I believe the second batch were available before the Chinese holiday and mine was sent express. There are a few other members on the German forums that have received their second batch. One of them has done the exact same thing as mine.
Wow that sucks. How long did you have it running before that happened?
I thought the beam was already too wide on the X45. Lucky this light isn’t for me.
It wasn’t on for any time at all. The flashlight wasn’t hot. The way it happened was I mechanically locked out the light while it was turned on in medium or high mode, then screwed back the battery tube after a second to reset the mode memory and there was a quick flash and pop then smoke. It seems like if the battery is disconnected while it is turned on, the relay doesn’t disengage and when the battery is reconnected it shorts out. I think this is a problem that could be solved by the electronics Engineers. Maybe a capacitor or something like that.
Imalent DX80 V2 Thermography Although I took a video, it was not recorded on the SDcard due to an operation mistake :confounded:
The illuminance drops at about 60℃ and hot display appears on the display.Maintain below 62℃.
At other times when it was 58℃ or more when re-lighting, the illuminance immediately decreases.
It looks like there is not FAN.
There is no hole for air cooling.
The battery is fixed and can not be removed.If this twist it might be possible but I will not try it (damaged scary) :confounded:
Anyone that is game enough to test, try switching the flashlight on medium, high and turbo and disconnect the battery tube while turned on and quickly reconnect it within one one second. This is what caused my fault. It quickly flashes and a pop and smoke. This is a short circuit and the battery must not be reconnected.
The reason why I was trying this was to reset the mode memory, but the flashlight should have been off before disconnected obviously. Nonetheless, this should not cause a fault. I hope they fix this as it is the 2nd know case in an few days.
I tried hard look on heatsink, but I could not see it well.This need tools to watch.
In Thermography this hole part was the highest temperature, so there would be a heat sink inside.
Sigh,Charging is impossible :confounded:
Imalent think that the probability of hitting a problem is high.It is the third after DT70, HR20.
Because I bought two DX80, another one will arrive shortly.Until then DX80 is unusable.
Large light since OLIGHT SR90.Large light is also good
Cool more arriving!
Can somebody use a piece of aluminium foil to close those little holes and see if that causes it to heat up a lot faster?
I still think it doesn’t but would love to be corrected for then ths expensive to make and design part would actually make sense except from advertising point of view (I really think they planned on a fan, it didn’t make enough of a difference because the holes are just too small and opted for making the CPU style heatsink a little bigger so it looks good trying to sell it.)
