Let’s call it heated chemicals method, works fine for me when I dedome XML2, XPL or XPE2 leds, usually I hang then upside down submerged in liquid heated to about 45-50 degrees celsius. It takes about 40-60 minutes and as soon as I notice that the dome has lifted from the phosphorus surface I take them out, remove the dome, wash the led with 96% alcohol then remove remaining silicone around the phosphorus “core”, wash again with alcohol then with destilled water, dry it out with compressed air and that is it, for XPL its even faster because silicone dome doesnt go around the led like on XML2 or XPG2… leds.
This method gives me minimum tint shift, I would say that 6500K only drops to 6000-5800K (but I have no way to measure this so, it’s my subjective opinion).
That’s what I’m thinking right now! :person_facepalming:
I really want to put one in my M25C2 Turbo, I have a de-domed XPL-W2 6500k in it now and at 6.27 amps it’s throwing just over 580kcd conservatively, on a VTC5A. I want to see what the SST-40 can do. I’ll probably change the FET out on the real old Mtn FETDD driver after I take a current reading if the driver can’t supply 8amps to the LED? I have SIR800’s 404DP’s and Infineon FET’s I could try out?
Sort of dedomed an SST-40 on white spirit, but screwed up the little bond wire which connects the two substrate pieces while removing dome leftovers with a toothpick. What is it for?
Edit: copy the whole quote so you get the whole picture instead of just saying it’s for ESD protection so you don’t go and put a solder blob there and damage something. (Well maybe works if you ONLY gets solder on the wires but that would be tricky. Maybe wrong… ask the experts)
True reverse-polarity protection would have to shunt the full reversed-voltage current as the LED would handle if forward-biased, and that’s way too small. So it’s probably a small zener diode, about o(10V) or so, to just shunt small reverse-biased voltage spikes from static.
Anyone want to test it?
Snap together a few 9V batteries, 1 at a time!!, put a 100kΩ resistor in series with it, then “zap” the LED backwards and measure the voltage across the LED. Full battery voltage means the zener ain’t conducting yet. If the voltage is, say, 6.2V from a single 9V battery, it’s a 6.2V zener. If 9V from one 9V battery but 12.6V from a pair at 18V, then it’s a 12.6V zener. Etc.
Keep the current to around 0.1mA (100µA) or less, preferably much less.
It’s not that clean as it seems, I was actually not impressed with this results at all, small white-ish dots that you can see on the led surface, that’s actually silicone that I was not able to clean off.
I am using stuff that is not available in US, it is called medical gasoline, super pure gasoline that can be used for cleaning wounds (evaporates fast, doesn’t leave any smell afterwards), It gives perfect results with XML/2 and expecially XPL leds, XPG2 also end up looking nicely, XPE2 leds are a bit stubborn thou.
For example XPL is dedomed in about 15-20 minutes in this stuff at ~50 degrees celsius.
Tried my luck with 2 leds, first one with hot dedome, left it in until I noticed dome swelling (maybe temperature was too high).here are the results, as you can see phosphor layer was also affected, piece fell of with the silicone while I was attempting to clean silicone that was left stuck to the led surface. The second one was cold dedome.
I left the led in for about day or two, I was not expecting good results because stuff I use affects on a tint shift so I usually leave led in just until I notice that dome started lifting from led’s surface, so shortest possible time, after that I rinse it thoroughly with 96% alcohol, blow off with compressed air then rinse it with distilled water one more time -> drying with compressed air and that is it, led i ready to be installed.
When I dedome XPL led I noticed that dome is not swelling its as if the “dedoming liquid” gets between transparent silicone dome and led + white silicone that surrounds leds die and just lifts the dome, results are perfect, as if CREE never put the dome on. Dome on the SST-40 behaves differently.
I don’t think that medical gasoline is used to cleaning wounds.
The medical gasoline we have here is for removing the glue from the skin when removing the plaster (right word? Patch?) from small wounds. Or cleaning the microscope lens from immersion oil.
Same product?
CAS-nr.: 64742-49-0
Substance Name: Naphtha (petroleum), hydrotreated light
Or Benzinum medicinale
Quite possible, I would say that I pretty much had good luck with major injuries, I didn’t have any, so didn’t actually see this stuff in its intended use, It can only be bought in pharmacy and it is not for drinking so, I presumed it was for cleaning
