Imalent DX80 32000 lumen monster
nice! thanks
Mine came in yesterday and I got to play with it a little last night. No problems with it so far. Hopefully it stays that way.
Congrats.Imalent is Lottery :smiley:
This guy has problem with charger…
[video:]Imalent DX80 (Pro's and Con's) - YouTube
Ya, those cheap adapter can’t last long.
Maybe has to use laptop charger as replacement.
In my case, the AC adapter seems to be bad.Damaged just by using it once :rage:
The good news though is that it is outrageously bright, the reason I ordered mine.
Nothing boring about this light.
First thing I will do when I get mine is measure the open circuit voltage of the charger and the voltage under load.
Then I will use those numbers to use an external variable current limiting power supply to see how many amps this light draws when charging. Those numbers will be useful if my charger blows like the guy in the video.
Maybe the best way to charge it is with an external power supply
I have a Dell XPS L702X laptop,which has a charger at 19.5V/2.5A.(The original from Imalent, writes 19V/2000mA).Is this good for the light?
I think so. But you better measure DX80 charger adapter voltage to have confirm voltage number. I don’t trust those number very much although mostly they are accurate.
I cut many lousily small adapter connector head and connect them to bigger adapter with similar voltage. Of course after they stop working.
I guess Imalent knows they are selling the connector head as back up for the lousy adapter.
I have had the same issue with the charger adapter the symbol of the flashlight did not light up. Sent few messages on Monday to BG they runaround me & I received their message yesterday that the adapter is in back order!. I’m considering to file a case to paypal. I totally lost confident with Imalent since my order was placed end of July.
^ Adapter is in back order? You’ll just receive another one that goes poof after 15 minutes. Imalent need to at least source a different charger which will take extra time I’d say. Well at least the light didn’t go poof.
Ow, like I told few weeks……
THIS LIGHT IS VERY EXPENSIVE!
I think if ultrafire was the manufacturer of this light it certainly have more reliability and costs less
I first thought it was funny… Then I realised you’re probably right, haha! :confounded:
I think the light is fine, it breaks shear output record of stock light.
Charging adapter might not be tested thoroughly enough.
Well, I have seen many good brand charging adapter failed for example HP. Just that they failed after a few years, not one time use.
I am also a BG, but was it a reply that BG would not correct it?
First they asked me a ridiculous question, whether the adapter was DC 19v & then no reply! I sent them another message if I don’t receive the answer I may file a case to paypal. They replied almost instantly & gave me an order # but it’s in back order & I don’t know how long do I have to wait. I totally sent them 4 messages plus 2 emails! Bad customer services.
I’m it as DC Power Supply it is possible to see the current value,This not smoke out it? :smiley:
The accessory of DX80 was 18V2A.
19V?? Is this an accessory?
Imalent barely know how to make flashlights, so I’m sure active cooling is even harder for them. Even top name flashlight companies have trouble with it.
About the fan size, even a tiny fan can make a huge impact. Just think of laptop fans.
I marked it spam
