Interesting information Tom Tom. What you say sounds like a sort of LD-29 driver, also one of my favourites like all sorts of fully regulated drivers. Modified a pair of TA13 torches with H2-C drivers recently.
Cheers :-)
Cheers :-)
Take a look, usually on Amazon fulfilled at a decent price. Sometimes in a package with a (good) cell, charger and a bike mount. Their grey anodising is soft, but I like the way they wear with use.
Disclosure: I received one of the first (with pill) for review here, and liked it so much I bought several more. The emitters are on Al MCPCBs, cool white but OK, and the larger XM rather than eg. XP footprint and appropriate SMO reflector, so not perhaps the ultimate throwers. The driver seems very good and balanced to me, but maybe does not appeal to those obsessed with max. amps. I like it, and it seems very efficient to me (run time).
Banggood has it. Just saw this C8s CPF review too. Do you know, by any chance, how deep is its driver boot? Driver pics?
Cheers
Not sure what you mean by driver boot. If depth of cavity, well I only have my review sample with separate pill, so not relevant to current production. There was enough room left that I considered packing it with a piece of thermally conductive silicone, but didn’t.
Mine takes I think a 17mm driver (screwed into the pill with a nice ring), and a 20mm MCPCB. But don’t quote me on that. The driver is mostly obscured by a big wound inductor on a hefty toroid core, taking up pretty much the full diameter of the cavity. Not the sort of square sealed component I’m used to seeing these days.
But everything may have changed since then, you will just have to take a chance and see for yourself. I don’t think you will be disappointed.
This is a review of the same vintage as mine:
Yes Tom Tom, depth of cavity.
Nice inductor, not so nice current sensing resistor. 82mΩ is too big, causing a lot of voltage drop and power loss in the driver. If current for high mode is 2.8A, Pshunt = I² × R = 7.84A² × 0.082Ω = 642.88mW. Looks like sense voltage is set at ≈0.23V.
An LD-29 uses a 25mΩ shunt for the same 2.8A maximum driving current. This is much nicer: PLD-29shunt = I² × R = 7.84A² × 0.025Ω = 196mW. Sense voltage is 0.07V. How good would it fit I don't know.
Cheers
That Thorfire C8S sure looks lot like Sofirn C8S:
What size is the driver in that Thorfire C8S, anybody?
In Sofirn it’s that 20mm (20.8mm plate).
Edit: That driver Barkuti showed is from Sofirn AE shop. It is 18.8mm size.
I should be getting the ’F by next week, acto the email notifications from the Post Orifice.
I doubt it’d have the throw of a single big-reflector C8, but the idea of trip XP-Gs is intriguing! Wonder if it’d be floody or throwy. Best of both worlds, or worst?
Never had a multi-reflector light, so this should definitely be interesting!
My Sofirn C8F arrived today, what picture do you like to see?
I will try to post pictures tomorrow but I can’t do a full review like everyone here :person_facepalming: .
These are pictures of Sofirn C8F with stainless steel bezel for Convoy C8
Have fun …
If you take your new flashlight outdoors, you'll be...
getting the 'F out!
Sssssssssssssss.
What the @#$%? I'm also getting the F soon FFS!
(Error: I'm getting the T.)
̿ ̿ ̿ ̿̿'̿'\̵͇̿̿\з=( ͠° ͟ʖ ͡°)=ε/̵͇̿̿/'̿̿ ̿ ̿ ̿ ̿
Original posting date: Wed, 10/04/2017 - 07:28. Content fixup.
I knew I should’ve picked the XP-L HI…
I know I should have picked XP-L HI. XP-L2 is domed so it’s not really a thrower in my opinion. Of course if it would be dedomed but why bother, I have gray Convoy C8 with XP-L HI led and that has also stainless bezel Edit: I have Sofirn C8A, that has XP-L2 led.
0K, don't blame on me :facepalm: much my pals, I just rechecked my conversation with Tracy Wan from Sofirn and I'm getting the C8T. Really sorry for this, it happened because I asked someone about and he told me “the C8F because of its uniqueness” or sort of. Got a bit messed up in my mind but now, in retrospect, I'm looking at it with better eyes. At least I know how to get a proper candela figure with my smartphone.
kotobuki, what's the MCPCB size for that C8F? The very reason I just noticed I'm getting a C8Turbo is because I was wondering how could it be that Tracy told me the MCPCB was 16.8mm on the C8T…
Cheers
Some more pictures of Sofirn C8F:
Factory bypassed springs? Nice!
Thanks for the review Jouna!
Thanks for the pictures, kotobuki! Looks interesting.
Massive triple MCPCB, looks to be ∅≈28mm, don't you think?
Emitters are XP-G3, they're listed as XP-G2 in their AliExpress ad. Custom request, kotobuki?
I can see the new driver Tracy Wan told me about. The 8-pin SOIC thing and the small 3-pin stuff look like the MOSFET switches. Then there's the usual 10-pin microcontroller this OEM likes to use and an also unknown to me 5-pin whatever chunk of silicon at its left.
Cheers
Any chance you could measure the spacing of the reflector? I’d like to know if it is compatible with any Noctigon triple MCPCBs. Also, would the triple reflector work in a Convoy C8 host?
