I run VP C114+ Race fuel in my Drag Bikes and that’s exactly what this stuff smells like!
Well 2 hours on warm in the crock pot, domes are swelled up, but not off, let it sit over night, got up at 3:00 a.m. Targets remain….will check after work…
No worries, the slower the better! The boiling Imron Thinner blew the domes off 5 XHP70 emitters and the phosphorus with them, the 70.2 came off in like 5-10 minutes in the stuff, but the beam was crap, the phosphorus is like really chunky, the only ones that it worked on was the XHP35 HD’s I de-domed. But I ran them in lights first, the other were brand new never lit up!!
Jeez not slow enough! So after 2 days cycling between warm (the lowest setting on the crock pot) and cold, letting it sit over night, gone thru 9oz. of Toluene… it’s not good! :person_facepalming:
The domes on 2 must have been hanging by the bond wires and took them out with just blowing on them and the first one hit with a light blast of air took the phosphorus as a complete pad with it? :rage:
The XML’s XP-G2’s no problem.
Had them sitting up, as not to pull phosphorus off hanging them upside down, like what happened with the XHP70’s?
I’ll give it another go, hanging them upside down and see? IF this don’t work, I’ll just go back to agitation and cold fluid de-doming……takes forever but it works for me with the XHP35’s and XHP70’s.
Well the liquid de-doming isn’t the problem, that I’m finding out with the tougher LED’s, it’s the time, nothing good comes fast I guess.
And too Hot seems to just explode the domes up off these tough LED’s and takes phosphor with it, as I witnessed doing the Hot and I mean bubbling HOT de-doming (MEK :confounded: ) the XHP LED’s. :cry:
I’m going to reflow 3 more SST’s and hang them and just go slow, till they fall off? Then see what’s UP? :person_facepalming:
Normally I just use one of them Jewelry Sonic cleaner’s and IMRON paint thinner but it could take a week or two, because I only run it when I’m going to be around to monitor it, other wise it just sits in the fluid.
Let’s call it heated chemicals method, works fine for me when I dedome XML2, XPL or XPE2 leds, usually I hang then upside down submerged in liquid heated to about 45-50 degrees celsius. It takes about 40-60 minutes and as soon as I notice that the dome has lifted from the phosphorus surface I take them out, remove the dome, wash the led with 96% alcohol then remove remaining silicone around the phosphorus “core”, wash again with alcohol then with destilled water, dry it out with compressed air and that is it, for XPL its even faster because silicone dome doesnt go around the led like on XML2 or XPG2… leds.
This method gives me minimum tint shift, I would say that 6500K only drops to 6000-5800K (but I have no way to measure this so, it’s my subjective opinion).
That’s what I’m thinking right now! :person_facepalming:
I really want to put one in my M25C2 Turbo, I have a de-domed XPL-W2 6500k in it now and at 6.27 amps it’s throwing just over 580kcd conservatively, on a VTC5A. I want to see what the SST-40 can do. I’ll probably change the FET out on the real old Mtn FETDD driver after I take a current reading if the driver can’t supply 8amps to the LED? I have SIR800’s 404DP’s and Infineon FET’s I could try out?
Sort of dedomed an SST-40 on white spirit, but screwed up the little bond wire which connects the two substrate pieces while removing dome leftovers with a toothpick. What is it for?
