Review and disassembly: Sofirn C8F
86 posts / 0 new
XXX-Man
XXX-Man's picture
Last seen: 12 hours 2 min ago
Flashlight was provided from Sofirn for free.
Specifications from manual:
LED: Cree XP-G3, 1955 Lumen, 13600cd, 5350-5700K
Operating voltage: 2.8-4.2V
Power: 20W
Output: 6A
Battery: 1× 18650 Battery
Switch: backward tail clicky
Size: 14.4cm length, 4.46 / 2.45cm diameter, 140g (without battery)
Material: 6063 Aircraft aluminum with Type III anodization
Reflector: smooth
Battery warning: Blinks 2x/sec. And turns off one minute later
Deep discharge protection: yes, at 2.8V
Lens: Hardened glass lance with AR coating
Waterproof: IPX-8 (2 meters for 30 minutes)
5 Mode: High 1955lm 26min; Mid 630lm 1h40min; Low 105lm 9h8min; Moonlight 1lm 800h; Strobe 1300lm 1h26min; SOS 1300lm 1h26min
2 mode groups: moon/low/med/high/SOS; low/med/high; strobe is activated with double tap
Mode Memory: yes
Package:
Sofirn C8F, manual, strap, 2x o-ring
Flashlight has nice feel and looks good quality.
Threads are square and look. They are anodized and came well lubricated.
Tube is not reversible.
Threads are compatible with Convoy C8.
Tail switch is reverse clicky mounted on 17mm board, held in place with retaining ring. It has nice click.
Flashlight can tailstand without problems.
Driver is 17mm, bigger driver won’t fit. It’s fixed with retaining ring.
It has 3/4 modes with memory and strobe on double click. Modes are nicely spread.
Glass is 42×2mm without AR coating and reflector is SMO.
There is o-ring between bezel and glass.
LEDa are XP-G3 and is on 30×1,5mm alu board.
There is 1 screw holding board to shelf. Shelf is fixed, so no pill.
There is good amound of thermal paste between board and shelf.
Picture with CC bezel from Convoy
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
Edited by: XXX-Man on 05/01/2018 - 05:56
XXX-Man
XXX-Man's picture
After reassembly it was working for 2 minutes and then turned blue so I quickly turned it off.
After turning on all I get is this, on high.
Crying
Any idea what happened??
My reviews:
kiriba-ru
kiriba-ru's picture
Last seen: 11 hours 32 min ago
There could be too small pressure to the pcb from reflector (due slightly different bezel size).
XXX-Man
XXX-Man's picture
You mean LEDs overheated?
There was even more pressure with SS bezel. It even doesn’t screw all the was down with thick o-ring I used.
I don’t think it could overheat in a minute even with low pressure, but I may be wrong.
My reviews:
mrheosuper
Last seen: 4 weeks 7 hours ago
maybe the driver can’t handle the current
Forgot my pen
khas
Last seen: 1 week 17 hours ago
Mine looked like this when I turned it on first time :
I don’t think the XP-G3 likes the heat, the MCPCB isn’t DTP.
XP-L HD/HI works fine :
With XP-L HI V2 4B it pulls 12.3 A on a VTC6 on high, it does get very hot before the 3 min step down, I have been using it for walking the dog the last two evenings drained two VTC6 batteries so far no problems with XP-L HI
XXX-Man
XXX-Man's picture
You did reflow yourself? On stock pcb?
My reviews:
AgentSteel
AgentSteel's picture
Last seen: 10 hours 35 min ago
Looks like there’s some room for improvement LOL
Flashlights, blades & beer
Let’s stay relatively optimist!
giorgoskok
giorgoskok's picture
Last seen: 3 weeks 6 days ago
Did you bypass the springs too ?
khas
Yes I re-flowed the emitters on the stock MCPCB myself, the XP-G3 has a low Vf so they pull a lot of amps, if the just used XP-G2 instead it would be fine.
The springs are bypassed from Sofirn.
XXX-Man
XXX-Man's picture
Ok, looks like I have to order some XP-L HI Big Smile
Can you post some beamshots? I want to know how does it look with XP-L HI.
White wall would be ok Smile
My reviews:
khas
Sofirn C8F Triple XP-L HI V2 4500K LED
I sent Sofirn a message on Aliexpress trying explain that the XP-G3 is the wrong emitter for the C8F, it’s of course fine if you use a low drain battery, but high drain battery and bypassed springs is not going to end well.
XXX-Man
XXX-Man's picture
Thank you. Looks great Smile
Maybe I killed it because I used LG HG2…
My reviews:
Barkuti
Barkuti's picture
Last seen: 4 days 7 hours ago
If using high drain cells, you may try lowering the cell voltage. You could, for example, start at 3.7V with a 30Q and measure current flow. Maybe the overall Vf off 3 XP-G3 emitters in parallel is a bit low, this way there's a very good chance the emitters will survive by limiting the potential current avalanche.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
XXX-Man
XXX-Man's picture
This looks maybe like design fail and if it is it needs to change.
No battery should cause leds to die in any flashlight.
My reviews:
Barkuti
Barkuti's picture
XXX-Man wrote:
This looks like design fail and it needs to change.
That is what regulated drivers are for.
Cheers Smile
XXX-Man
XXX-Man's picture
I guess you are right Smile
My reviews:
Lightbringer
Lightbringer's picture
Last seen: 51 min 42 sec ago
Turning blue means catastrophic levels of current being pushed through the chip.
I had a “3V-22V” drop-in that I wanted to test to make sure it could handle even only 2 cells, so put in 2 18350s. Got really blue and really dim. Didn’t have it that way for more than 1-2sec tops, pulled the plug. 1 cell back in, the bugger survived.
1 cell?? Dunno how a trip could go blue from only 1 cell like that, even if just crowbarred right across the LEDs.
Unless they separated from the mcpcb and were just floating? Could make electrical contact w/o much thermal contact. That might cook ‘em.
XXX-Man
XXX-Man's picture
It was on no more than a second after turning blue but no help. I don’t understand how would they get so hot that fast. I was using it max 2 minutes before they died but it wasn’t constant on as I was playing with modes.
Interesting is moon didn’t work at all (before it died), leds were off in that mode.
My reviews:
Lightbringer
It’s before my time here, but I believe OL did pretty much only DD lights: LED and Li cell and switch, that’s the whole circuit. Don’t think they could cook so fast unless there was some serious thermal upset.
‘Though now with continuous-38A cells…
NikolaS
NikolaS's picture
Turning blue means that solder under led is bad and melting at low temperatures. Try to reflow same xpg3 with better solder and flux, worked for me couple times even with DTP boards and XHP70…
XXX-Man
XXX-Man's picture
You think they could work again?
I did led reflow only one time before, so no experience with that and no tools for that.
My reviews:
NikolaS
NikolaS's picture
I am 99% sure they will come back to life..
Probaj nemas sta da izgubis Beer
blueb8llz
Last seen: 4 hours 34 min ago
So runtime is less than 30 mins on high? And only 13 kcd?
XXX-Man
XXX-Man's picture
NikolaS
I will try Smile
blueb8llz
That’s what manual says. I have no way of measuring it.
My reviews:
Barkuti
Barkuti's picture
The emitter board is said to be aluminium and heat transfer to the leds' thermal pad is thus also crippled. It would be wise to start measuring tailcap currents with less than fully charged batteries and work your way up from there to observe current ramp up as cell voltage is increased.
As it is, lower discharge cells may work better in this torch.
Cheers
XXX-Man
XXX-Man's picture
You were right, reflow helped and leds are working good.
Only problem I have is it died again, but if I press on led with my finger it works when pressing.
I have to clean the board and replace solder and I think it will be ok. This time I only heated it as it was.
My reviews:
NikolaS
NikolaS's picture
You welcome Cool
Just clean all remaining solder with copper wire after removing led, and some 1000 grit sandpaper will clean underneath led remains with just slight moving without any pressure. Applying good flux and quality solder will solve the problem for good..
XXX-Man
XXX-Man's picture
NikolaS
I tried today several times and there is always at least one led not working good.
All of them are working now, but 2 are on only about 50% brightness.
Not gonna bother with it anymore.
I have asked Sofin for replacement MCPCB or I will somehow put 3 DTP boards in with XP-L HI.
My reviews:
L4M4
L4M4's picture
Last seen: 8 hours 16 min ago
Just ordered this light and three of these: http://kaidomain.com/p/S026300.Nichia-219C-Neutral-White-4000K-CRI92-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
Since I have these LEDs as a triple in my S2+ and I am loving it, I hoipe to get a very nice High-CRI trower (i.e. more throw than that triple S2+ ;)) with this combination.
NikolaS
NikolaS's picture
Sorry to hear that,hope you will end up with best solution. I have xpl-hi on the way, hopefully next week I will have a chance to test out that driver since Sofirn claims 4.5Amp and 1300+ lumens.
I will do a short review also
