So you can have an idea of what the D1 looks like in the Convoy S2+ holster, here are some pics. I happen to have both, but I don’t normally use them in this combination. You can see that it fits and will close, but because of the big head it feels like the velcro wants to separate. The stiff fabric would probably bend more easily over time with use. Perhaps it could work for someone.
Honestly, that doesn’t look any better than the Convoy holster I posted pictures of. The pictures on BG just show a narrow head type of flashlight fitting well into the holster (looks like a S41). Sure the D4 will fit, but I imagine the fat head of the D1 will be bulging out at the top. Pictures of actual use would be helpful.
I’m used to neutral tints. The tint in the 6500K SST40 from Mountain is quite cold in comparison.
Hopefully Mountain will get some 5000K SST 40 soon. 6500K is a bit too cold for me.
I tried dedoming a few of these SST40s this weekend:
First attempt: Soaked the star in Coleman Fuel for 3 hours, then pushed off the dome with a toothpick. This is the method I used to successfully dedome many XPG2, XML and XPL emitters. OUTCOME: Failure. When the dome came off it took out the emitter wires. The bond wires weren’t just snapped off at both ends. They were simply gone.
Second attempt: Same as above, but soaked for 6 hours. OUTCOME: Failure. Same result as first attempt. Both bond wires snapped. They were still there, but the ends connecting to the casing had broken and both wires were dangling from the LED.
Third attempt: used the hot knife method to slice off the top of the dome about a half mm above the emitter. Heated the star with emitter just as if doing a reflow (but not till solder melted). Then heated a brand new unused #10 exacto knife blade and sliced off the top of the dome. OUTCOME: Success. Smoothest slice dedome I’ve ever done and I didn’t break the bondwires. It still works. Hotspot is noticeably smaller with similar throw to the stock XPL HI (maybe a tiny bit less). Unfortunately, the tint shift was extremely minimal. Went from maybe 6500 down to 6000K at best. Still too cool for me.
Fourth attempt: Coleman fuel soak overnight. I’m not expecting any better results than the first and second attempt though. The bondwires seem much more fragile than those on CREE emitters. Looks like if I want to dedome these and get a shift closer to neutral I may need to get some Toluene. OUTCOME: will find out tomorrow.
I dedomed it in regular 95 octane petrol. Soaked it upside down and the dome fells off and you know then it is done.
I made this little thing wrom wire to hold the led upside down.
