Imalent DX80 32000 lumen monster
707 posts / 0 new
The Miller
The Miller's picture
nice! thanks
Caseit741
Last seen: 6 days 7 hours ago
Mine came in yesterday and I got to play with it a little last night. No problems with it so far. Hopefully it stays that way.
silicoon
silicoon's picture
Congrats.Imalent is Lottery Big Smile
hIKARInoob
hIKARInoob's picture
Last seen: 20 min 52 sec ago
This guy has problem with charger…
DENGOH
DENGOH's picture
Ya, those cheap adapter can’t last long.
Maybe has to use laptop charger as replacement.
cool i'll see you when you get there
silicoon
silicoon's picture
In my case, the AC adapter seems to be bad.Damaged just by using it once Angry
dchomak
Last seen: 3 years 3 months ago
The good news though is that it is outrageously bright, the reason I ordered mine.
Nothing boring about this light.
First thing I will do when I get mine is measure the open circuit voltage of the charger and the voltage under load.
Then I will use those numbers to use an external variable current limiting power supply to see how many amps this light draws when charging. Those numbers will be useful if my charger blows like the guy in the video.
Maybe the best way to charge it is with an external power supply
Theodore41
Last seen: 3 weeks 5 days ago
I have a Dell XPS L702X laptop,which has a charger at 19.5V/2.5A.(The original from Imalent, writes 19V/2000mA).Is this good for the light?
DENGOH
DENGOH's picture
I think so. But you better measure DX80 charger adapter voltage to have confirm voltage number. I don’t trust those number very much although mostly they are accurate.
I cut many lousily small adapter connector head and connect them to bigger adapter with similar voltage. Of course after they stop working.
I guess Imalent knows they are selling the connector head as back up for the lousy adapter.
my9221
Last seen: 12 hours 55 min ago
I have had the same issue with the charger adapter the symbol of the flashlight did not light up. Sent few messages on Monday to BG they runaround me & I received their message yesterday that the adapter is in back order!. I’m considering to file a case to paypal. I totally lost confident with Imalent since my order was placed end of July.
hIKARInoob
^^^ Adapter is in back order? You’ll just receive another one that goes poof after 15 minutes. Imalent need to at least source a different charger which will take extra time I’d say. Well at least the light didn’t go poof.
Franz
Last seen: 1 month 4 weeks ago
Ow, like I told few weeks……
THIS LIGHT IS VERY EXPENSIVE!
I think if ultrafire was the manufacturer of this light it certainly have more reliability and costs less
hIKARInoob
I first thought it was funny… Then I realised you’re probably right, haha! Sick
DENGOH
DENGOH's picture
I think the light is fine, it breaks shear output record of stock light.
Charging adapter might not be tested thoroughly enough.
Well, I have seen many good brand charging adapter failed for example HP. Just that they failed after a few years, not one time use.
silicoon
silicoon's picture
I am also a BG, but was it a reply that BG would not correct it?
my9221
First they asked me a ridiculous question, whether the adapter was DC 19v & then no reply! I sent them another message if I don’t receive the answer I may file a case to paypal. They replied almost instantly & gave me an order # but it’s in back order & I don’t know how long do I have to wait. I totally sent them 4 messages plus 2 emails! Bad customer services.
silicoon
silicoon's picture
I’m it as DC Power Supply it is possible to see the current value,This not smoke out it? Big Smile
silicoon
silicoon's picture
The accessory of DX80 was 18V2A.
19V?? Is this an accessory?
JasonWW
JasonWW's picture
Last seen: 1 day 12 hours ago
RollerBoySE wrote:
JasonWW wrote:
The Miller wrote:
I still think it doesn’t but would love to be corrected for then ths expensive to make and design part would actually make sense except from advertising point of view (I really think they planned on a fan, it didn’t make enough of a difference because the holes are just too small and opted for making the CPU style heatsink a little bigger so it looks good trying to sell it.)
I think they never intended for a fan. It would require a complete redesign. A longer head combined with an intake and exhaust area. There are no signs of that here.
I’m sure they could have made the holes bigger if they wanted to.
It looks to me they only intended to create more surface for better cooling.
Maybe they just don’t know enough about how to design with fans?
(Unless they are rather big, fans will probably not make much of an impact when it’s about this much heat. (Apart from a lot of noise, if they are small, that is.))
Imalent barely know how to make flashlights, so I’m sure active cooling is even harder for them. Even top name flashlight companies have trouble with it.
About the fan size, even a tiny fan can make a huge impact. Just think of laptop fans.
atbglenn
atbglenn's picture
Last seen: 2 years 3 months ago
JasonWW wrote:
Cosmoing wrote:
An ultraviolet flashlight is a type of flashlight that emits light within the ultraviolet spectrum. It is used in a wide variety of applications, such as identifying forged documents and looking for leaks in refrigerators. The flashlight usually resembles a standard flashlight, and consists of a light emitting diode (LED) and a handle. They can come in various forms, such as small, hand-sized designs or large, lantern-type models.
Huh, is this spam?
I marked it spam
Boycott Nike
RollerBoySE
RollerBoySE's picture
Last seen: 1 week 3 days ago
True, but then they tend to be noisy.
Better with a big fan at less rpm (if possible).
Flash-O-Maniac
My AC/DC Adapter also failed after 2 hours during first charge attempt on DX80. I checked with DMM, dead just like the one in the previous post with pic. I contacted Banggood and they replied that I should send pic of packing slip, make video of problem and post to YouTube and send them link, and take other pics which will help them. I answered that is not going to happen. I already sent them 3 pics of the adapter and invoice slip that was included inside shipment showing exact item ID # and all the information they really should need to know I purchased this item and what I paid for it. I requested that they contact Imalent and have them send me a new replacement AC/DC Adapter for the DX80. In the meantime I am using a laptop charger that is also rated for 19V, the same as the Imalent defective charger was. The Imalent charger was rated for 2 amps, the laptop charger is rated 3.42 amps, should be no problem using higher amp charger, the light will only draw what it needs, and it needs at least 2 amps. Any 19V charger with at least 2 amp rating and a 5.5mm X 2.5mm charging plug will work.
But the charger I am temporarily using is for a Toshiba laptop. It has a big brick in the middle with charging cable coming out one side and power cable out the other. Too bulky. So I searched and found a “wall wart” style 19V style charger that is about the same size as the one that came with the light. It is a charger used to charge an Asus laptop. Also has 5.5mm X 2.5mm charging plug. Readily available at your usual online sources.
The light works fine so far and is pretty impressive. Charger on mine is the weak link and a relatively inexpensive item to replace. That is the challenge for Banggood. How much time and energy is a person going to put into getting just the AC/DC Adapter replaced. I think they are counting on most people giving up and not be willing jump through the long list of hoops they require you to jump through.
But I might be wrong. They might surprise me (and a few others) and take my word for the adapter being broken/defective and somehow send a replacement. Funny thing is I’m not interested in a $5 refund that I expect they will offer. I have money, I don’t have a working compact charger for my newly purchased Imalent DX80.
Itsme
atbglenn wrote:
JasonWW wrote:
Huh, is this spam?
I marked it spam
Maybe it was supposed to be in this thread
http://budgetlightforum.com/node/54372
silicoon
silicoon's picture
After confirming well, it was 19V2A Sad For that reason, I could not find it much.
I decided to buy this.
Thank you.I was very saved Thumbs Up
Flash-O-Maniac
This should also work if you would prefer a smaller more compact adapter:
https://www.amazon.com/gp/product/B01IR1LY30/ref=od_aui_detailpages00?ie...
Theodore41
My Dell laptop charger,writes 19.5V/2.5A.Is it good for the job?
Flash-O-Maniac
Others might be better able to answer that question. I did research and discovered that Amp rating above the minimum that you need is no problem because the device only draws what it needs, the rest is left as unused potential, and the same is true for Watt rating. A higher Watt rating than the adapter you are replacing should not cause a problem for the same reason. But the Voltage should be the same unless the device (in this case DX80) has a range of acceptable input voltage and that different voltage falls within that range. I have no clue if the Imalent DX80 is set up to accept a range of charging voltage other than 19V.
My electronics knowledge is limited. Hopefully others might be better able to answer your question, and feel free to correct any bad advice I have given.
NikolaS
NikolaS's picture
Voltage should be the same but since its 16,8V battery pack standard 19,5V laptop charger will be fine, and for Amperage bigger the better. Also its much better to find used original charger than those crappy replacement from BG, they will last as much as they cost Sick
Theodore41
I’ve got it just now.It seems OK, the charger is OK also.But it is now day hear,so I will play with it in the evening.I hope it will be OK after the try.
If I can open the charger,I try to make several holes through the plastic,for better cooling.
NikolaS
NikolaS's picture
Are all dead chargers for US 110V plug-in, or we have some 220V also?
