Emisar D1
I know this may be a silly comparison, but has anyone tested the Emisar D1 (XPL-HI) against a Jaxman M8 (XPL-HI)?
I own a M8 modded with fet driver , let me measure it;s output later today , and i’ll report back .
Thanks :wink: It is more of curiosity, as I have the Jaxman M8 under sight for so long, but not the Emisar D1 comes and makes things complicated :smiley: :person_facepalming: Despite being different lights in terms of functioning, of course!
Thanks!
Does anyone else have the pronounced yellow dot in the hotspot that is somewhat common for XP-L HI emitters?
Glen I gather that you appreciating a flashlight is high praise indeed! I have been thoroughly impressed with each of Hank’s emisar branded lights. I have 5 D4s (all different emitter options) and a single D1 (so far!)
Joey, I’m thoroughly enjoying the D1 more and more as I use it. I love it so much, I plan on buying a D4 and a D1S when it comes out.
I notice it only on a white wall at around 10 feet. In real use, it’s not noticeable at all. BTW, It’s not a dot from what I’m seeing. I’d call it the center of the hot spot. It’s minor and not a big deal IMO.
I have been anxiously awaiting the release of the D1s ever since Hank slipped a picture of him holding one into another thread. Anyone know when?
Can anyone suggest a holster/belt pouch that is readily available, forthis light.
If it’s the size of the Convoy M1/M2 I imagine the Convoy holster will fit (it fits S2+ sized lights with still some room to spare)
So you can have an idea of what the D1 looks like in the Convoy S2+ holster, here are some pics. I happen to have both, but I don’t normally use them in this combination. You can see that it fits and will close, but because of the big head it feels like the velcro wants to separate. The stiff fabric would probably bend more easily over time with use. Perhaps it could work for someone.
Maybe I missed it, what light is this one? And has there been any reviews? Thanks!
Its the D1s Alex, not released for us to buy yet.
My M8 has a fet driver running sir404dp fet , for 53kcd . I think i measured th reflector at 29mm back when i modded it .
D1 and D4 has my back! in my works ruck sack
that D1 beam is crazy! That D1S beam is even crazier!
Thanks :wink: That is sure of a hotspot! I suppose their illumination range is quite similar, then!
Few pics
Is there a memory mode that ignores turbo?
There is a memory mode that doesn’t ignore turbo. So 2-click to get out of turbo before turning off.
