. The tricky part is figuring out where to put its config settings, if it has any.
OTOH, momentary mode makes a pretty decent muggle mode if set to a medium level.
I just reflashed a Q8 with this newest version of Andúril.
Sometimes a hold from off will remain at moon and not ramp. At first I thought this was only occurring shortly after powering off, but I’ve seen it happen after the light has been off for 30+ seconds. It seems intermittent. I can’t replicate this with my D1 running the previous version of Andúril. Could this be caused by the new ‘1-second’ ramping reverse rule, like it’s trying to ramp down from moon?
Other ramping functions seem normal.
I’m also getting some faint flickering during the ‘steady’ phase of bike flasher mode. It’s very faint, and seems to go away at some brightness levels along the ramp.
If turned off while reversed, it could then try to reverse a hold from off. The amount of time it was off doesn’t matter for that, since it doesn’t measure time while off.
About the bike flasher… it runs at ~4 kHz PWM now instead of 15.6 kHz, as a side effect of some power management changes I added a few days ago. I’m not sure if it’s worth fixing or not, since the fix would cost a fair amount of space. Basically, all interruptible “delay” operations run at 1/4 CPU speed. This affects modes which use those, such as biking, battcheck, and beacon. It doesn’t slow down PWM in other modes though, like ramping and goodnight, which have no need for explicit delays.
The upside of this is that things like beacon are now much more efficient for longer runtimes. The downside is that the PWM on a few blinky modes might be visible or audible in some circumstances.
Eh, probably not. I only noticed the faint flicker while ceiling bouncing the Q8 to check out the new brighter bike flasher levels. I doubt it would be visible on a bike.
I just reflashed the Q8 again. It sure is nice not needing to fire up the soldering iron!
How about clearing mode memory on lockout? You do this on physical lockout already and doing the same on software one seems logical.
After all if I lock it out, I will probably not use it in a moment.
Independently, time-related functions need to increase power consumption only when they are running. So when mode memory is cleared, you can go back to deep sleep.
You need to put these files in your project’s folder.
When you create a new Amtel Studio project, it creates a directory structure based on the name of your project. Right click the tab at the top left of Amtel Studio and click “Open Containing Folder.” Drop the .c and .h files into here and run the compiler again.
Another error you are probably encountering is, “Hey, you need to specify ATTINY” in the tk-attiny.h file. Double click the error, then scroll up a few lines and remove the // from one of the lines reading “#define ATTINY” and change the number to the proper ATtiny model number (13, 25, 85 etc.).
I’ve got Andúril running on a Q8, D1, and D4 now. I love having several lights with the same awesome UI!
I have an EagleEye X6R with a TA driver running Narsil that I’d like to reflash, too. It has a forward-clicky tailswitch and an e-switch on the head.
I’d like it to light up at the memorized level when powered up, so I can use the tailswitch as momentary.
I found this piece of code but I’m unsure what changes to make:
void setup() {
// blink at power-on to let user know power is connected
set_level(RAMP_SIZE/8);
delay_4ms(3);
set_level(0);
load_config();
push_state(off_state, 0);
Am I on the right track?
Also, how can I format code to read properly when posting here? It becomes a mess if I insert spaces at the start of a line.
