The 219Bs are very inefficient and have a low maximum lumens output. The current 219Cs are not available with R9080, only R9050. Also they don't offer an XP-L2 sized LED. That is why this LG is so interesting.
There is also the question of what we actually need. A R9 value of >=50 is already very good. It makes all the diffference in the world compared to LEDs of the past.
I know sample size = 1, but I have a high CRI XP-G3 and find it very ugly. Yes the CRI is there, you can tell it if you look for it, but I’m so distracted by how green it is that I have to really try to see the nice color rendering.
It seems to vary. I have 4000K 90CRI XP-L2’s that are as green as you describe, while the 80CRI variant of the same led has a great tint. The 3000K 90CRI XM-L2 leds that KD sells again have a wonderful tint.
I have some 80 CRI 3000k XP-L2 which aren’t too bad, lots of pink in the tint. But the 80 CRI 3000k XP-G3 looks fairly green. I’m sure there are good new generation Cree chips out there, but it seems a bit of a lottery right now.
The only amazing Cree I’ve seen so far is the 4800K XM-L2 EasyWhite (quad die) in the ZL H600Fd Mk3. Even if it is CRI 84 R9 19. The frosted lens makes wonders.
This is going off-topic, but I recommend shaving or de-doming the first generation high-cri XHP-50 and XHP-70s. It noticeably reduces the yellow corona and spot. The tint becomes much more even.
Unfortunately, triples are too floody for me, so the E2L is off the menu.
Any chance of getting this LED into an M2?
That would probably be a unique light in the marketplace, because 5000K and 90 CRI in a cost-effective AA light are very hard to find. Zanflare might be thinking about one, but they’ve gone quiet lately, and the only other option I can think of would be a much more expensive Eagletac.
maukka, do you have any measurements for the new LG leds in the Jaxman E2L? still deciding whether to get the warm white nichias or the neutral LGs in the Jaxman e2l but i wouldn’t decide until the numbers are out from maukka :nerd_face: .
Almost sure they are far away from modern cree and nichias.
This is typical feature of LG and Samsung leds - they are very competitive at 350mA test current, but with current raise they look not so good. I suppose the reason is internal thermal resistance.
Thermal resistances:
LG H35F0: 2.5°C/W
Cree XP-L: 2.2°C/W
Cree XP-L2: 2.2°C/W
Cree XP-G3: 3°C/W
Nichia 219C: 4.2°C/W
Cree XM-L2: 2.5°C/W (but with much bigger footprint)
So they are all very similar in that regard. The XP-L2 tolerates a much higher maximum current though because of the flipchip design.
Brightness @ 3A (LG doesn’t state the temperature, I assume 25°C):
LG H35F0 4000K: 882lm
Cree XP-L2 U6 4000K: 1000lm
Nichia 219C D240 4000K: 800lm
Cree XP-G3 R3 4000K: 910lm
So the XP-L2 is indeed noticeably more efficient (13% more lumens, basically two Cree Bins). Even the XP-G3 is brighter.
The LG LED still has some benefits though:
- cheaper and easier to get compared to the XP-L2 90CRI (Mouser is very expensive for low quantities)
larger Die size compared to Nichia 219C and XP-G3 => more useful Beam in some lights
