Very nice test! Love those beamshots, way better then I could find out here in flat land Texas for that kind of distance.
Just some FYI, I measured the LED bare in my setup and got around 2400 lumens IIRC. It is the same LED from my XHP35 test in my sig as the prototype LED died due to something falling on it and causing it to burn.
Thanks TA. I sort of figured my number on that would be a bit short since the light was cascading over the rim of my lumen tube. Did you take any cd readings?
For the imperial challenged 6230ft is 1.899km
Living close to the sea and in early spring the humidity here stops me from getting any where near that, if I had a nice big building like that hotel to aim at I would get maybe 1.4km :weary:
Yeah, I did some testing at one point and was surprised just how many lumens are lost if any part of the reflector surface is covered, particularly the outside rim.
I am sure there are some losses from the reflector and glass but still should be over 2000 lumens OTF pretty easily I would figure but impossible to know for sure unless someone has a 6” sphere.
I tried to take some throw readings at one point but it was just too humid to get good readings. The readings kept going down the further away I got instead of up like they should. Makes sense as the beam was almost blinding itself from being scattered. My best numbers were actually from less then 5m when the beam had clearly not collimated yet.
I forced myself to wait on trying this light out till I was ready to start filming. Seriously it sat on my desk with no batteries for a week. It was worth it.
I've just rawly estimated the Kcd output of my modified ThorFire TA13 with C2 XHP35 30G and stock output Kaidomain's H2-C driver (1.5A max). My phone measured nearly 75Klx at 0.8m, which is almost 48Kcd. To me this is good for ≈50m, maybe 100 if I'm in a good mood.
With this same reasoning in mind, your gigathrower is maybe good for 260 meters, 525 if I'm in a really nice mood. :-D
The most enjoyable flashlight video I watched to date. Loved it!
Can not wait for the unleashing of the beast. Not sure if i understood the ui completely.
Can the turbo mode be memorized? Or is it only high mode, then you have to double click?
That video was expertly done as usual! I laughed out loud when I first saw the performance! Now, I’m just dang excited to get mine!Thanks to the creators, the programmers, and the reviewers, for their respective efforts. BLF is a great place to be, no doubt!
