Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Hm
It would really be smart to take a look under the switch cover, there is a new cover with full lenght stuff in the box.
It seems you are the second with a cover sliding off issue, the first was a simple swap with the one provided
Mine wasn’t that bad but this is how another package of mine traveled… It sat in Compton for 1-1/2 weeks before going to Georgia… I could have drove and picked it up in 1 day! It’s amazing how crazy shipping is. How do these companies stay in business with these kinds of inefficiencies!?
mine finally got on the move from la today after sitting for 2 weeks
supposed to be here next Wednesday
Well I dont currently have access to it, but I did see one of them and the cover does not appear to have moved at all. It seems the actual switch/actuator underneath the cover has partially fallen away from the external surface so that its not pressable through the cover directly, but at an angle, so now its only pressible with firmer pressure deeper inside the switch hole at an angle…the cover seems to be in place relatively normally still.
I should have access to look first hand at it soon. How do I best take the cover off to look at it when I can?
Today I also received my Q8. It´s a great light. Thanks to the team. I realised the lighting was quite weak in my room :smiley:
Thank you… I appreciate that info. I am gonna nab some of those… :wink:
doganygood to hear
B42 remove the ring around the switch to get access there
I finally figured out that my 30 digit tracking number is a DHL eCommerce number, and tracking now indicates that my Q8 was “processed” this morning at the DHL eCommerce distribution facility in Compton, California. Others with a 30 digit tracking number may want to see if they can track their Q8 with DHL.
2017-10-18 18:58 LAX-US, Arrive to destination airport
2017-10-13 04:27 UNITED STATES, EN ROUTE TO DHL ECOMMERCE DISTRIBUTION CENTER
2017-10-13 04:06 UNITED STATES, ELECTRONIC NOTIFICATION RECEIVED: YOUR ORDER HAS BEEN PROCESSED AND TRACKING WILL BE UPDATED SOON
2017-10-09 00:00 HK, 已到港
2017-10-08 18:01 Depart from Origin airport
2017-10-07 01:07 广州处理中心
2017-10-06 16:37 广州处理中心, 已扫描
2017-09-30 17:02 Flyt Express’s sorting centre, Item dispatched. PKG#:PKG04302338
2017-09-28 13:48 Flyt Express’s sorting centre, Item in transit
2017-09-28 12:48 Flyt Express’s sorting centre, Item received
Finally , on the move…….
Thanks Ag76. My info is the same as yours, processed in Compton, CA this morning. To be delivered by USPS.
Could someone recommend a tripod lanyard screw for this? Can't seem to find a nice one.
https://www.aliexpress.com/item/In-stock-New-1-4-Screw-For-DSLR-SLR-Camera-Strap-Tripod-Quick-Release-Plate-Mount/32659359889.html
The one you linked I use a lot and is about as good as it gets, I’ve looked everywhere for something better and I can’t find it, so I’d suggest what you have there.
I also just got my Q8’s today and all I can say is WOW, what a beautiful light.
I could not find one flaw, not even a spec of dust in the reflector, not a sharp spot on the light anywhere, even has some thread lube on it, just beautiful and extremely nice machine work.
Thank you to all involved in making this happen, this light is just over the top.
I could not be anymore happy at all,
Thank You again Q8 Team you are tops …!!
Just got an email from Liion Wholesale has button top 30Q’s in stock today
for Akovia:
Go to the top of the page
Choose “Search within thread”
enter the words “tripod socket” (without quotation marks)
That will give you a variety of possibilities several people have mentioned
So my Q8 seems great. No scratches, not dirt, led's fairly well aligned (not quite dead perfect, but ok). The screws are nice quality with the possible exception of the LED board center screw that still doesn't look bad. The indicator LED's are not quite even (mabe 2x different), but they work, and it's not an issue to me. My battery tube initially located just short of perfect alignment, and after a little use it's already gone past perfect alignment, so that just proves it's not a reasonable thing to expect and isn't possible to deliver, at least not without a completely redesigned closure mechanism. It definitely has the bump-on bump off feature. Handy for slamming it down on the table to turn it off. Not dependable for biking, but it's not uncommon from what I can tell.
Otherwise, it works great. I do have bistro-HD running on it (not the posted version, it doesn't work). The light does seem to have switch bouncing (mostly simple fix), so I'm guessing my bench setups don't because of either the big OTSM cap they have (even when I'm not testing them for OTSM) and/or maybe the lack of R1/R2 impacts C1 stability, not sure, but it bounces, and the bouncing finds every little race in the code real fast. There's still some rare lockup so maybe it find that soon or maybe I won't.
Nice light, well done.
> tripod socket
Someone up there
EDIT: that was Nil, at Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light - #13392 by Nil
recommended this one. I agree it looks better than the other choices.
https://www.aliexpress.com/item/Photography-studio-accessories-1-4-D-ring-camera-dslr-screw-adapter-for-strap-quick-release-plate/32721974733.html
Removing the switch cover
You can scratch the black ring, try to wrap one layer of tape arround the needle noses of the pliers
Just preformed the requested test. Deactivation of the switch LED has no affect on the constant glowing of the main LED’s.
I will now disassemble for inspection of the SMD components on the driver. I’ll be sure to get some close up photos for documentation and analysis.
