By shining a light in the vent holes in the side, you can see many fins, revealing the CPU heatsink shown in the YouTube video advertisement.
Anyone that is game enough to test, try switching the flashlight on medium, high and turbo and disconnect the battery tube while turned on and quickly reconnect it within one one second. This is what caused my fault. It quickly flashes and a pop and smoke. This is a short circuit and the battery must not be reconnected.
The reason why I was trying this was to reset the mode memory, but the flashlight should have been off before disconnected obviously. Nonetheless, this should not cause a fault. I hope they fix this as it is the 2nd know case in an few days.
Since your DX80 smoked in this way, unless that person stay next to Imalent factory or office, he must be crazy to try that.
I tried hard look on heatsink, but I could not see it well.This need tools to watch.
In Thermography this hole part was the highest temperature, so there would be a heat sink inside.
Sigh,Charging is impossible :confounded:
Imalent think that the probability of hitting a problem is high.It is the third after DT70, HR20.
Because I bought two DX80, another one will arrive shortly.Until then DX80 is unusable.
Large light since OLIGHT SR90.Large light is also good
I’ve got today the Post office notice announcing that my DX80 has arrived.I collect it tomorrow.
I hope it is not a lemon. :question:
Cool more arriving!
Can somebody use a piece of aluminium foil to close those little holes and see if that causes it to heat up a lot faster?
I still think it doesn’t but would love to be corrected for then ths expensive to make and design part would actually make sense except from advertising point of view (I really think they planned on a fan, it didn’t make enough of a difference because the holes are just too small and opted for making the CPU style heatsink a little bigger so it looks good trying to sell it.)
I think they never intended for a fan. It would require a complete redesign. A longer head combined with an intake and exhaust area. There are no signs of that here.
I’m sure they could have made the holes bigger if they wanted to.
It looks to me they only intended to create more surface for better cooling.
Maybe they just don’t know enough about how to design with fans?
(Unless they are rather big, fans will probably not make much of an impact when it’s about this much heat. (Apart from a lot of noise, if they are small, that is.))
Mine should come today also.
USA
GearBest is now promoting this light, 30 pieces with USA plug for $219.95 with code “DX80”
I wonder if they are just clearing out stock and giving up or they just got this batch in and are kicking off a sale campaign.
Cool more arriving!
After arrival of the second DX80,I compare Thermography :+1:
nice! thanks
Mine came in yesterday and I got to play with it a little last night. No problems with it so far. Hopefully it stays that way.
Congrats.Imalent is Lottery
Ya, those cheap adapter can’t last long.
Maybe has to use laptop charger as replacement.
In my case, the AC adapter seems to be bad.Damaged just by using it once :rage:
The good news though is that it is outrageously bright, the reason I ordered mine.
Nothing boring about this light.
First thing I will do when I get mine is measure the open circuit voltage of the charger and the voltage under load.
Then I will use those numbers to use an external variable current limiting power supply to see how many amps this light draws when charging. Those numbers will be useful if my charger blows like the guy in the video.
Maybe the best way to charge it is with an external power supply
I have a Dell XPS L702X laptop,which has a charger at 19.5V/2.5A.(The original from Imalent, writes 19V/2000mA).Is this good for the light?
I think so. But you better measure DX80 charger adapter voltage to have confirm voltage number. I don’t trust those number very much although mostly they are accurate.
I cut many lousily small adapter connector head and connect them to bigger adapter with similar voltage. Of course after they stop working.
I guess Imalent knows they are selling the connector head as back up for the lousy adapter.
I have had the same issue with the charger adapter the symbol of the flashlight did not light up. Sent few messages on Monday to BG they runaround me & I received their message yesterday that the adapter is in back order!. I’m considering to file a case to paypal. I totally lost confident with Imalent since my order was placed end of July.
