You cant photoshop CRI on a non CRI light source
White balance cant fix it, a CRI light wih more red illuminates only red parts, more amber, cyan also come in play with high CRI light source the same way
This is absolutely not an area that I know anything but Great Thread!!
Maukka gave a good idea on thos “Viltrox”, I know exactly who would need just these :+1:
Hi. I have the same question. I want a good high cri flashlight but in a small compact edc form. What I have found so far is an upcoming flashlight which according to specs is not only high cri, compact and and reasonably priced but also high lumins considering it’s 90+ cut.
WUBEN T046R 1300lumims
It has 3 XPG3 less which I was concerned about but after some research I found out that recently they have indeed released a high cri version of this led. Though it has slightly greener tint rather then the radish tint of the HIGH IS 219B. Would anyone suggest a similar flashlight to this one? Or is this a good option in it opinions.
If someone can suggest other similar high CRI COMPACT FLASHLIGHTS I WOULD appreciate it really.
If you want you could contact kiriba-ru on this forum and he can send you an assembly for the S2+ that uses 3×219C 4000K leds on KD board with KD optics. The whole assembly including the pill is a drop-in module - all you need is a pair of needlenose pliers or heavy duty tweezers to change the optics out. Cheaper than a new light.
Oh no! I shall have to hope nothing ever goes wrong with mine then! I LOVE my triple you made for me. I’ve been putting it to good use for all sorts of things, including photography - it does burn through a 18350 in turbo, though!!
@Stephenk Thanks first of all. I have searched the jaxman e2 and e2l. E2 has much is 219b but only 350 lumins. E2l has
Has quiet a lot more lumin but so far as I can tell only xpg2 led. Not sure if it has high cri.
@lexel i did know about the astrolux. But I prefer s42. Which one do u recommend? Nichia 219b in s41 or nichia 219c in s42?
@drhook59 the new pill would have definitely been a great option. Sadly no more left :(.
