The Miller
I canât find a way to remove reflector screw on my Q8.
Itâs badly stripped and so tight I broke only screwdriver I have that can âfitâ
My Q8 do also have that button LED thing going on, but really it dont bother me one bit, but if it do that one day i will just fix it and be done with it.
I am going to do a little modding on it to amp it up a little more, but i am in no hurry with that, first i will enjoy it as is :heart_eyes:
I see in the OP it mentions that lube may be required. Can anyone recommend lube suitable for the Q8âs threads, especially products available in Australia? Thanks.
Try applying the tip of a very hot soldering iron to the screw head for about one and a have minutes and then use the Millerâs rubber band technique.
They could have put glue on the threads.
stephenk, I canât help with Aussie products, but I use a DOW silicone grease that works fine, I think it was The Miller who suggested SuperLube. Itâs not the Space Shuttle where it canât be done wrong or else.
My 3rd and final Q8 (gift for my son) arrived yesterday. After a quick strip-down, clean, lube & reassembly I can report that everything is perfect except for the switch LED's, it has the uneven brightness "problem". I have a feeling he'll want them changing to either blue or white like I'll be doing mine so a non-issue really.
On a side note, I gave my daughter's BF my 2nd Q8, 4 button-top 30q's & a Lii-500 earlier today for his birthday and he was chuffed to bits, he's really impressed.
It really does make for a fantastic gift, many thanks again for all involved in making this concept a reality!
I donât know that this is available in Australia Sil-Glyde , but you can find it in any auto parts store, here in the US. I read a flashlight article a few years ago, where this was mentioned. I just happened to have some in my toolbox. I havenât used anything since.
Try a local Ford dealer parts department. This XG-12 electrical grease is supposedly Nyogel 760G repackaged for Ford. 3oz tube was $15 dollars at my local dealer.
I ordered my Q8 on the 12th. According to the numbers a few pages back, I think it should have been in the âthirdâ set of 500 lights. I just checked my account, and itâs marked as shipped, but the note says âShipment information sent to FedExâ. So, I dunno. Thatâs kinda weird. Maybe theyâre just pre-printing all the labels?
UPDATE: since i received my other two Q8s (second pair came day after the first pair, but got my hands on it only from Monday)
Out of 4:
First came non-lubed, uneven beacon LEDs, beacon LEDs stopped working next morning, has switch contact issue rarely
Second came well lubed, even beacon LEDs, beacon LEDs do work, has very ofter switch contact issue
Third came OK lubed, uneven beacon LEDs, beacon LEDs do work, no switch contact issues yet after 3 days
Fourth came non-lubed, even beacon LEDs, beacon LEDs do work, no switch contact issues yet after 3 days
switch contact issue video (FLASH) â http://tinypic.com/r/2rpqid5/9 you can hear clicks but it wonât turn off at random positions of flashlight
Mr.Poppy: according to previous posts about the light not turning off with a single click, it seems it is a matter of timing: the click must be very short - 1/4s. Can you check if a faster/lighter click makes a difference on those two lights?
