Mine is quite simple, as most of it’s features already exist in the FET+1 MTN driver and LD-4 driver, but I’d like a simpler/more accessible (i.e. made in china with free shipping) option
Regulated driver, max 3 to 4,5 amp depending on config (could be single channel, could be a 2 channel amc + another higher amp regulator). If dual sided, that the spring is narrow enough to enable the use of a retaining ring (have soldering/desoldering drivers) by letting the AMCs sit closer together. Bleeder resistor for illuminated tailcap, plus ATtiny25 and OTC for Bistro compatibility
If I understand correctly, two of the main roadblocks right now are waiting for gcc and avrdude to support the 1616/1617 chips?
The driver will likely also need some acupuncture holes or pogo pads to facilitate flashing.
As for firmware, I’ve got a lot of the hardware abstraction already done, to enable e-switch firmwares to run on a variety of driver types. I just haven’t used it on anything beyond tiny25/45/85 with 7135 and/or FET PWM channels, so the first other driver type will likely require some additional plumbing work.
In any case, all the FSM UIs should work with little or no change once the toolkit itself has had a new driver added.
I’d be happy with a simple 1×AA 1-mode 1A+ driver for LEDs, even if it’d require NiMH over alkaleaks. Highest output I can find is for 800mA (FT driver).
It’s a bit out of my league / over my head, but i think i understand generally what you’re saying.
The problem is ‘lossless current sensing’ if i’m not mistaking.
Maybe you can increase the magnetic field enough to use a hall sensor.
Maybe by making a small electro magnet with a couple of windings of 0.8mm copper wire?
It’s not just lossless sensing, but building a circuit to amplify the current signal without creating too much error is difficult as well. Another thing is to get small current steps on the high levels (you may end up …0.5A, 1A, 5A or so).
You create a coil (called solenoid), which is what we have to avoid. Even if the inductance is really low, I don’t want to try that. A coil (with all of it’s effects) on the output of the converter between the led and ground maybe could even prevent a buck or boost converter from working at all. The converter could oscillate because of the inductance, it would never reach the wanted current. And I don’t even want to know what self-induction could do to a GND signal and it’s connected chips…
Let’s see, maybe I can do something about that. 17mm diameter?
For the firmware people:
To make all the DigiPot buck and boost designs work (maybe some more changes in the future are needed, but just to make it work, this is required), we need a change in the firmware. Instead of a pwm signal on the output of the MCU (like in many firmwares), we need the MCU to put out an SPI or I2C signal for a DigiPot (I think SPI is easier to implement). Very often you don’t even need a real SPI signal, but rather 3 pins with the first beeing a “device select” pin, the second pin is just oscillating, and the third pin puts out the data (8-16 bit length).
Another thing: I have now found a pretty easy way to make a switching converter work with e.g. bistro or biscotti (in theory, hopefully it works in practice), but it’s limited: It needs 2 DigiPots (there are chips with 2 in 1 package), so more surface area. I think the difference of the forward voltage created by the LED (lowest to highest mode) shouldn’t be more than 1V or so, to keep the current steps small.
Yep. 800mA is okay (for 3V from alkies, or 2.4V from NiMH), but it’d be nice to be able to run a bit higher from NiMH cells that can put it out pretty reliably. 2 eneloops in a modded MiniMag would kill, if enough light output would result. Even 1.5A or so would help.
One other item on my wishlist would be a decent 1-mode (as to not complicate things) so that a single 18650 or 26650 could decently drive an XHP. An F13 that can dissipate some decent heat could make good use of an XHP35 or XHP50. Right now, I’m using this to drive a regular XM-L or XP-L (forgot what’s in there) from a 26650.
I see no reason a decent cell can’t push more regulated power through a decent chip. 2.8A into an L or L2 is great, but it could use a little more oomf it the host can handle it.
The F13 takes a 22mm driver, the P60/P90/D26 in the MiniMag a 17mm. 20mm is common enough in other lights, too, eg a SK98.
First try on a 1-mode Buck-Boost converter for 2-3AA or 1 LiIon cell:
It uses a TPS63020. You have to calculate max current yourself (see page 13 in the datasheet), but it can do more than 800mA, even worst case. The current can be programmed via one resistor. There’s a jumper as well to choose between normal mode and low current high efficiency mode (see figures 10 and 11 in the datasheet).
How do the spring pads work? They appear to be seprate from the rest of the underside, is that simple so the IC can be heat sinked with those vias or are they V+ and ground?
From what I see the left pad with the vias is V+, the right pad is floating and is just to hold the spring, and the middle vias go to the ground ring and are there to heatsink the IC.
I’m not that involved into this, how can we program the new Tinys then? With an USB to TTL adaper? How does this work on the software-side to get the code sent to the MCU?
This is a 1-Mode boost converter with an MP3431 on a 17mm board, powered with 1×18650 or something similar (max. input current 19A!). Current is set with one resistor, like the 1-Mode buck-boost circuit before (of course you can change the current sense resistor as well).
If it doesn’t get too hot, this circuit could supply (calculated values) up to 6-7A to an XHP50/50.2/70 (the lower the forward voltage of the LED the better), or a bit over 3A to an XHP35.
Heat probably will be a problem, but for short bursts, it should work.
Liking the nice fat copper traces going to the SW, GND, and OUT pins, and especially the nice short path from the chip GND pin to the driver ground ring. In a host with a retaining ring for the driver, or soldered driver, you should get good heat transfer out of it for high current.
Nice thread!
I’d like to see a 10~12mm sized driver for 10440 flashlight with high cri nichia. Preferably e-switch with Narsil or comparable ramping firmware, blinking out the voltage and supporting lighted tailcap. With a true moonlight and direct drive mode. Thermal regulation would be nice, but I think can only be accomplished with the driver behind the MCPCB.
(Being able to run it on AAA as a fallback would be a nice bonus, but definately too much to ask for. )
To build something as amazing as CRX did here Lumintop Tool Ti
but running Narsil would make me a very happy man!
The PyUPDI thing looks interesting. With a need for only 3 pins instead of 6, it should be significantly easier to design drivers which support acupuncture-style reflashing… particularly since one of the pins is VCC and one is GND, so only one actual programming via should be needed on linear drivers. This also allows using physically smaller chips, so more room on the driver for other stuff.
I’m assuming a usb-serial adapter of some sort would work.
It also looks like gcc got support for attiny1616/1617 about three months ago, with a release target of gcc 8.0, so as soon as that’s widely available it should be relatively straightforward to build binaries for those chips.
A proof of concept could probably be done now, using pre-release tools, but the barrier to entry seems a bit high for common use.
Quad XHP35 HI under Carclo 10622 with well over 4 klum OTF and little under 100 lm/W while delivering those lumens. 1000 lm for 1.5h from a single 18650 cell. Flooooooody.
C8 or similar with dedomed XHP50.2 doing 3500 lm and (???) 100 kcd, sustaining 2000 lm for long.
C8 or similar with XHP35 HI doing 2500 lm and XXX kcd.
My favourite UT02 with XHP50.2 doing 3500 lm and 180 kcd?
And those numbers are conservative.
Too bad that with one mode it needs a big host to dissipate the heat…
