Tom Tom, the Si9926CD datasheet lists a maximum of 8A per package. The thermal resistance is too high and the little FET bugger will end up like a roasted burger. I'd stack another package just because of reliability.
Cheers ^:)
Cheers ^:)
$9.06 for a TA13 at Banggood only leaves me $1.94 to get an SST-40 on copper DTP star.
Stacking another one on top will make almost no difference to thermal dissipation. You would have to lay them out on separate bits of the PCB, for the heat to be conducted through the leads into separate areas the PCB where it gets dissipated.
We are agreed, this little package would be toasted without any decent thermal path into the board. Stacking another one on top won’t improve anything there.
I think the two FETs inside the one package are quite capable of handling the current, and the power. And the PCB, presumably so.
The rest is over to you, if you think e.g. reducing from 9 to 4.5 milliohms is of any consequence…
$8.99 on e-bay.
$2.09 for SST-40 when buying 1, $1.6 when buying 10.
These are on stars, though I don’t know if they are DTP. Most likely not copper…but if it’s DTP I would stick with it for such cheap light. If it’s not DTP then this light won’t be nearly as cheap….
Agro, these are DTP mounted emitters: “thermoelectric separated” search at FastTech
The boards these leds are mounted over:
I believe both boards are DTP, only from different providers. Hope FastTech were more clear with their product descriptions.
Reflow the cheapie on one of these boards, or buy a ready-to-go SST-40 on custom KDLight copper star at Kaidomain.
Cheers ^:)
;SST-40 on custom KDLight copper star at Kaidomain.
Cheers :partying_face:
I can recommend those with experience. First fried two cheap SST-40 with poor star/MCPCP. Then ordered those and they handle amps at least up to 5.5A in my setup. Edit: Someone told me that he drives those at 8A.
“according Cissy from Sofirn driver is direct driven.” That I updated today and I measured tailcap amps of C8A: I got with freshly charged NCR18650GA after some spread 6.10A @ High. Have anybody measured amps with different/ better batteries from any other model (or same) of those C8:s?
Edit: Peak was around 6.3A.
Edit2: Now there is in add that driver is direct drive.
Edit3: Led gasket have been chanced but only for XP 3.5mm footprint leds:
C8F,Cissy told me will have a upgrade model, with 3 groups and DTP MCPCB, :heart_eyes:
Just talked in other matter with Cissy from Sofirn. She asked me something, I answered but maybe here are also people that could say their opinions. It’s about new C8F. There are two kind of driver groups and Cissy asked which one would be better. I quote Cissys message straight here and do tell what you think.
“Switch: one side switch
One click enter group1 : Low- mid-high
Double click enter group2: LL-Low-mid-high
Three click enter group3: firefly-LL-Low-mid-high
In any groups when light on, double click enter hidden mode:strobe-SOS-bike -strobe. three click enter turbo mode 1950 Lumens
2. 3 groups modes:
Turn on enter group 1: low-mid- high
When light on, four times quick press switch to change groups, cycle from group1- group2-group3-group4
In any groups when light on, double click enter hidden mode:strobe-SOS-bike -strobe. three click enter turbo mode 1950 Lumens”
And like Jackie said above C8F is coming with DTP MCPCB because of problems with heat.
3-D photo of C8F to come:
One group with high only please!
I voted for plan B if need be. No one’s going to remember to click 3× just to light it up from off. Best to just set it and forget it.
But doubleclick-to-blinky is just evil. Rather doubleclick-to-turbo or something, instead.
If the µC is flashable, maybe some other eswitch-enabled UI could be stuffed into it.
Unfortunately, it says something if a UI is unwieldy enough to have to replace it with something else.
Just sent this to Tracy:
Hello Tracy,
I heard you've worked out the initial C8F revision issues, namely the non-DTP (no thermoelectric separated) MCPCB. It's was a dissipated power per surface unit disaster waiting to happen.
With regards to the interface, I think plan 2 has the highest chance of receiving great appraisals. I believe people wanting to namely use groups 2 or 3 could complain from needing to multiple click the torch to switch it on the way they mean it to play with plan 1. Just my opinion, of course.
Cheers
Agree with Lightbringer with regards to the triple and doble click function swap.
Cheers ^:)
- 3 groups modes
2. 3 groups modes:
Cissy/ Sofirn needs help to decide from 2 groups. She gives everyone who respond to this query 2$ discount QR code from at least 15$ purchase from Sofirn AE shop. I sent it via PM to all who gives their opinion which group would be better.
Copy of what Cissy said about double click after I asked could it be modified:
“Double click to turbo 1950Lm and three click to strobe-SOS-bike-strobe.”
And also assumption from Cissy: “also may use 3 pieces XPL instead of XPG3”
:smiling_imp: may it burn?
I vote plan 2 now when it’s only 3 groups you can switch between.
It’s easier for “normal” people to get right.
Double click for turbo should be standardized.
3 fast clicks for strobe…
Changing groups should atleast be 5 fast clicks so it don’t accidently change group instead of putting on the strobe to blind an attacker or whatever strobe is used for.
If I was in that situation and I panic and try to put on the strobe and accidently changed mode instead of getting the strobe I think I would have gotten more panic.
If i just did a double click when panic I think ~2000 lumens would still blind the attacker.
How do animals react on high lumen strobe when attacking?
Should I strobe an attacking bear, wolf and such animals?
Just curious…
Edit: damn bad English
Does this Sofirn driver have any hidden turbo?
It says 86%PWM at high, can’t find any info about any turbo.
I guess it’s the driver that’s in the Sofirns right now?
No thermal stepdown?
Link:https://m.aliexpress.com/item/32834504322.html
Sofirn New C8A C8F C8T Driver 2 Groups Circuit Board Anti-reverse LED Driver Chip mode memory
Protection:Reverse polarity protection, low voltage protection, Memory mode function
Input voltage: 2.8-4.2V;
Current: Directly-drive
Suit for : Cree XM-L ; XP-L, XP-G
2 Groups:
Group 1:Low 5%PWM> Mid 30%PWM > High 86%PWM,Double click strobe 86%PWM.
Group 2 :Moonlight > Low 5% PWM> Mid 30%PWM > High 86%PWM> SOS 86%PWM,Double click strobe 86%PWM
Low voltage protection: Yes. The light is automatically turns off when the voltage is lower than 2.8 volts. The signal is that the light slowly flashes for 1 minutes
Group Set Operation: When on, 3 click continuously, the light flash 2 times and then automatically goes to next mode group.
Edit the link.
Hmm. It says this above the text I wrote in the other post.
Specifics
Voltage 2.6-8.4V
Brand Name Sofirn
Usage for flashlight
Certification CE
Not right?
Is it only 1 cell driver as the text under this text says?
I hate when sellers give 2 different descriptions on the same item.
Only makes me not buy it.
- 3 groups modes
2. 3 groups modes:
I prefer Option #2… preset mode groups
With double click to turbo.
Triple click to hidden strobe.
Use XPL2 leds
Thanks!
EagleShield, you can open the images in a new window and copy its link from there, some browsers even allow you to grab the link directly. Maybe you did that because you have the app installed? ;-)
I can't stand nearly any specific purpose app, they're full of shittiful restrictions versus a browser in desktop mode. I only install the AliExpress app to grab “app only offers”, to immediately uninstall it just after the purchase. As a user of Chrome browser, keeping the app installed is a real piss off experience, constantly bugging the user with prompts to open AliExpress links in that @#$% software. The browser does it all and does it better nearly always.
It is only a single cell driver, as far as I know. Maybe it can be used to DD 2S emitters with 2S li-ion input…
The low power MOSFET is probably an A09T (AO3400), the high one is a 9926A (dual MOSFET per package).
Cheers :-)
Yeah. I have the app installed.
Trying to get a link to that item too but only end up getting to Spanish aliexpress it seems.
And what’s really annoying is when trying to browse aliexpress with chrome and have the app installed… it opens every item in aliexpress app but I click that chrome should do it!!
Why do I use the app you would think? Just because I dont like to log in all the time. I don’t trust any browser to save my password.
