Test/review of Vapcell NCR21700 4800mAh (Purple)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 days 23 hours ago
DSC_2049
Official specifications:
  • Model: vapcell INR21700
  • Size: 21.0*70.0mm
  • Nominal voltage: 3.6V
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.50v
  • Typical Capacity: 4800mAh (0.2C discharge)
  • Min capacity: 4700mAh (0.2C discharge)
  • Weight: Max:69g
  • Internal resistance: Max:14mOhm
  • Standard Charge: 1500mA,CCCV 100mA cut-off
  • Charging Time: 5 hours (standard charge)
  • Quick Charge Current: 4000mA
  • Max Continuous Discharge Current: 20000mA
  • Operating Temperature: Charging: 0°C ~ 45°C, Discharging: -20°C ~ 75°C, Storage Temperature: -5°C ~ 35°C
  • Storage Humidity:
  • Appearance: Without scratch, distorion, contamination and leakage
  • Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH, Atmospheric Pressure: 86-106KPA
Vapcell%20NCR21700%204800mAh%20(Purple)-info
A very high capacity cell in the new 21700 format.
DSC_2046 DSC_2047 DSC_2048
DSC_2050 DSC_2051
DSC_2052
DSC_2053
DSC_2054
Vapcell%20NCR21700%204800mAh%20(Purple)-Capacity
The discharge curves tracks nicely and the battery has lots of capacity, but it is not a high current cell.
Vapcell%20NCR21700%204800mAh%20(Purple)-Temp-15.0
At 15A I have to stop the discharge early due to temperature
Vapcell%20NCR21700%204800mAh%20(Purple)-Temp-20.0
Vapcell%20NCR21700%204800mAh%20(Purple)-Temp-30.0
At 30A it gets hot fairly fast.
Vapcell%20NCR21700%204800mAh%20(Purple)-CapacityTimeHours
Vapcell%20NCR21700%204800mAh%20(Purple)-Energy
Vapcell%20NCR21700%204800mAh%20(Purple)-PowerLoadTime
Vapcell%20NCR21700%204800mAh%20(Purple)-TripCurrent
Vapcell%20NCR21700%204800mAh%20(Purple)-Charge
Conclusion
This battery has very good capacity, but is best used at 10A or lower for continuous usage.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
mrheosuper
Last seen: 1 month 7 hours ago
It has nearly same capacity of decent 26650, amazing
Forgot my pen
Barkuti
Barkuti's picture
Last seen: 6 days 7 hours ago
Samsung 48G based. Overspecced cell.
This cell simply cannot be rated “48” at any discharge rate. Silly
Decent 26650, mrheosuper? To me a decent 26650 is the PLB 5000mAh (LiitoKala 26650-50A and the newer rewrap Lii-50A).
This is for everyone, not just for the aforementioned. Now go hit the “rude” button, you @#$%!  Thanks! Smile
If we were to define capacity from a ≈1C standpoint, this cell's down to 2.8V rating is 4500mAh. It's power delivery ability is not even half of that of a 50A. Yes, it is smaller and lighter but, at what price?
I can buy two 50A cells for the price of this @#$%. No need to say @#$% else.
It is funny to see how quality chinese manufacturers are being more honest than Samsung, Panasonic/Sanyo and Sony.
Open your eyes, lads and lasses.
Cheers Party
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
