I would LOVE to see a BLF version of the Olight SMini. I really want a small EDC running whatever LED I want and a UI like Crescendo or Narsil. In fact, I’ve been looking for suitable hosts for something similar for the past week, and the best I can find are significantly larger, with outdated electronics, and cost almost as much as the D4. I’ve basically resigned myself to the fact that the D4 with the shorty tube is going to be tough to beat.
But something like the S Mini that I can flash and swap LED’s on has me extremely interested.
There is also a clone of the OTR light even cheaper! It has a terrible UI, but had a regular price of $15. That might make for a suitable host. I had only seen it on Aliexpress, but now it shows the product is no longer available.
Someone here, I think it was Tom E, took an M3 and piggy backed a new driver on it and had it running Narsil. It was very cool.
The usb port is on the opposite side of the switch.
The U16 should have everthing the M3 has including the red led under the switch. It’s a bit hard to see though, since the switch cover is white. I could just barely see the red light when my battery was low.
I guess they have it back again, but the priced has doubled
I had that light under sight, but, as you said, the UI is not that great and I have no means to reflash it, so I ended up buying a Olight S1R Baton.
BTW, in a future project, I would love to have a BLF light with these characteristics, small, pocketable, taking 16430 and 18350 batteries, a good driver, with a decent driver (Narsil or Anduril; don’t own any with these, but I love the concept of a “progressive driver”).
Yup, it is not so budget as it was! The price literally doubled in some weeks! :person_facepalming:
I’m not sure about it, but seeing these lights, the are probably getting the hosts in the same place. Even the photos in the specs are very similar. However, Jaxmnve seems to be a “Store”, and OTR a “company”, with all that implies.
So, probably working with OTR could be more fruitful as they are a more recognized seller/manufacturer.
I’d love to have a light with that firmware on my hands!! It would be simply great!!
About the M1, the characteristics are the same of M3 (of what I recall) except that it is a tailclickie! The host seems taller because of the click itself, but its also a small light.
Yes that small OTR clone with charging is doubled in price now
It arrived
Nice tint, way more easy to operate then the Olight it clones, both switch presses easier and a simple click for next mode had my preference over Olights click and hold. Cell indicator. Charging seems OK, the cell has no branding, measure 644mAh and lowest IR I saw was 69.
I like it, it is a little bit bigger then the Olight.
For the same price I would still go for this one and not get the Olight.
Clip is good.
A BLF special with nice UI should have some more zing to it IMHO. But not a lot of room to work with, both space and price doesn’t allow that.
Hum, I wouldn’t have go to the Olight (pricy…) if I could get the features I wanted most in the Jaxmnve or the OTR M3 (direct access to moonlight and turbo, “real” moonlight, and electronic lockout). As I couldn’t get all this in those lights, and I can’t flash or replace drivers (on those lights), I “had” to go to the Olight :person_facepalming:
BTW, can you confirm the modes of the Jaxmnve, please?
About zing you mean other different specs, worthy of being a BLF special? Yeah, I tottaly agree with you!!
My words above were only in the way to have some basis for a small light like this.
In this or another thread, ToyKeeper talked about making a shorter FW3A (FW1A) and I agreed due to the size and the good specs of the FW3A. Making a “FW1A”, for me, would be awesome.
This was a project I found the other day while searching for 18350 lights. Also, I’m not saying these are good, but maybe it can be an inspiration Future is open!!!
As far as I perceived, these were part of a kicstarter project that eventually end up “in nothing”, but can’t be sure on that.
Just checked the price in AE App, and it is on the 11,14€
I guess the price on the website is the one that doubles, but in the App it is the price we first seen!
Oh, ok! Yesterday I saw it only in the website, but its good to have dropped again!!
Nice charging then, not over or undercharged! That is tempting :smiling_imp:
Can you confirm the UI, please?
Thank you for the info
EDIT: That was tempting, so tempting that I ended up ordering today :person_facepalming: Now, the quest for 1 or 2 nice’but’budget 16340 cells!!! :money_mouth_face:
Not sure how good idea it is really, but…
Ledil Seanna A is an Fresnel + precollimator optic. It has ~150 mm diameter and costs $30 when buying 1, closer to $20 at volume.
If we ripped the lenses, removing enclosure it may get down to $20/piece. Being Ledil, it should work much better than cheap Fresnels.
Now, this is an interesting base for a big zoomie. I’ll call it Z.
Initial sketch:
BLF GT-like shape (it’s rough, but the major dimensions are correct) on top.
Seanna without mounting screws on bottom left, Z zoomed out bottom middle, Z zoomed in bottom right.
7p 21700 battery pack. You can use any number of batteries, but the light will surely have balance issues with too few (and may still have with full set ).
The pack should be quickly-replaceable.
With a boost driver it wouldn’t fall out of regulation too soon.
XHP35 LED. Z would be a really nice base for Luminus CFT-90, but:
probably wouldn’t sustain it at full output without active cooling
the LED costs much more
the driver would cost more too
overall it would easily double the light price to get a nicer hotspot and somewhat better performance.
Note: I draw it here with no glass lens in front of Fresnel, just like Ledil does. Bezel size is the same (quite small) too.
Overall, similar performance to GT; should be better, but not much.
Similar price?
Otherwise - a completely different light.
