I believe the second batch were available before the Chinese holiday and mine was sent express. There are a few other members on the German forums that have received their second batch. One of them has done the exact same thing as mine.
Wow that sucks. How long did you have it running before that happened?
I thought the beam was already too wide on the X45. Lucky this light isn’t for me.
It wasn’t on for any time at all. The flashlight wasn’t hot. The way it happened was I mechanically locked out the light while it was turned on in medium or high mode, then screwed back the battery tube after a second to reset the mode memory and there was a quick flash and pop then smoke. It seems like if the battery is disconnected while it is turned on, the relay doesn’t disengage and when the battery is reconnected it shorts out. I think this is a problem that could be solved by the electronics Engineers. Maybe a capacitor or something like that.
Imalent DX80 V2 Thermography Although I took a video, it was not recorded on the SDcard due to an operation mistake :confounded:
The illuminance drops at about 60℃ and hot display appears on the display.Maintain below 62℃.
At other times when it was 58℃ or more when re-lighting, the illuminance immediately decreases.
It looks like there is not FAN.
There is no hole for air cooling.
The battery is fixed and can not be removed.If this twist it might be possible but I will not try it (damaged scary) :confounded:
Anyone that is game enough to test, try switching the flashlight on medium, high and turbo and disconnect the battery tube while turned on and quickly reconnect it within one one second. This is what caused my fault. It quickly flashes and a pop and smoke. This is a short circuit and the battery must not be reconnected.
The reason why I was trying this was to reset the mode memory, but the flashlight should have been off before disconnected obviously. Nonetheless, this should not cause a fault. I hope they fix this as it is the 2nd know case in an few days.
