Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
I finally have something that resembles tracking….
2017-10-09 00:00:00
Status:已到港
2017-10-08 18:01:00
Status:Depart from Origin airport
2017-10-07 01:07:17
Status:
2017-10-06 16:37:08
Status:已扫描
2017-09-30 17:02:23
Status:Item dispatched. PKG#:PKG04302130
2017-09-28 13:35:36
Status:Item in transit
2017-09-28 12:35:36
Status:Item received
Yay for progress!
Yes, because it serves no technical function that a solidly lit light can’t. It just does it in a more complicated way for the pure reason of looking pretty.
Now if the pulsation speed increased or decreased with battery voltage, then it would be functional, but it doesn’t, it always stays the same speed.
Don’t get me wrong, I think it’s neat and cool. There’s nothing wrong with that, but you have to admit that’s it’s not a functional thing, it’s strictly cosmetic.
Sometimes the relentless questions and suggestions can not feel right. Specially when asked in several threads or repeated again and again.
There is a phase for things and if a station has passed it is not all that good if people keep coming back on things.
A good way to start is give some breathing space, ask once and just wait. Ask in the right place, not in several places, it feels very pushy if the same thing gets posted about here (station passed) in the GT or FW3A topic while there is a Narsil topic where one can ask it once and well in case of work people do there is simply only acceptance if the answer is not what you wanted when asking.
I would even go so far to say “if an answer to a question could not be acceptable, maybe just don’t ask it in the first place”
What LRU says but then said harsh, don’t like it, do it how you feel it must be done, stop or not even start bugging in such cases.
I know what I am talking about here, it was one of the reasons to start these BLF specials myself in the way I thought would be good.
Am I missing something here? Q8 with current version of Narsil already have it, switch light on as default, can set to make it off (I did it to mine), have option to change setting for locator led, battery level indicator led and indicator led.
Advanced Configuration UI Operation
Activated from Battery Check mode by doing a press&hold for at least 1.2 seconds. The light blinks twice quickly, and once slowly. 3 settings summarized below, and operates the same as the main configuration UI.
1. Locator LED feature 1=disable, 2=enable
2. Battery level Indicator LED Only 1=disable, 2=enable
3. Indicator LED Enable 1=disable, 2=enable
May be better to make it off as default, less people will notice and make noise about it.
Mine arrived an hour ago. Tracking # I received the Friday before the Holiday was worthless on any tracking site. It arrived with a bowed out box inside a bag, but the foam and bubble protected it fine.
After the going thru the checklist, dropped in the waiting 30Q’s, and fired it up with a double tap. My coworker thought aliens were beaming her up, with all that light bouncing off our white walls. :sunglasses:
The unit came in clean, free of grit and well lubed. Ran it thru ramping and switch light on and off, and all functions as it should. Compared it to my L6 w/CW, and it seems I’m going to have to get used to the NW. All my other lights and vehicles are outfitted with cooler 5500K+ LEDs.
Thank you to all the developers and programmers for your efforts, and for the delivery of final product that piqued my interest enough to join here.
My first light arrived promptly but additional 3 lights from revised version are in limbo. The following is from FEDEX Tracking. Go figure … :disguised_face:
Label created
Shipment information sent to FedEx
Anticipated ship date:
Sat 9/30/2017
ROWLAND HEIGHTS, CA US
Scheduled delivery:
Pending
ORANGE, CA US
Shipping label has been created. The status will be updated when shipment begins to travel.
Quickly and easily customize your home deliveries.
Request to get your home deliveries when and where you want them with FedEx Delivery Manager®.
Customize Delivery Request Notifications Obtain Proof of Delivery
More actions
Travel History Hide Help
Date/Time
Activity Location
9/30/2017 - Saturday
5:54 am Shipment information sent to FedEx
Select time zone
Shipment Facts Hide
Tracking number 9261299991206461838906
Reference YT1727321549007223
Dimensions 6x4x2 in.
Terms Shipper
Service FedEx SmartPost
Weight 1.1 lbs / 0.5 kgs
Total pieces 1
Packaging Package
Reminds me of a Thomas Disch novel
Wow. That’s about all I can say. My first Q8 arrived last night (not original batch AFAICT), and I can find nothing to complain about. Awesome light. Kudos to the entire team. If I could only own one flashlight (ah! the horror!) the Q8 would be it.
I don’t normally like lighted switches and parasitic drain. But the Q8 does it right.
My experience with Bistro and Biscotti had me drifting towards preferring simpler UIs. But, again, Narsil is just right. I intend to use it as a moonlight/turbo 2-mode light, but I can ramp if I really want to. It doesn’t get much simpler than that.
Wow. And, again, kudos. Thanks for all your hard work. This light is an unbelievable deal. I hope the ano can survive the constant fondling and drooling it seems to demand.
Iam not trying to play down what members did to make this light work, but you can’t tell me the paper work that was sent with the light is easy to understand. You take one look at it and think holy blank this isn’t easy to understand. (quote=Lazy-R-us]
OK, Good you are already most of the way there. I was confused by the blink pattern as well - Tom set it up so that there are 2 blinks to focus attention, then a number of blinks to show what setting you are configuring. What helps me is to think or say “Con-Fig” or “Men-Ue” when those first two blinks happen. Then you count off to the appropriate setting.
So- click on, eight second click and hold.
“Con-Fig” 1 - ramping mode (click once to disable, click twice to enable)
“Con-Fig” 2 - set moonlight level (click between one and seven times to set your fav moonlight level)
“Con-Fig” 3 - set stepdown (click once to disable, twice for temp, three times for timed)
  • If you select temp stepdown, the LED’s turn on to max and the light starts to heat up, let it warm up to your level of comfort, then click.
  • If you select timed stepdown, click once for 60 seconds, twice for 90 sec, three times for two mins, four times for three mins, five clicks for five mins, six clicks for seven mins.
“Con-Fig” 4 - blinky mode (click once to disable, twice for one strobe, three times for all strobes)
Light will blink four times to indicate config session is done and turn off.
At any point in the config session, click and hold will exit the session (blinking four times to let you know).
The best and worst part of a community collaborative project is that if you think something should be done differently - you have the power to do so. No fair claiming that “Someone” should make it better. Dig in - learn to use it, document it in a way that makes sense to you, then post it. If it works better for enough people, it will get adopted as the new standard.
[/quote]
I’ll have one Q8 from the second batch here at Friday , i changed the springs board with one from TA in my first Q8 , so i have still the untouched board to compare springs etc , if anyone is interested .
Btw , banggood’s priority mail worked well , 2/10 shipped and has schedulded delivery for 13/10 . Pretty good for 1.7$ :slight_smile:
Well mine was shipped 28 Sept and according to tracking the latest update is Leaving The Shenzhen Operations Center. 2017-10-01 00:44
2 weeks to go nowhere according to that.
I give up on ordering from China after this one.
There is no option to make the light stay on all the time.
The problem with off as default is you can’t tell when power is connected or if it’s mechanically locked out. It can also be hard to find in the dark. Hard to find the button as well.
Yep, that’s the one, Dale. Works like a charm.
Bought it, filled in about 5 things I have on order, the 1st Q8 is listed as en-route and it even shows a pin-on-a-map for the last known location. I had to look up the FedEx numbers to get it tracking as the YT number seemed to be giving it problems. Pretty cool feature set, I’ll get notifications without having to look them up online so that’s neat too. Thanks for pointing it out. :wink:
My second batch Q8 is waiting … and waiting … and waiting … in Hongkong.
Paid priority shipping! :frowning:
Anzahl: xxxxxxxxx
Paketstatus: Im transit
Zielland: Deutschland
Herkunftsland: China
2017-09-30 12:00 Arrived In Hongkong, Waiting To Fly Away.
2017-09-29 21:30 Leaving The Shenzhen Operations Center.
2017-09-29 14:07 Shenzhen Operations Center Processing Package Information.
2017-09-29 09:36 Flyt Express’s sorting centre, Guangzhou, Item dispatched. PKG#:xxxxxxxx
2017-09-28 13:42 Flyt Express’s sorting centre, Guangzhou, Item in transit
2017-09-28 12:42 Flyt Express’s sorting centre, Guangzhou, Item received
Powered by www.17track.net
:weary:
So I expected my two lights tomorrow…
I couldn’t hold back so I checked the tracking…
AND THEY BOTH ARRIVED TODAY!!! :slight_smile: 8) :+1:
But why am I stuck in a meeting for the next hour???
:person_facepalming: :rage: :weary:
Just got mine out of the mailbox and first inspection it looks perfect.
Yeah Dale, the map feature is nice. The kids and I have been watching my Q8 drift across the country from California to Georgia for over a week on the map. It had a weird layover in Arizona for a few days and it’s been a mile from my house for three tortuous days lol.
Hallelujah! It turns a rookie carrier didn’t know to put the package box key into my mailbox… :person_facepalming: So my two lights and batteries were locked up all long weekend… Both lights are clean, no damage to anything, and all screws match and are not stripped or anything. Unit 1 works well. I think I drove my wife a little crazy - ramp up, ramp down, ramp up, ramp down, etc. :smiley: Charging batteries for unit 2. I’m sure it will be fine. Great work crew!! What a deal for $40!
Q8
My Q8 arrived today, very nice light. Everything well lubed, all screws look perfect, and the holes in the driver are bigger now, the screws fit through. The button LEDs are equally bright. :+1:
Somehow there was a little solder blob in the head, I just removed it. And the brass ring has some residue on it.
Now I have to wait for my VTC6 cells and mod the light.
