Yes, thatās the thread that peaked my interest also. The OP confirmed it with Nye Chemical so he says. You could PM him and ask. I will say that Ford isnāt in the business of manufacturing Motorcraft oils, or lubricants, so they have to source it from somewhere. I have some Nyogel sitting right here, and comparing the two, I see, feel and smell no difference between the two. They look identical to me.
I've been using a FORD tube of Nyogel for years now. It's on it's very last squeeze. I now remove the cap and dig in with a tool to pull out what I need. It was offered for sale here on BLF by a member a while back, think he got them off of eBay - little older batch but all good.
Iām now re-thinking whether I need (want) the Kronos 70 GB (S70 with higher power driver). Was expecting it to be a quite different animal from the Q8, for throw, but from your shots it seems the Q8 will cover both bases, at least well enough for me, in such a compact package.
PS: were your torches standard, or have you made a few improvements to any ?
More Good Thread Lube Info for inquiring minds.
SuperLube has worked fine for me for years & I will continue using it. For any who might want info on other lubesā¦ hope this helps.
That looks like a compound maybe for assembling industrial electrical gear, petroleum based, and has suspended zinc particles in it to help conduction. I wouldnāt try it if wanting to use lockout. Interesting nevertheless maybe elsewhere inside torch (tail PCB to tube interface perhaps).
I think any decent synthetic grease as previously mentioned is sufficient here, thread-lubrication and O-ring compatibility is top of my mind.
By the way āsyntheticā doesnāt mean silicone based, it is probably a highly refined (chemically reconstructed) hydrocarbon material.
I generally use some bicycle grease with Teflon because already I have it to hand in a big tube, it is inexpensive, and it seems to do the job well enough. And it is a pretty red color Not saying itās the best though, not sure what the base material is, if it is a genuine āred greaseā then it will be vegetable based, to throw another one into the discussion. Itās good stuff for bicycles, at least.
That Ford/Nyogel XG-12 = Nyogel 760g stuff looks interesting, Iāll see if my Ford dealer has it at a sensible price (not really planning on spending nearly half the price of a Q8 on a tube of grease).
Haha TK thatās what i use in my RC cars, and also what i put on the dry Q8 thread yesterday, i need more though cant be more than a few Sq CM in the tube.
1807?
That is sweet and a bit tricky at the same time.
I really like that BLF as a whole did order as much as were spoken for despite we know people have left BLF.
I remember it was pulling with reserve lists to get to the amount needed on other projects, so this is nice.
Of course a 99ā99.9 order rate would have been ideal, leaving more with a profit in it for Thorfire and Banggood. Making ~104% a bit tricky.
But well all in all very happy, also for the trust, when issues became clear people stocked to their pre order, very kind and nice.
I donāt see a pause after moonlight mode when turning on the light with a press & hold. For me it seems that it immediately starts ramping up and I need to ramp down to have the lowest output.
Is the pause duration at moonlight of the D4 the same as the Q8 ?
The moonlight is easy to catch with the D4 while I always miss it with the Q8.
I just found this Ford XG-12 / Nylogel on US Amazon, a couple of options: Amazon.com Around $16 from the Amazon mothership (not too many left) and $14 from an alternate seller. Saved me a trip to a car dealer.
As I know itās only a pause for easy catching, you canāt really see it on long distances.
But when you hold the hand a few centimeters in front of the lens, then itās noticeable.
I estimate the pause is 500msec ālongā
If you ramp down to moonlight with the hand close you can see also the same small flicker as in turbo, indicating end of the ramp.
First of all, I am very glad that you liked the comparative, thank you all for commenting.
Yes, devastates the S70, it is true that the S70 throws something more, but the Q8 gives quite more light, and the flood is impressive, in addition the tint is very nice, the combination of launch and flood of the Q8 along with the tint it has Itās love at first sight.
How good to read that, I am from Galicia, a region similar to Asturias, both very beautiful. I wish I could visit your city, Iām sure is very pretty, too.
I bet you do not need more range or flood than the Q8 can offer you. But of course, we always want more of everything XD
I was skeptical about Q8, I thought I would not be surprised. But I was wrong, I was surprised, and much, it creates a great blanket of light, and throws quite a lot too, and letās not talk about UI, etc, and all for only $ 40, a must have.
My flashlights are standard, without modification.
