MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
8370 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 6 days 23 hours ago
The Carclo 24mm quad series would be pretty easy to swap in for a different beam profile, the Khatod optic would require pretty drastic modifications, probably the only real way to use the Khatod would be to machine a new bezel tall enough to handle the extra height.
My EDC Ti/Cu light has the Khatod and the beam is pretty impressive. Clicking it up to level 7 outside in search of a crittur making noise the illuminated area is pretty staggering. The D4 is also quite capable of surprising one in it’s output and coverage levels. I would think a 10623 (hope that’s right, the last 2 are the main important ones, it’s a spot optic with a diffuse surface, no cup in the external make) would be a nice swap. Maybe floodier with a more uniform output.
contactcr
Last seen: 7 hours 5 min ago
Will the D1S be available for pre-order with you guys like the D1 was? Any ETA for that?
contactcr
See if you can get the D4 pocket clips they have on intl outdoor page too. Im sure plenty will add some to their next order Smile
Newlumen
Newlumen's picture
Last seen: 11 months 1 week ago
Hello I am trying to purchase a convoy l2 xpl hi from mtnelectronics.. I am planning to use it with 2 ×26650.. is this light came with the extension ? Or I need to purchase extension? Thanks.
http://www.mtnelectronics.com/index.php?route=product/product&path=80&pr...
noboneshotdog
Last seen: 1 week 2 days ago
Newlumen wrote:
Hello I am trying to purchase a convoy l2 xpl hi from mtnelectronics.. I am planning to use it with 2 ×26650.. is this light came with the extension ? Or I need to purchase extension? Thanks. http://www.mtnelectronics.com/index.php?route=product/product&path=80&pr...
I think you will need to purchase this.
http://www.mtnelectronics.com/index.php?route=product/product&product_id...
Thier ain’t no bones in a hot dog. F. York
khas
Last seen: 1 week 3 days ago
According to the listing the extension tube is included :
What’s Included :
Convoy L2 XP-L HI Flashlight
Battery tube extension
Extension comes with both smooth and anti-roll rings.
Lanyard
18650 conversion spacersSmooth ring and Anti-Roll ring for extension tube
Newlumen
Newlumen's picture
What’s Included :
Lanyard
This is so cool.. where can I find the lumen and lux info?? Thanks.
JasonWW
JasonWW's picture
Last seen: 1 day 18 hours ago
Newlumen wrote:
What’s Included :
Lanyard
Here is a link to the Convoy store. It’s a 3A driver so the xpl should give out about 1000 lumen. They don’t list lux so you’ll have to search for that from what other people have measured.
Convoy L2 CREE XPL HI V2-1A LED Flashlight torch,lantern,self defense,camping light, lamp,2cells version http://s.aliexpress.com/u2MnEZrm
Firelight2
Firelight2's picture
Last seen: 2 hours 54 min ago
Richard,
Any word on when SST40 emitters will be back in stock?
Also, will you be carrying 5000K SST40?
DB Custom
DB Custom's picture
I swapped the Nitecore EA8 Caveman’s XM-L emitter for an SST-40, took it from 900 lumens to 1400 lumens without changing anything else but the MCPCB… the orignal was thin aluminum and I used a 20mm SinkPAD modified to fit. Pretty cool to gain 50% more output without having to bump the driver! Smile
DB Custom
DB Custom's picture
Got my Emisar D1 today from Richard, boy do I like how this light looks and performs! Big Smile
Here’s the Emisar D1 beside a Manker Godmes T01
With the 1300mAh Aspire 18350 I’m seeing the lowest setting at 0.7935 lumens and the highest at 1249 lumens, start value. Tail current on a fresh Aspire 18350 was 4.88A.
With an Sony VTC5A 18650 I’m seeing the high end at 1462 lumens with a 6.56A tail draw. Even at 30 seconds the Sony was still delivering 1345.5 lumens. Smile
Gotta love it!
Edit: PS, gotta make note, the reflector in this D1 is as near perfect as any I’ve seen! Beautiful! Nice job Hank, very much appreciate the effort! Smile
DB Custom
DB Custom's picture
Might be worthy to note, I grabbed my little 18350 equipped D4 to look for something earlier today, the one with XP-E2 green emitters, and it would only operate in full Turbo momentary. Couldn’t figure out what might have happened to it. Got the D1 in the mail this afternoon and when I locked it out with 4 quick clicks it too operated as a momentary in Turbo. DUH! My little D4 had been locked out. A quick 4 clicks to unlock it and it worked perfectly. LOL
giorgoskok
giorgoskok's picture
Last seen: 1 week 4 days ago
Lock out mode is 6 clicks !
4 clicks changes between Tactical mode (momentary) and regular modes ramping .
T18
Last seen: 1 year 6 months ago
I’ve had some odd button sticks, but generally if I double click the light it will stop whatever it is doing wrong or loosen the tail cap. Not anything to complain about at all.
goshdogit
goshdogit's picture
Last seen: 17 min 58 sec ago
I suppose this is the first and only time we will see your D1 in stock form. Big Smile
What are your plans?
DB Custom
DB Custom's picture
You are so right, changes already made, it now makes 1552.5 at start and 1400.7 at 30 seconds on an Aspire 18350, 1735.35 at start and 1604.25 at 30 seconds on a Sony VTC5A.
Spring bypasses top and bottom, swapped in an XP-L W2 1D on a 20mm Noctigon. Big Smile
Love how it lost .4A but gained some 300 lumens in the trade. Wink
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 57 min ago
I like the W2-1D Thumbs Up Very Nice!
KB1428 “Live Life WOT
DB Custom
DB Custom's picture
Fitted the long tube from my D4 onto the D1 so now it takes a 20700A cell and makes 1783.65 lumens at start… interestingly enough it does the same 1604.25 at 30 seconds as the VTC5A.
Newlumen
Newlumen's picture
Hey db, thanks for the lumen number.. look like Sony vtc5a give advantage… Your lumen number are pretty accurate???
DB Custom
DB Custom's picture
My light box was calibrated with 25 ANSI rated lights, so it should be very close. Any new light I get that has ANSI ratings I always check against it and the variances are +/- from moon to Turbo, usually very close.
Richard (RMM) and Tom E as well as robo819 all use light boxes made by the same people as mine is, so at least 4 of us are in sync and we all show similar numbers to the ANSI rated lights for the most part.
Edit: One thing that is an obvious difference is the cells we use. I try to use the latest and greatest cells for maximum output, because max is how I like it. The manufacturer’s do not necessarily use, say, the Sony VTC5A, so the numbers can vary on this alone. Wink
Edit II: Might ought to add, I swapped the MOSFET to an Vishay SIRA20DP and it is now making 1818.15 lumens at start on the 20700A cell. Big Smile
Newlumen
Newlumen's picture
Thanks db.. you are the best. I am using Sony vtc5 on my d4. What kind of lumen am I getting?? Thanks.
DB Custom
DB Custom's picture
What emitters does yours have?
Mine was set up with XP-G2 and I swapped in Nichia 219C, Nichia 319A, XP-L HI and finally XP-E2 green. Somewhere in the Emisar D4 thread of TK’s all the results are posted. Smile
Newlumen
Newlumen's picture
I am a fan of cool white. Xpl hi v3 6500k.. I just use medium mode and the light didn’t get warm.
I love this light, so I bought another d4 in xpg2 dedome and d1 sst40 dome on.. ( from a modder)..
DB Custom
DB Custom's picture
Careful with the SST-40, it can’t take direct drive FET from a top cell, it’ll blow bond wires. (at around 9.6-9.7A)
Deputy Dog
Deputy Dog's picture
Last seen: 2 weeks 2 days ago
Contactcr asked:
I’m curious as well.
doubleone44
doubleone44's picture
Last seen: 1 year 8 months ago
Coupon code doesn’t work for me for some reason.. “Warning: Gift Voucher is either invalid or the balance has been used up!”
Firelight2
Hm… my plan is to stick an SST40 in my D1. Waiting on my shipment of SST40s from Mountain Electronics.
So I gather I shouldn’t run an SST40 equipped D1 on a VCT5. What about 30Q?
Newlumen
Newlumen's picture
Ok.. so far it’s working fine.. I have a d1 with the sst40 dedome running Sony vtc5a..
DB Custom
DB Custom's picture
I wouldn’t do spring bypasses or use thick wires, leave some resistance in place so the emitter can survive.
korpzgrinda
korpzgrinda's picture
Location: Eastern Woodlands in the Wilderness of North America
You have to use the code while on the shopping cart page. It doesn’t work if you are already on the checkout page.
