It’s like that isn’t it George? This has been an interesting shipping experience, all the lights I have and it’s never happened like this before. Oh, sure, I’ve had one go to Dallas, about 2 hours North of me, and then go to Florida and come back, but that was a zip code mishap. This is a whole new thing, all the hand-offs…
Yeah, using HKJ’s info as a guide, 15% capacity at 3.4V is pretty optimistic. 3.4V is anywhere between 0% and 13%, for the batteries he measured… that’s at 1A. Even less capacity at higher amps. So effectively unable to provide max power on the Q8.
1. Is this a compatible charger for these high drain 30Qs?
(I already own a Liitokala but my buddy has the Nitecore charger and needs to know if he needs a new charger for his new 30Q batteries)
2. What mm bit do I need to fit into the threaded tripod hole on the side of the Q8? And with the newer/corrected version of the Q8 will I still need to hack off part of the bit in order to make it fit into the hole?
3.4V is at about the 2.1 Ah mark, so 2.1 Ah out of 2.86 Ah capacity is about 73.4%, so 26.6% capacity remaining. This is directly off a Samsung 30Q flat top test, so not sure if this is all apples to apples, but this is how I've thought it could be calculated.
Those measurements are under load, wheras the 3.4v in question wasn’t measured inside the running Q8, it was the state of charge of the cells as per the poster, so likely measured after taking them out.
Ahh, ok. Anyway in HKJ's reviews to find out the "not under load" levels? These things will vary from cell to cell it seems like. I've seen discharge curves vary nearing the end.
I think it is awesome, had to do work the other day
blink blink blink lower
I ramped it up a little and had light more then enough to see for the duration of the work at least half an hour
It is so good to be able to put lumens out at steady rate sometimes, I hate lights that keep on blinking and detest my Olights that just go off and won’t turn on.
