Haven’t you used the light before disassembling? Did it work then?
You took the light apart and reassembled it with a bezel from a different light and manufacturer. I won’t be surprised if this bezel - due to different construction - is not able to press the MCPCB against the shell. You mentioned you couldn’t screw down the bezel completely because of a thick o-ring. But this might also be caused by different or too short threads.
XPG3 loves heat i have XPG3 doing almost 9amps and they get really toasty. This would be why they un-soldered them selves the stock board can not handle the current. The stock board may not be making proper contact with the light its self if its not fully flat on the bottom.
Just to inform XP-L hi version or C8T have DTP copper PCB 16mm with nicely spread silver thermal grease underneath,and two screws for fixing in place. Tint is also amazing around 5700K maybe V3 2B I would say, much better than U6 3A .
XP-G3s are just……special. As are the XHP50.2s based on them. It seems like around 25% of them are just “weak” while the rest work great aside from the tint shift. At least that has been my experience.
I’ve had probably 6 XP-G3s fail, and 2 XHP50.2s. All of them the same failure mode, they work fine for a little while, then they go blue all of a sudden and cut out. Sometimes a reflow fixes them for a bit, but they have always failed again shortly after.
I’ve even caught a few as they went blue, shut the light down and powered it up and they worked again for a bit, but again, they always fail shortly after, so I don’t trust them.
All of my experiences are with emitters I have reflowed myself on DTP boards, and all showed good reflow upon replacing them. None of them were driven all that hard either, I’d say under 4A, usually under 3A.
After they fail they will usually still light extremely dimly if given voltage, and sometimes will kick back on if pressed on, so I suspect something going on with the internal bonding to either the thermal pads or the annode/cathode.
I want to like the XP-G3, but between the tint shift and the fact that they are the only emitters I have ever had fail without serious abuse, I’m probably going to mostly avoid them in favor of 219C.
Are those problems you speak of common to all of the newer generation Cree emitters, Jensen567? If so, failures with XP-L2s and XHP70.2s should also be common, I think.
Let's tell Cree we love bond wires and clear domes. :-D
The dome is clear, just looks yellow from the top. No, seems to be isolated to the XP-G3 size die, I haven’t had a single XP-L2 or XHP70.2 fail like that.
I used it only for about 5 minutes, it was day and no point in using it longer.
And I used call that can’t give more than 3,5A because I had that near me.
Later i put HG2 inside and it died.
Bezel has even longer threads than original because I can screw it down completely with original o-ring. I used thicker one because I wanted even more pressure on MCPCB.
Yeah, I’m not entirely sure what is causing it, but it seems to be fairly common with the XP-G3 and XHP50.2.
The fact that I have seen the exact same behavior from both of those leads me to believe there is some sort of manufacturing flaw with this die that has gone unnoticed by quality control at Cree.
Since they sometimes recover with pressure, my first guess would be something to do with bonding the flip-chip die to the external package.
Thankfully it seems isolated to only those 2 models, as the XP-L2s and XHP70.2s I have used are all going strong, even with some serious abuse in a few of them.
I own heaps of XPG3s never had this issue. I think i own 10 XPG3 emitters they all still work fine even after being driven really hard. What boards are your XPG3s on?
Various, but all DTP and mostly noctigons. I have probably more than 30 of these emitters I have used in various builds for myself and others, in that process I have had 6 failures. I have had 3 XHP50.2s fail out of probably 12 or so I have used. That is a relatively small sample size, but they are at least from various batches. I have also seen quite a few posts from other users here with issues using these emitters.
The ones that do work can take a beating, but some just die even with a relatively light loading. These are purely my experiences, so YMMV.
My C8T is a killer, 80.000cd just after switching to AR lens. I will post a review,just couldn’t find time lately.
Unbelievably this light have same size hotspot from 5 meters like UT02 which have much bigger reflector. :+1:
Jarl! I am also to post a C8T review pretty soon, with a freshly loaded 30Q cell I've been able to measure just above 6A at the tailcap with a custom built shunt.
Candela figures… don't really know what to say. I've measured up to 102.4Kcd but of course my smartphone's luxmeter may not be very accurate.
Stepdown time is ≈3:25 in my early sample, measured up to 52.8°C at the head fins just after stepdown.
Medium mode, handled via a low power MOSFET, should be PWM free but I haven't tried to check it out, may someone suggest some tool like an Android app? Can be from any source.
I just sent a mail to visosystems and said that they should fix their flicker tester app for android.
Maybe it helps, you could always borrow someone’s iPhone and download the app to check the flicker.
Edit: Got an automatic mail back saying he’s not in office until Dec 3:d so better find someone who have a iPhone you could borrow…
