Imalent DX80 32000 lumen monster
They dropped it out of market if it is in the same price bracket,as the X70.
Yes I have a 16K lumen active cooled light in my head
It will thus not do 25-40K but if it can be done the 16K will be there for so much longer then any other hand held LED light can do 16K it makes up for that
16000 good lumens is all we can ask for :wink:
Active cooling is the ticket:
Lots of high CRI light that lasts a little longer than a few seconds (preferably indefinite).
My DX80 is waiting for me at the post office! Ahh! It came via express so quicker than I expected. You can expect me to report back with a lot of details and Beam shots comparing to the acebeam x45. Stand by.
Looking forward to those beam shots mate
Initial impressions… WOW!
I judge very critically and am very pleasantly surprised. The only thing that the build quality is ever so slightly let down by is the switch. It feels like a cheap Chinese clicky switch but nonetheless it works well. I’m very pleased to find an electronic lock out and also a very effective mechanical lockout with less than an eighth of a turn. The build quality overall and the anodisation, the LED centring is absolute top-notch. No complaints.
Reports of the first batch had it that the flashlight mode spacings were very inaccurate and much higher than claimed. I’m pleased to say that upon comparing with my flashlight collection and proven outputs, the modes are very accurate to the claimed spacings. Low mode is definitely around 120 Lumen, if not Less.
Another thing I was worried about is a blue or really green tinted emitters. Again, I am pleased to say that the output is approximately 5500k with no noticeable tint shift towards green or blue. Apon initial impressions, I am very happy with the tint.
A strange thing is the breather vents all around the head and Shining another flashlight from the opposite side you can see the CPU style heatsink fins. It seems like this flashlight desperately needs a fan. I am also a little suspicious how this can be waterproof when it is open like that. Time will tell.
The battery cartridge is a sealed solid unit. I believe I could unscrew the end plate and access it if I wanted to.
I like the design and it is well balanced and easy to hold. The machining on the head allows it to lay on the table and not roll. Little details like this I appreciate.
I will say that possibly the most disappointing aspect of this flashlight will be the throw figures. From initial impression and from Beam shots, it looks like this flashlight will be around 100kcd. I will prove this later on. Still plenty good enough for me but a Far Cry short of the claims specifications. The reflectors are very reflective and about 20 mm deep.
I will charge now and look forward to more testing. Initial impressions are very positive.
I look forward to the rest of your testing and what you will share about your findings. Hopefully mine shows up soon
Here is a Beamshot sneak peak DX80 on right, acebeam x45 on left.
Dx80 head weight
X45 head weight
Side by side
That head is :smiling_imp: , ha ha but body mass is almost double then Acebeam !!!
Well that didn’t last long. :frowning: same thing happened to mine as the flashlight on the taschenlampen forum. I’d say a full secondary recall is on the cards.
Burned circuit board
Smoke in head
Banggood !!! As I mentioned earlier they haven’t even replace first stock just checked numbers with Imalent and decided that they are ok……
I believe mine was definitely the second batch. I didn’t see any issues in regards to the mode spacings or LEDs partially lit. Everything seemed fine.
Damn what a BUMMER! :person_facepalming:
Looked to be a nice looking light too!
Why then other vendors don’t sell them yet, and how did they get them in the middle of national holiday?
I believe the second batch were available before the Chinese holiday and mine was sent express. There are a few other members on the German forums that have received their second batch. One of them has done the exact same thing as mine.
Wow that sucks. How long did you have it running before that happened?
I thought the beam was already too wide on the X45. Lucky this light isn’t for me.
It wasn’t on for any time at all. The flashlight wasn’t hot. The way it happened was I mechanically locked out the light while it was turned on in medium or high mode, then screwed back the battery tube after a second to reset the mode memory and there was a quick flash and pop then smoke. It seems like if the battery is disconnected while it is turned on, the relay doesn’t disengage and when the battery is reconnected it shorts out. I think this is a problem that could be solved by the electronics Engineers. Maybe a capacitor or something like that.
Ya, I too hoped it can reach further to 150kcd.
That sucks. Hope Imalent sort it out for you.
