I’d take a careful look around R3, in case there is a dodgy joint or the resistor itself is faulty , though it seems to look OK.
This 100K resistor is there to drain the FET gate voltage to ground when the gate is not being actively driven by the MCU.
If it has become disconnected, this might explain the very slight current flowing through the LEDs when the MCU is asleep, depending on how MCU pin 6 is left during sleep.
E.g. if MCU pin is left floating tri-state (and R3 has become disconnected), only the tiniest leakage current would be enough to charge the FET gate just sufficiently to turn it on very slightly.
Check resistance measured at the FET gate pin to ground.
Should be no more than 100K (depending on whether much meter current flows through MCU pin as well). Try with meter probes both ways round, in case in one direction MCU pin protection circuit conducts. Generally black probe on ground should be OK.
Maybe afterwards try re-touching R3 solder joints anyway, if you feel up to it.
Well, that’s my hypothesis, for now, with a lot of “ifs”
Otherwise maybe a leaky 7135, but you would have to disconnect it to diagnose that.
I got a few of these in. They are pretty nice, heavy so seem well made, and don't need to be sanded/grinded down to fit. The ring though will flop around, so using a heavier, thickr lanyard would work well with them.
I bought one of these for my MT-01 and I like the smaller size compared with some others I bought recently. It sits reasonably high off of the light but the thick rubber washer works well to take up the slack when you screw it in. I’m going to buy two more for my Q8 collection for sure.
Ok, this would explain the huge difference in price. But in “Item specifics” the Aliexpress seller says “Material: Aluminium”.
Perhaps the title (which says “steel”) refers to the keyring only …
I’ve been out of the game for awhile. Mine arrived this week and still in the box for now. I located my flashlight stuff today to see what I had.
I have a XTAR SP2 charger and no batteries.
Is this charger OK besides only having 2 bays? Else maybe I will go ahead and get the LiitoKala Lii-500 (assume thats the same as the LI500 you note)
I’ve been searching this thread regarding battery options. Is there a protected option?
I am in the US, and I’d prefer Amazon if at all possible for Prime / Prime now! Any links or more recommendations appreciated. I guess I can patiently wait for my batteries.
Use the “Search Within Thread” button at the top of the page.
> FastenR-Tripod
$_24.95_?!
You can find what appears to be that same product for less than $2 at aliexpress, and there are stronger-looking alternatives
Look in this thread with the search feature
Sorry to bring up on old post, but I'd like to add some more facts to this. You referenced a worse case example that's not applicable to the Samsung 30Q. Here's the 30Q compared to the AW 2600 at a low draw of 0.2A, so little voltage sag:
Using this chart, the 30Q still has 20% of capacity remaining at 3.4V at a low draw. The AW, well, has a really bad drop off - not very common.
That page from HKJ is apparently very old, using cells that maybe were popular 4-5 years ago, and they have different discharge characteristics. Same with the Pana B - it has a steep drop off at the end.
I buy pretty much all of my batteries from Mountain Electronics. Very hard to beat his pricing especially since he is located in America and the shipping is quick. Richard is a long time blf member and stands by his sales. Also your not going to get fake or counterfit products from his website. Now as far as batteries go I personally buy only Samsung 30qs for all my 18650 flashlights. They are always at or near the top of the performance curve regardless of what flashlight you need them for. They are typically budget friendly and have a nice high 3amp hour reserve of power.
Well I gave my son a Q8 for his birthday, loaded with Panasonic 3400 protected
Dang bright
(lucky him, his flat parts of the tube and head align perfect)
The SP2 is a good charger, but the 2 bays is very limiting. You’d have to do 2 sessions of 4 hour(?) charges for the Q8. If you dont mind the wait of monitoring them the whole time it’s charging, then it’s probably fine for a Q8.
The Lii500 will do all 4 at once, so it cuts your charging time in half. This is definitely a better charger if you get a GT where you have 8 cells.
You could do 2 charging sessions at 1A on the SP2 for the Q8, then at the same time, 2 charging sessions on the Lii500 at 1A for the GT.
It’s just time dependant. How much do you like waiting?
I’ve got 3 chargers so that I can charge all my work light cells in one small 3 hour (or less) window once a week. I hate waiting.
People have reported that the Q8 works well with protected cells. They cost a lot more, though. About $10 each. Richard over at Mountain Electronics carries some of the best. His 3400mah NCR18650B cells actually say they can charge at 2A. If that’s correct, then your SP2 charger will let you do that for faster charge times. (Most good 18650 cells only recommend 1A to 1.7A charging rates). It’s output is also good for at least 7 amps. Well above what the Q8 needs when you use 4 cells.
