True, but then they tend to be noisy.
Better with a big fan at less rpm (if possible).
My AC/DC Adapter also failed after 2 hours during first charge attempt on DX80. I checked with DMM, dead just like the one in the previous post with pic. I contacted Banggood and they replied that I should send pic of packing slip, make video of problem and post to YouTube and send them link, and take other pics which will help them. I answered that is not going to happen. I already sent them 3 pics of the adapter and invoice slip that was included inside shipment showing exact item ID # and all the information they really should need to know I purchased this item and what I paid for it. I requested that they contact Imalent and have them send me a new replacement AC/DC Adapter for the DX80. In the meantime I am using a laptop charger that is also rated for 19V, the same as the Imalent defective charger was. The Imalent charger was rated for 2 amps, the laptop charger is rated 3.42 amps, should be no problem using higher amp charger, the light will only draw what it needs, and it needs at least 2 amps. Any 19V charger with at least 2 amp rating and a 5.5mm X 2.5mm charging plug will work.
But the charger I am temporarily using is for a Toshiba laptop. It has a big brick in the middle with charging cable coming out one side and power cable out the other. Too bulky. So I searched and found a “wall wart” style 19V style charger that is about the same size as the one that came with the light. It is a charger used to charge an Asus laptop. Also has 5.5mm X 2.5mm charging plug. Readily available at your usual online sources.
The light works fine so far and is pretty impressive. Charger on mine is the weak link and a relatively inexpensive item to replace. That is the challenge for Banggood. How much time and energy is a person going to put into getting just the AC/DC Adapter replaced. I think they are counting on most people giving up and not be willing jump through the long list of hoops they require you to jump through.
But I might be wrong. They might surprise me (and a few others) and take my word for the adapter being broken/defective and somehow send a replacement. Funny thing is I’m not interested in a $5 refund that I expect they will offer. I have money, I don’t have a working compact charger for my newly purchased Imalent DX80.
Maybe it was supposed to be in this thread
I want to buy a 18650 UV flashlight that best fits the role of checking US Currency Authenticity. Jaxman, Convoy and Nitecore are some I have briefly looked at online. After my posting this I will look into UV options further. Those with hands-on experience/suggestions are who I am hoping to hear from. Added I want the best "out of the box" factory UV light that serves the intended purpose, over long term. *NailBender lights are not a consideration*
After confirming well, it was 19V2A
For that reason, I could not find it much.
I decided to buy this.
Thank you.I was very saved :+1:
This should also work if you would prefer a smaller more compact adapter:
https://www.amazon.com/gp/product/B01IR1LY30/ref=od_aui_detailpages00?ie=UTF8&psc=1
My Dell laptop charger,writes 19.5V/2.5A.Is it good for the job?
Others might be better able to answer that question. I did research and discovered that Amp rating above the minimum that you need is no problem because the device only draws what it needs, the rest is left as unused potential, and the same is true for Watt rating. A higher Watt rating than the adapter you are replacing should not cause a problem for the same reason. But the Voltage should be the same unless the device (in this case DX80) has a range of acceptable input voltage and that different voltage falls within that range. I have no clue if the Imalent DX80 is set up to accept a range of charging voltage other than 19V.
My electronics knowledge is limited. Hopefully others might be better able to answer your question, and feel free to correct any bad advice I have given.
Voltage should be the same but since its 16,8V battery pack standard 19,5V laptop charger will be fine, and for Amperage bigger the better. Also its much better to find used original charger than those crappy replacement from BG, they will last as much as they cost :confounded:
I’ve got it just now.It seems OK, the charger is OK also.But it is now day hear,so I will play with it in the evening.I hope it will be OK after the try.
If I can open the charger,I try to make several holes through the plastic,for better cooling.
Are all dead chargers for US 110V plug-in, or we have some 220V also?
Amazon.com
Thank you :+1: Because it sells to Japan, I will consider it.
I think that the chargers are capable for either 110V or 230V.We in Europe, have received a EU adaptor,so as,putting it on the US tips, it can adapt to European outlets.
In my case, the AC adapter seems to be bad.Damaged just by using it once :rage:
Is it possible to open it,so as to drill holes through plastic?It could have better cooling I think, putting a small fan by it.
What is the tip size of this charger adapter? They are not universal I think!
Τhe outer diameter is 5,38mm.
The tip size for the laptop adapter that I used and the charging plug fit perfectly was Outside Diameter = 5.5mm and Inside Diameter = 2.5mm. I assume this is the tip size needed for the DX80.
I got mine today and the first thing I did was checkout the power supply adapter.
Open circuit voltage is 19.5V.
I have a whole box of power supplies, I save every one I come across, ’cause you never know what might come in handy.
Other than the supplies to laptops that I have, the only one that was compatible plug wise and voltage wise was this Fujitsu.
19V at 4.22A would make a nice replacement. I probably scrounged it at the recycle bin at Best Buy. No doubt if anyone were to
try, they could find another that would work.
This is the only extra I had and I am reluctant to cut the cord. I need a cord to measure how many amps a DX80 will pull when charging. I would like to know if the power supply they ship is being over worked, or it is just of poor quality.
If I can find a second compatible supply at Best Buy, I will cut its cord and do the test.
Either overworked or of poor quality,it becomes hot when it is working.
I have had the light charging now for about 2 1/2 hours and the supply is not even warm
The indicator lights are blinking some sort of code but I can’t decipher the meaning.
Portapow has a handy meter for dc inline measurements. Comes with USB and DC (5.5x2.1mm) plug adapters.
