Tom
In strobe modes:
If I go back from #1 strobe the lamp goes off. Can we have revolving strobes? So somebody can go #2,#1, #5, #4 , … in circles.
Strobes works exactly the same as normal mode operation, so do you want that for strobes and normal modes?
I got a few PMs and questions about the cheat sheet.
Some people seem to have problems to understand the tables and the manual.
I would point out that the normal operation in RAMPING and MODES is very different.
If you look in the first table of the cheat sheet you will see that only the commands for ON and OFF are the same.
I didn’t expect this. I thought a few commands like turbo and moon are the same.
Some people had a problem to switch OFF, lamp seems not respond to click:
Timing of click for off, hold the switch just a tad too long and the Q8 will not register it as shut down command but treat it as a very short ramp command. Your light is not broken. Please try a very fast and short click.
People did asked for examples with complete click-ology.
Best would be to have a lot of subtitles in the video.
Reset to factory in RAMPING:
3x, 2x, 2x, press&hold (for 1.2sec) till 4 blinks
Reset to factory in MODES:
1x, click&hold (for 2.5 sec), 2x, 2x, press&hold (for 1.2sec) till 4 blinks
Switch from MODES to RAMPING
(while holding, the lamp goes into strobes, that’s normal)
hold for 3.2sec, after two short blinks and one blink, 2x.
The lamp continues to blink out configuration for RAMPING.
Switch from RAMPING to MODES
(you hold for a long time, please ramp down, it’s easier on the eyes)
hold for 8sec, after two short blinks and one blink, 1x.
The lamp continues to blink out configuration for MODES.
Strobe Modes:
The normal way (RAMPING: 2x, 2x, Y clicks [Y= 1…4] ) is time sensitive because of the lock in modes. And I got PMs people are not quick enough for the Y clicks, because the Y have to be done right after the second double click.
If navigation is hard, try:
RAMPING from off/on:
Double click, double click, 4 clicks in a row. Now you are in the 5th strobe = 10 sec beacon.
MODES from off/on:
Longhold (over 1,2sec), 4 clicks in a row. Now you are in the 5th strobe
Now you can go back via click&hold. You can go back 4 times, then comes OFF.
If you go backwards you have time to do this.
For RAMPING:
If you want to remember how many clicks to go to B attery = 3 clicks
The B and 3 look quite similar.
Ups, that got lengthy
Sorry Joe
I think yes.
Right now is the navigation in MODES if you go backwards:
Nr2 -> Nr1 -> moon -> OFF -> Turbo -> …
With revolving navigation:
Nr2 -> Nr1 -> moon -> Turbo -> …
Does that any harm?
To be honest I don’t use MODES at all, I can’t tell.
Thank gang. One last question, When your in the strobe configuration mode I see it says “1=disable, 2=one strobe, 3=all 3 strobe. If I configure it to be “one strobe” Can I choose which “one” it is?
As I know, no. When I choose this option it blinks only with strobe #1
Your GT video is greart!
You should do one with the Q8, it’s a verry practical light around the house, its awesome in tailstand, best UI. It’s worth spreading the word.
That is definitely true. They are completely independent, and intentionally so. RAMPING is based on press&holds to adjust brightness, MODES is based on single clicks to advance to the next mode. The only thing they have in common is the priority given to one click ON, one click OFF, but of course the behavior varies.
For MODES, double clicks (2X, 3X, etc.) are not compatible - there would be too many unintentional actions since you want to be able to fast click through modes. I've used lights with UI's like that and they are a real pain and annoyance. But for RAMPING, double clicks fit in well since your primary means to change brightness is by press&hold.
Like I said, MODES operation and STROBES work exactly the same:
- quick click to next mode
- click&hold to previous mode
- click&hold from the first mode turns the light off (if in MODES, it actually returns to the previous mode)
- the current mode locks in when you stop navigating the modes, and locks in quickly in 1.2 seconds (IDLE_TIME = 75 in the code). You can tweak IDLE_TIME to change this.
- you can easily work around the locked in mode by press&hold to go to previous, then you can advance to the next mode. This will not work if you are on the first strobe mode however, since that will either turn the light off or return to the last mode (if in MODES).
For VOB, if you are used to the old MODES operation of the original Narsil prior to having ramping, then navigating strobes is the same.
If we go with changing the press& hold from 1st mode to loop around to the last mode rather than exiting, I can't think of anything that would cause problems. This would solve the problem for STROBES when you lock in to the first strobe mode, and want to stay in STROBES to choose another strobe or beacon mode. If it's implemented the same way in MODES, again, I can't think of anything causing problems, in fact I think it's an improvement all around:
if in MODES, locked in at mode #1 (lowest):
- one click: turns the light OFF
- press&hold: goes to last mode: max/turbo (currently it would turn the light OFF)
So clearly, it only has advantages to make this change... I'll put in on my list - should be in the next release.
Thanks joechina -- very good suggestion!
As joechina said, no. But this is easily modifiable in the source code - in "Setups.h":
// Custom define your blinky mode set here:
#define SPECIAL_MODES_SET STROBE_MODE, POLICE_STROBE, BIKING_STROBE, BEACON_2S_MODE, BEACON_10S_MODE
Just change the order as you would like, or remove ones you don't want, to add ones. Right now, RANDOM_STROBE is not used but is available. Other special modes would have to be added though (software written).
That sounds like a very nice refinement on the UI.
Finally, I compiled a .hex file, NarsilM V1.0 3C1S
Did not change any CODE……
NarsilM.c
Channels.h
ModeSets.h
RampingTables.h
RegisterSettings.h
Setups-31S.h rename to Setups.h
tk-calibMTN17DDm.h
tk-calibWight.h
tk-delay.h
tk-random.h
I will flash to the ATtiny85 to test
Hi Tom,
Working on the UI vid today. Most everything seems to be going fine, but I have one hiccup. In the “modes” group the count seems to be off some how. On the ref sheet I see that the default when switched to modes should be group 4, but I get 5 mode as default. I tried switching to the first group and I got 2 mode, the second group I get 3 mode. I thought maybe the whole thing was just off by one click but group 5 for me is single mode.
I did try resetting to default, but the result is the same after ward. As far as I can tell everything else works as described in the sheet. I was able to change the moon mode levels etc. Any ideas?
Matt , is moonlight mode enabled ?
If yes , modes are counted without the moonlight .
Ohhh - think the mode sets are "unique" for the GT buck driver build.
I got all the info here. I'll post.
This is directly from the code:
//--------------------------------------------------------------------- // Buck driver 2 channel modes //---------------------------------------------------------------------
// 2.0 A max modes
// 1 mode 2.0A
PROGMEM const byte modeFetSet1 = { 201}; // for analog control
PROGMEM const byte mode7135Set1 = { 255}; // for LM3409 enable/PWM// 2 modes /4 25% 2.0A
PROGMEM const byte modeFetSet2 = { 42, 201}; // for analog control
PROGMEM const byte mode7135Set2 = { 255, 255}; // for LM3409 enable/PWM// 3 modes /3 11% 33% 2.0A
PROGMEM const byte modeFetSet3 = { 26, 53, 201}; // for analog control
PROGMEM const byte mode7135Set3 = { 255, 255, 255}; // for LM3409 enable/PWM// 4 modes /2 12.5% 25% 50% 2.0A
PROGMEM const byte modeFetSet4 = { 27, 42, 77, 201}; // for analog control
PROGMEM const byte mode7135Set4 = { 255, 255, 255, 255}; // for LM3409 enable/PWM// 5 modes cube-oot 1% 7% 22% 52% 2.0A
PROGMEM const byte modeFetSet5 = { 25, 25, 39, 80, 201}; // for analog control
PROGMEM const byte mode7135Set5 = { 24, 170, 255, 255, 255}; // for LM3409 enable/PWM// 6 modes cube-root 1% 5% 15% 32% 60% 2.0A
PROGMEM const byte modeFetSet6 = { 25, 25, 30, 51, 94, 201}; // for analog control
PROGMEM const byte mode7135Set6 = { 24, 126, 255, 255, 255, 255}; // for LM3409 enable/PWM// 2.5 A max modes
// 1 mode 2.5A
PROGMEM const byte modeFetSet7 = { 255}; // for analog control
PROGMEM const byte mode7135Set7 = { 255}; // for LM3409 enable/PWM// 2 modes /4 25% 2.5A
PROGMEM const byte modeFetSet8 = { 45, 255}; // for analog control
PROGMEM const byte mode7135Set8 = { 255, 255}; // for LM3409 enable/PWM// 3 modes /3 11% 33% 2.5A
PROGMEM const byte modeFetSet9 = { 27, 58, 255}; // for analog control
PROGMEM const byte mode7135Set9 = { 255, 255, 255}; // for LM3409 enable/PWM// 4 modes /2 12.5% 25% 50% 2.5A
PROGMEM const byte modeFetSet10 = { 29, 45, 86, 255}; // for analog control
PROGMEM const byte mode7135Set10 = { 255, 255, 255, 255}; // for LM3409 enable/PWM// 5 modes cube-oot 1% 7% 22% 52% 2.5A
PROGMEM const byte modeFetSet11 = { 25, 25, 41, 90, 255}; // for analog control
PROGMEM const byte mode7135Set11 = { 26, 185, 255, 255, 255}; // for LM3409 enable/PWM
// 6 modes cube-root 1% 5% 15% 32% 60% 2.5A
PROGMEM const byte modeFetSet12 = { 25, 25, 31, 56, 106, 255}; // for analog control
PROGMEM const byte mode7135Set12 = { 26, 136, 255, 255, 255, 255}; // for LM3409 enable/PWM
So what does all this mean?
First 6 sets max out at 2 amps, 2nd set of 6 are full power at 2.5A.
DEL's cube root is percentages calculated,similar to TK's python script that calculates lumens.
All these sets exclude moon mode. If you have moon mode enabled, then you'll get the modes above, but also starting with your currently set moon mode level.
Does this help?
What Giorgoskok wrote.
If you choose only mode #1 and enable moonlight you end up with two modes.
If you choose mode set #7 (which has 7 values in the table) and enable moonlight you will end up with 8 brightness levels.
(On the Q8 product page is under product detail a table where it is clear that moonlight is included, when switched on BLF Q8 4x XP-L 5000LM professionelle Mehrfachbedienung Verfahren super helle LED Sale - Banggood Deutschland sold out-arrival notice-arrival notice )
Tom E
I guess the cube root modes are the evenly spread ones?
What is the reason for 2A instead of 2.5A max? Reduced wear?
2A gives a longer in regulation run time while 2.5 amps is available with a double click. From memory the difference in output was somewhere around 13%.
Previous post has the GT mode sets. The Q8 is different.
As the Mrs said (Steve), the intent is prolonged runtime to max at 2.0A. If you want the full 2.5A, there's a duplicate set of modes available shown above, plus in ramping, ramping max's out at 2.0A but a 2X click goes to turbo at 2.5A.
Tom,
The Q8 in MODES:
What is the lock out comand?
(I thought 2x + click&hold )
But on my Q8 it is 4 clicks like in RAMPING.
Edit: I already did a reset to factory.
joechina, According to your cheat sheet it is 4 clicks for lockout in both ramping and discrete mode, I just verified with one of mine as well.
[edit]It does work this way, but I read the UI cheat sheet wrong. Tom has verified this is a bug.[/edit]
In MODES operation:
- 2 quick clicks followed by click&hold works for me (as designed)
- 4X clicks though will restore it from lockout, as well as 2X clicks + click&hold (as designed, both ways work).
- Just tried it: the 4X clicks to enter lockout in MODES is also working -- this was unintended. I did not want it to function like this because someone can click quickly through modes and unintentionally lockout the light. Granted though, I made the multi click operations pretty quick, so it's harder to get it occur unintentionally, but it can happen.
Ok, another bug
fyi: Don't have a Q8 with me, but I'm using a Manker U11 modded with NarsilM v1.0, so exactly the same as the Q8, or should be?
Thanks for acknowledge Lazy-R-us.
But I wrote in the cheat sheet for MODES you can only lock out if the lamp is off, with 2 clicks and a click&hold.
I noted that a year ago, so maybe Tom changed it.
Tom answered above
