[Finished] 5. Batch "TA" Bistro HD OTSM/Narsil drivers, 15-47.5mm size fit H03, MF01, MT03, Q8 1S or 2S, Clicky or E-switch
Would you like to post a Q8 OSH-Park link?
Thanks
put me in for a 22mm bistro 3v
and 26mm 6v bistro with springs
with post to Australia
thanks
If its OK I can equip them with the PSMN3R0-30YLDX FET
its the same as in the BLF Q8
and costs 0.6$ less
The 26mm Board will be a 30mm one sanded to 26mm
I will start this batch when I can confirm the new AMC supplier has the same quality than the last one had
The I will order SIR404 FETs and other parts for this batch
I don’t know why the old supplier is not selling claw types anymore
I have here 3 blank Q8 drivers so if you need only one board its cheaper
board cost plus 1.15$ shipping
I have 2 Q8(one on the way), so I need 2 Q8 board.
[quote=Lexel]
and costs 0.6$ less
that will be ok ,make it 30mm as I will make the light to suit
shoot me a pm with total costing thanks…
[quote=lostheplot]
Ok
I am atm a bit low on LDOs more coming soon
I put you on Batch 4 list
I got only parts for OTSM Bistro left this batch and next I quit the TA one
Is it possible to get a TA Q8 driver flashed with TK’s Anduril?
If so I’d like one or two (depending on price):
(1)46mm Q8 Anduril no calibration, PO=(2B), SD=2.8V, 16AMC
(1)46mm Q8 Anduril no calibration, PO=(2B), SD=2.8V, 8AMC
Could you post or PM me the price in Euro’s and the price for shipping to Belgium in Euro’s please.
Would it be possible to get 8AMC’s seperatly if I want to add some to the 2nd driver?
Hi
it is possible to add the other firmware if you supply me the hex for it
as I am not familiar with Anduril I cant calibrate it like I am used in Narsil
I can build you the drivers and add 8 loose AMCs
OK, I’ll ask around if there is a Anduril hex file for the Q8. I’ll let you know as soon as I got it, if not I’d buy them anyway flashed with latest version of Narsil. Cheers.
Bookmarking this for future mods. Nice stuff!
It doesn’t look like there’s a HEX file for a FET+N+1 availlble for Anduril. So the latest version of NarsilM will do.
Do the siwtch LEDS blink while crossing from 1AMC to N AMC to FET?
Also, from what I understand (wich is as good as nothing) I cannot just add extra AMCs without recalibrating the driver software?
The Indicator LED blinks out after you stopped ramping which bank is active
You can add extra AMC7135s
The ramping table is a good start and gives good results on most lights,
it depends also how much the FET current is, like a single LED can draw on 17mm 2.45A from AMCs and 6A from FET
while a quad board draws 2.45A from AMCs and 12-15A from FET
for quads the ramping in FET will be proportional bigger,
the SRK sized have 5.6A AMCs to about 20A FET
but the steps in FET are the same its still smooth
ok thanks for explaining.
So I’m stil up for
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 16AMC
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 8AMC
Now that I have read through things a bit more, I am liking these even more.
When you can get to them,
(2) 30mm 2S NarsilM LDO 65°C, SD=6V, PO=(NO), lighted side switch, LED wires, no spring
shipped w/tracking please.
Not sure on the wire length, as I dont have the hosts (Convoy L6) in hand yet. Seems common enough I trust your judgment on that, just let me know.
Thanks,
Jim
I can do this in this batch, but I have to wait to stock up parts and 30mm boards
Sounds good. I am in no rush. Got several others in the works right now to play with.
Lexel, on the 2S boards for the L6, are you still using the 4700k resistor for the switch light?
4.7K ?
I use 20K
20K~30K are fine?
Yeah, I use 15k to 30k.
I was just gonna suggest Lexel increase the resistor value for these 30mm 2S L6 drivers since everyone usually uses 2 leds.
I had another question. Is this accurate?
Could you sacrifice temp protection in order to get LVP and the indicator function?
