Thanks for the nice review. What is your overall conclusion about this light? (I have it, but with biscotti-driver, and I find it flawless, everything is done right)
In the S2+ the retaining ring in the tail is reverse threaded, counter clockwise to unscrew.
It is a matter of taste, Simon made the change at some point and many find a metal switch-cap more classy, but personally I like silicon covers better because they feel better and allow building a lighted tail.
I thought all the sand coloured ones came with the new firmware, and 12 mode groups. This is getting confusing, because you can still order a “new edition” C8 which has the old firmware as well.
Convoy really need to sort their models out. There are so many versions now of similar products that it can be impossible to be sure you are ordering what you want, or whether there is a newer version available.
If you buy this light from Simon itself, you get the biscotti firmware.
Maybe FT is selling old stock
I personally do not like the metal switch that much because it’s so much smaller than a standard silicone cap.
I would love it if the switch would be 2 or 4mm bigger and the ring around it illuminated
I ordered this light from simon 5 weeks ago and didn’t receive it yet
Thanks for your kinds words.
Well I do believe that the light is one of the best in the sub-$20 category.
Everything on it is excellent. I especially like the thick, matte textured anodization that most convoys come with.
My only complain would be with the metal switch, that even though it looks super cool and is great once you get used to, requires a bit of a learning curve”.
As for the retaining ring, I already knew about the reverse threads but it seems that in order to get it apart I will have to apply equal amount of force on both sides (e.g use fine needle nose pliers).
An illuminated metal switch from the factory would be dope.
Someone has already posted a thread about implementing an illuminated tailcap.
Regarding the shipping times, mine took around 2.5 weeks to arrive in Greece, yet it took another 3.5 weeks for our national post to process the package…!
Yeap, unscrewing the switch retaining ring will be hard applying for to one side only, it will work only after the initial torque is done on both sides
As for the flashlight, of everything that comes with the new models (smooth reflector, metal button, xp-l hi, ARC glass, driver) I end up preferring to change most but glass and the driver. I switched my clear S2+ with a 219C and OP reflector, and ordered with a rubber tail cap (I believe only the clear one has both metal and rubber variants). These changes make it a best for me, but I understand how throw, output, tint and CRI will weight differently from person to person
Well I am more into throw and output so the XP-L HI is the way to go
I even think about stacking another 4 x 7135 chips and go for a 4.2A output.
Probably I will hold back my thoughts as anything over 3A is way overkill for an EDC.
S2+ and S3 with RMMs DIY FET-Driver and Triple-LEDs here
Takes around 45 seconds to get uncomfortably warm in the head area…
I would love more Convoys like the S8 with at least a bit of a heatsink…
It does heat up, but I find it takes a few minutes longer to get too hot to touch on turbo than what most concerns I’ve read here seem to believe. And this is with the nichia on the x8 driver, the xp-l should take longer even to become burning hot. The triple with FET, of course, is another story entirely
I forgot to add another change I’ve made, which is to change the GTD o-ring for a black one, in order to reduce a slight tint shift to green which is uncharacteristic of the nichia and took me a while to figure out :person_facepalming:
The reason it took so long is because the OP reflector on my other S2+ did not have this effect as visible, but the SMO reflector on the clear one made it noticeable
Out of curiosity, what LEDs are you running on your triple setup?
Heatsinks or not, the compact form factor of the light will always stop it from handling high currents.
Don’t make the mistake I made. Just get a set of “ring-pullers”. I got a set from Tekton (via Amazon) for a decent price, and was kicking myself I didn’t just go and do that long ago.
4 pliers in a set, all combinations of straight/curved, squeeze-to-open/squeeze-to-close.
No more screwing around with needlenose pliers, tweezers, screwdrivers, etc. Ever.
It is very confusing. When I’m recommending the S2+ light to others I almost have to write a thesis on reseller, chips, UI, colour, emitter/reflector, tint. The XP-L HI models should have used a different model name.
I think FT, BG, and GB all requested the 3/5 mode UI in their order.
Indeed. It’s bad enough to have to explain the difference between S2 and S2+, let alone the myriad other models. At least the C8 is the good old C8, no closely-named similar models within Convoy itself.
Personally speaking, good reason not to purchase Convoys off of them and always go straight to Simon.
I’m actually recommending the 3/5 mode version to other lighting photographers as it has a better strobe (10Hz). Whilst the variable strobe in the latest revision of Biscotti is great for giving someone a migraine, it sucks for light painting.
Good point, although light painting is (sadly) such a niche usage, I’d expect the painter/photographer to request the 3/5 firmware anyway.
Then again, Biscotti, while versatile, is so open-ended in its configuration, the regular joe might get intimidated by the mode select flowchart alone. “Click when it blinks” seems far less ‘scary’ to them, I’ll bet.
