Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Yeah. That looks pretty good. The last time I googled DC fix I got all kinds of colored films and such and no decent places to buy it from.
Sureeeee…… Now it works exactly as expected. My timing on the single clicks might have been too slow. The bike mode is nifty :slight_smile:
I think the stuff in my beamshots is the ‘sand’ variant. A listing on Amazon seems to call it ‘milky/sand’ and d-c-fix’s site calls it just ‘milky.’
Have you tried the ‘Scotch tape method?’
Here is the manufacturer’s page with their diffuse self-adhesive variants.
Another trick, go backwards in strope:
Strobe Modes:
The normal way (RAMPING: 2x, 2x, Y clicks [Y= 1…4] ) is time sensitive because of the lock in modes. And I got PMs people are not quick enough for the Y clicks, because the Y have to be done right after the second double click.
If navigation is hard, try:
RAMPING from off/on: Double click, double click, 4 clicks in a row. Now you are in the 5th strobe = 10 sec beacon.
MODES from off/on: Longhold (over 1,2sec), 4 clicks in a row. Now you are in the 5th strobe
Now you can go back via click&hold. You can go back 4 times, then comes OFF.
If you go backwards you have time to do this.
I’m glad you got it sorted. :+1:
Moin moin
I got two Q8 yesterday and work so far both perfectly.
Thanks to all those who have made this project possible.
greeting
Jens
To remove bezel, place on tyre inner tube(free from tyre repair shops).
Hold head, press down hard and turn anticlockwise.
Here are a few detailed pics of my near perfect Q8. I've found nothing to complain about with the workmanship or performance. Comparing this by eye to the performance of a few other lights with similar specs, my sample somewhat exceeds the factory specs given, without any modifications. I'm using Sony VTC6. I plan to bypass the springs.
I disabled the strobe and all functions of the indicator light. I do miss the double-click from turbo to get back to the previous setting, like the D4.
Thanks again to Miller and the team for the best bang for the buck I'll ever get in a flashlight!
MAD777, that first pic makes me hungry! It’s early here, finishing up a cup of joe, and that looks like 4 over easy eggs…. my Q8 is hung up in Houston so I can’t even make toast! :stuck_out_tongue:
Nice shots, looking forward to seeing this light…
Number 1 is hung up in Houston, still, number 3 is now in ElPaso, TX and number two is still sitting in LA. I recently ordered a couple of things from Banggood that have caught up to number 3 light, in ElPaso, even though the shipping seemed much different. I guess they’re playing with my number 2 in LA… hope they leave the cells in it when they’re done. :stuck_out_tongue:
I'm adding this as a feature improvement: if strobes are disabled, 2X click from a 2X click invoked turbo will restore last level.
Oh, I never thought about it before, will try it but have little problem here, could you please inform me store that selling clip for it?
How about a triple Q8 threat with one of these:
You wouldn’t have to worry about trees in your way, on turbo, it’ll simply turn them to ashes.
I guess you already know that after double click to turbo you can click to OFF and the next click brings up your old brightness level?
Right now I don’t know if Toykeeper has a RampinglOS version for the Q8.
I wrote RampingIOS, so definitely will work on a Q8. Both support FET+1 fine.
I figured that out eventually, but the sudden darkness of being off for a second is a bit annoying.
That is great to hear. It will add a nice refinement to things. I don’t even use strobes, I just learned them for the videos. :wink:
My two Q8 arrived yesterday. It's all perfect and I'm happy. Wonderful lamps with great UI.
Once again, I would like to thank all the organizational and technical Employe.
Best regards, Hardware
I got one on Friday and one on Saturday. Both are 2nd batch. Boxes were a bit bent up, having been mailed in a unpadded bag.
Lights were in good order.
As for imperfections, they were insignificant but identical between the two lights.
  • Faint machining marks on bezel, as reported earlier by others. Not noticeable or a problem.
  • Slightly gritty thread action. Fully fixed by wiping down and re-lubing.
  • Dry O-rings. Fixed with Nyogel.
  • One super tiny nick inside of battery tube on head end. Result of construction process, no actual problem.
  • One super tiny dot of HA missing on tail. Nitpicking; no real problem.
Emitter centering on both was great. I gave both lights a run on Turbo/Max down to almost dead batteries. I let one of the two sit for 48 hours on standby. No switch Green LED problems.
I did have a heart-dropping moment when I tested one on Maxinitially and got something like 3100 lumens. Then I realized I grabbed the set of 30Qs at 3.4V instead of the fully-charged set of 30Qs I intended. Using fully charged batteries, both tested north of 5100 lumens at 30s on both lights.
Very pleased. Great value. Thanks to those who made it happen! It seems being in 2nd batch was a stroke of luck for me as both lights are without any real flaws.
I’m hoping to post a mini review with x-ray of internals tonight (Aussie time).
I just realized my second one didn’t have a bag with the extra O-rings and switch cover. Hopefully my third one will have that.
Wow just found out mine is in USPS in Stamford CT only 1 state away and it was not suppose to get here until the 22 so fingers crossed it does not go on a cross country trip to visit some watering holes. I still don’t even have my new batteries yet I have some I can try it with but not great ones.I will update when its in my hands. PS was just going to drive the 3hours and break in the Postal Facility tonight but I think I am still wanted in CT for a 145mph ticket I had years ago so I decided against it. LOL
