Thanks TK, I’ll give your code a try. On first glance I see the difference in what we did — I was putting my if-else statement inside the if(ramping) statement instead of outside and duplicating the check. Not sure what the difference is functionally since only one branch of that code is going to run anyway, but I guess there is one. I’ll pull up my edits and compare. Thank you!
Can confirm that code works on my setup too. Not sure what I was doing wrong, but thanks! I do have the same ‘bug’ you report, the ramping doesn’t work until the driver is cycled off and back on using the e-switch, and its got other flakiness like cycling off if you release the side switch too soon after power-up, but its a start. Thanks again!
So I figured this out. For some reason the switch pin on the MCU was malfunctioning. I was poking around with the dmm and noticed there was 21k ohm from the switch pin to ground. I thought maybe the eswitch was the source but after some more troubleshooting I removed the MCU and measured from the ground pin to the switch pin and it was 21k ohm. A new unused MCU measured several mega ohms. After swapping the MCU it works...
I think this was discussed in the Q8 thread but that moves so darn fast it’s well buried by now and can’t find it.
Is there an easy way or shortcut to 100% 7135 while in ramping mode? Only way I know of is to yo-yo between 1 and 2 button blinks to indicate 7135 or fet
Sorry, haven't been able to keep up with this thread - will try from now on. Thanks TK for the help and support! Lots of things goin on with the Q8's.
One more BUG added, thanks to joechina... that's a good thing that he found it, I think . Really haven't been able to spend any time on firmware lately. For some reason I keep playing VOB's youtube review of the BLF GT over and over again, featured here on REDDIT. The 5:00 to 6:00 section features NarsilM - my favorite part .
Here's the latest Open Issues:
Open Issues ----------- - 2017/10/04: BUG: in LVP switch LED control: the LED sometimes is left on after an LVP drop, and is not blinking the way it should be. The "bug" is that I'm trying to control the switch LEDs from multiple places so it's getting turned off quickly after turned on, and left on when it should be left off. It's a timing thing, so has sort of a random pattern - sometimes left on, sometimes left off. The 8 sec LVP blink need to be qualified better, and should not be calling Setlevel() as is because it wants to control the LED
- 2017/10/01: temp stepdown should not happen right away from turn ON. Delay it, least by 15 seconds!
- 2017/09/29: BUG: for temperature stepdown, where in moon mode, a temp stepdown is actually done because moon mode is marked as special level 255, which is considerred as a high level of output instead of very low. The stepdown results in the light switching much brighter. This should only happen id the temperature threshold is set to a low temp, or the light is still hot and not cooled down when moon mode is chosen. It can also result in an immediate jump to the stepdown level as soon as the light is turned on in moon mode. Might appear as a bright flash when ramping first starts.
- re-work triple channel ramping tables: add more to the FET range, check/test for different # of 7135's in the bank (5/27: not sure this is necessary now with new 3 chan ramping table)
- (from JasonWWW) triple channel mode sets are not completely defined, and are different than 2 chans - need to, at a minimum, document it this way - (from JasonWWW) possible problem with mode memory in 3 chan config - must check it out
Possible New Features --------------------- - besides supporting turbo/max on power up, add support if powered up with the button pressed, come up in moon (lowest) mode - joechina recommended to do a quick ramp to max, maybe even quick fade to OFF to ease tension to the eyes. The Olight A1R does this. - enhancing tailswitch support: full mode sets w/memory (Lexel) - add ability to have timed and temp step down simultaneously (Lexel) - research "bump protection" - tolerate a short loss of power - build in a method to show the current config settings - more blinky modes, like lightning, campfire, etc.
Done Issues/Features - FIXED: Tom E: in mode sets, step down settings wasn't working correctly - FIXED: 1 Lexel/BLF spotted: Blinkies unable to turn off in ramping - FIXED: delay processing of fast click operations to avoid max/turbo flash and allow more fast click options (over 4 doesn't work) - DONE: add in buck driver support cleanly (BLF GT) - DONE: add momentary/tactical mode
Tom for the BLF GT in batt check mode is the voltage blinked out per cell? Not blinked out for 16v 4s pack? 4 blinks, a pause then 2 blinks means I have 4.2V per cell?
Right. Yes, it's measuring 4S coming in, but displaying on a per cell basic. DEL did all the work there to get it right with proper resistor values, then wrote the code for measuring it, etc. He took Narsil and fuly modded it to support the driver, then later, I ported and combined it into one NarsilM version, so buck driver support is now melded in with the 1, 2, and 3 channel support in NarsilM.
Awesome. I actually thing that is a lot better than going off the pack voltage. It keeps things simple. I will probly be hitting you up several
times in the next couple days as I have started my vid on this UI
Are there any other lights besides this and the Q8 that are coming from a factory with this firmware?
Any bullet points you want me to be sure an touch on FAQ etc?
Also when your in the strobe configuration mode I see it says “1=disable, 2=one strobe, 3=all 3 strobe. If I configure it to be ”one strobe” Can I choose which “one” it is?
You can check the 6 videos in my sig. They are very basic as I’m not used to making videos. I’m sure yours will look and sound better.
There is so much to cover, you might consider doing more than one video. I’d cover everything that I did, plus what I couldn’t, which is all the indictator light functions.
The Q8 and GT are the first commercial lights with Narsil UI.
The Emisar D1 and D4 are similar, but use a slightly different UI called RampingIOS.
I got a few PMs and questions about the cheat sheet.
Some people seem to have problems to understand the tables and the manual.
I would point out that the normal operation in RAMPING and MODES is very different.
If you look in the first table of the cheat sheet you will see that only the commands for ON and OFF are the same.
I didn’t expect this. I thought a few commands like turbo and moon are the same.
Some people had a problem to switch OFF, lamp seems not respond to click:
Timing of click for off, hold the switch just a tad too long and the Q8 will not register it as shut down command but treat it as a very short ramp command. Your light is not broken. Please try a very fast and short click.
People did asked for examples with complete click-ology.
Best would be to have a lot of subtitles in the video.
Reset to factory in RAMPING:
3x, 2x, 2x, press&hold (for 1.2sec) till 4 blinks
Reset to factory in MODES:
1x, click&hold (for 2.5 sec), 2x, 2x, press&hold (for 1.2sec) till 4 blinks
Switch from MODES to RAMPING
(while holding, the lamp goes into strobes, that’s normal)
hold for 3.2sec, after two short blinks and one blink, 2x.
The lamp continues to blink out configuration for RAMPING.
Switch from RAMPING to MODES
(you hold for a long time, please ramp down, it’s easier on the eyes)
hold for 8sec, after two short blinks and one blink, 1x.
The lamp continues to blink out configuration for MODES.
Strobe Modes:
The normal way (RAMPING: 2x, 2x, Y clicks [Y= 1…4] ) is time sensitive because of the lock in modes. And I got PMs people are not quick enough for the Y clicks, because the Y have to be done right after the second double click.
If navigation is hard, try:
RAMPING from off/on:
Double click, double click, 4 clicks in a row. Now you are in the 5th strobe = 10 sec beacon.
MODES from off/on:
Longhold (over 1,2sec), 4 clicks in a row. Now you are in the 5th strobe
Now you can go back via click&hold. You can go back 4 times, then comes OFF.
If you go backwards you have time to do this.
For RAMPING:
If you want to remember how many clicks to go to B attery = 3 clicks
The B and 3 look quite similar.
Thank gang. One last question, When your in the strobe configuration mode I see it says “1=disable, 2=one strobe, 3=all 3 strobe. If I configure it to be “one strobe” Can I choose which “one” it is?
