First off, I wanted to say thanks for all the work involved, and I think this is a good light for the price. The main features of the driver’s customizability, ramping plus instant modes to full power are great. I’d say the biggest negative is the bright switch light which has to be covered at night, its not necessary to actually turn the light on, just uncover it to guide you around the dark house at night when you wake…
Now speaking of the switch… This thread is so huge, and I’m not sure if this has been an ongoing issue, but I am having problems with 2 of the lights I gifted. The switch apparently sunk into the light and is now almost not pressable…has anyone had this problem and/or are there solutions? You CAN press the switch by pressing harder and at an angle now, which is unreliable and makes press and hold function non workable, it seems it has just sunken into the light, I hope to get to opening it soon in hopes of looking at the assembly. Mine has not yet sunk inwards, but it makes me worried about pressing and holding it… The problem is these are gifts and I’m not the best with disassembly and repair…is it worth it to try if there is an easy solution or just write Banggood about the faulty lights?
Ok, I just saw what you mean. In round 2 production, they seemed to have made the LED wires shorter, but I found the switch wires seem longer so, if you have to untwist the LED wires a little. The wires are very stiff, so might take some tinkering, but I can get full access to the driver, just that it can't come out as far as it used to.
Literally the 10 or so round #1 Q8's I worked all had the same length wires, so figure this was a round 2 change.
Mine wasn’t that bad but this is how another package of mine traveled… It sat in Compton for 1-1/2 weeks before going to Georgia… I could have drove and picked it up in 1 day! It’s amazing how crazy shipping is. How do these companies stay in business with these kinds of inefficiencies!?
Well I dont currently have access to it, but I did see one of them and the cover does not appear to have moved at all. It seems the actual switch/actuator underneath the cover has partially fallen away from the external surface so that its not pressable through the cover directly, but at an angle, so now its only pressible with firmer pressure deeper inside the switch hole at an angle…the cover seems to be in place relatively normally still.
I should have access to look first hand at it soon. How do I best take the cover off to look at it when I can?
I finally figured out that my 30 digit tracking number is a DHL eCommerce number, and tracking now indicates that my Q8 was “processed” this morning at the DHL eCommerce distribution facility in Compton, California. Others with a 30 digit tracking number may want to see if they can track their Q8 with DHL.
2017-10-18 18:58 LAX-US, Arrive to destination airport
2017-10-13 04:27 UNITED STATES, EN ROUTE TO DHL ECOMMERCE DISTRIBUTION CENTER
2017-10-13 04:06 UNITED STATES, ELECTRONIC NOTIFICATION RECEIVED: YOUR ORDER HAS BEEN PROCESSED AND TRACKING WILL BE UPDATED SOON
2017-10-09 00:00 HK, 已到港
2017-10-08 18:01 Depart from Origin airport
2017-10-07 01:07 广州处理中心
2017-10-06 16:37 广州处理中心, 已扫描
2017-09-30 17:02 Flyt Express’s sorting centre, Item dispatched. PKG#:PKG04302338
2017-09-28 13:48 Flyt Express’s sorting centre, Item in transit
2017-09-28 12:48 Flyt Express’s sorting centre, Item received
The one you linked I use a lot and is about as good as it gets, I’ve looked everywhere for something better and I can’t find it, so I’d suggest what you have there.
I also just got my Q8’s today and all I can say is WOW, what a beautiful light.
I could not find one flaw, not even a spec of dust in the reflector, not a sharp spot on the light anywhere, even has some thread lube on it, just beautiful and extremely nice machine work.
Thank you to all involved in making this happen, this light is just over the top.
I could not be anymore happy at all,
Thank You again Q8 Team you are tops …!!
