The Defiant Super Thrower, and the C2V3 26650 torch body, (both now very difficult to find) to make a 18650 or 26650 DST.
After buying a couple S41S heads in the 3/30 AliExpress sale, I thought I would try out some legoing. The Ultrafire and some generic 501's and 502's fit and work. I didn't realize until after uploading the pic that the middle one below was not all the way screwed on. Tail cap just about touches the knurling and head has a slight gap.
OdePro TM30 "legos" with Astrolux S1
HC30 Head, Eagle Eye A6 18350 Tube and HC30 Tailcap. The 18350 Tube came off a EE A6 Shorty that I got from DB. It does not work with the H03 Tailcap. It measures 2”5/8 or 66.675 total length.
Jaxman E2L Head, HC30 18650 body, Jaxman Tailcap.
HC30 and H03 Tailcaps also work but only as twistys.
This mini Headlamp fits better on the Xtar H2 Commander Head Strap.
Sofirn C8F and Convoy C8 clean version:
Hello!
Can anyone tell me does convoy’s c8 tail fits on astrolux s2 or EE X6?
I need pressure remote switch for astrolux s2 or EE x6,so i will buy one for convoy c8 if it fits!
I just checked and the tail of the C8 does not fit on EE6X…
Thank you chooma!
I think i will use universal pressure switch from BG but it replaces original 16mm switch board.
Convoy S2+ short tube on Sofirn SP32A head and tail (anodized threads upwards and non-anodizing downwards)
Sofirn SP32A tube on Convoy S2+ head and tail (works both ways works with the taller threads towards the tail)
Not sure anyone else will find this usefull, but X6 tube can fit in X7 retaining ring threads.
If you feel your Olight SR91 is too long and heavy and/or if you do not like or want to buy a new proprietary battery pack, just screw the head onto the
body of a Thrunite TN31.
Well, you have to modify the head a little (reverse the spring and remove the black plastic cap).
The tailcap switch of the TN31 body will not work anymore but the electronic switch of the SR91 head will.
Mine is being converted to XP-L HI V3 3C which together with the factory Olight driver (close to 7 Amps!) will provide between 450 - 500Kcd of
beautiful NW light.
Much better then the original.
Cheers
Nico
I just posted this in other thread, but realized it should be posted here too. The tubes from first generation MT03's fit the MF01. I haven't tested to see if it works because my MT03 is 4S at the moment. But other than the O-rings not reaching the head, it looks like it would work fine electronically with no to little modification. The MT03 doesn't have a battery carrier (Cells load from the tail). IIRC, the plate on the head side of the tube looks like it would mate up with the MF01 driver without modification.
The head of the Ultrafire WF-502B screws perfectly onto the Revtronic PT20. Clearly the LED is that of the PT20, but the reflector has to be changed with a 26.5X31mm (I did not find it, I made it with a hand-made aluminum cone)
The image below is the original PT20 at a distance of about one meter (white wall)
The image below is the PT20 with head 502B and self-realized reflector, always at a distance of about a meter from the white wall.
In normal use (about after three meters) the various light rings are not noticed; the modification can still be improved and is easily reversible, unscrew the head of the 502B and replace the one of the PT20
They are compatible. Swapped in 2S plates to the MT03 and it works with the MF01. Makes the light much "grabbier" and easy to hold. Shorter too. Unfortunately, the MF01 tube does not fit the MT03 due to the shoulder built into the tube.
The JAXMAN 18350 battery tube is a perfect fit for the Sofirn SP31 and SP32A
The head of Sofirn SF14 fits on the body of the Sofirn SF10 , and the head of SF10 legoes with the SF14 body! FrankenSofirnStein
Xref: Mateminco X6S, Factory Triple - #22 by DB_Custom
Hst tip tp DBCustom for that.
And scroll down in that review thread for more lego-info.
Streamer wrote here: [Sofirn Lightning Deal] Sofirn SP32AV2.0 only 20.99 on AMZ us - #67 by Streamer
Good Information. Thanks.
