hav put a 075 resistor on top of the shunt and now pulling 5 amps , heaps better and was Very easy to do
Now i just want to go a bit cooler than NW , Can U guys recommend a better xhp 35 maybe around 6000 tint ?
These are really nice de-domed if your up to the challenge?
http://www.kaidomain.com/p/S026063.Cree-XHP35-HD-E2-1A-White-6500K-LED-Emitter
You could give them a close Shave and make your own HI too! :+1:
5amps is too much for XHP35?
im yet to mod mine and im very tempting.
do you have any issues after the mod?
UT02 uses a boost driver , 10fp says 5amps draw from the battery :+1:
thanks George.
I want to mod mine right now
do you have a photo where to replace the resistor? just incase i stuff up
found it
I love the UT02 as a host. The (old school) XP-G2 de-domed was one of my favorites!
Pulling over 6amps and throwing over 300kcd it was a laser beam jacket pocket rocket thrower!
But for a Bombastic Boomer I use the XHP70.2 UT02 the most. With the Lexel built T/A Narsil driver, copper driver adapter’s, I then bored the head out for a 32mm Maxtoch board, used a Convoy L6 white switch boot and wired off the driver, with resistors, lighted up the stock e-switch, blue or red, but I liked the red only, for DANGER!
The 70.2 P2 1A at 8+ amps is quite impressive out of this smaller light, nice over all beam with a large Hot spot with this smooth reflector.
Oooo… I like the clear switch boot. Ima havta git me one of them! Did you get the boot from the convoy store? How is the beam looking?
Ask Simon for them, the L6 tail cap white/clear boot.
I like the P2-1A the best so far, less of a brown/yellow corona, ring, then say the B-C’ I have tried. The beam is white, not cold blue-ish, like the P2-1C as is the ample spill. The beam is naturally big, coming out of a short reflector, but it lights up the neighbor across the street back yard/driveway like daylight so it has decent trow for a small reflector. It would make for a nice patrol light, even say half way up the ramp it is more than enough light, but then double click for Turbo, yeah there’s no where to hide!
I’m looking at getting a couple more of these UT02’s if I can find them for the $28-$30 price I got the last 4 at? I found some interesting other 70.2’s at Mouser I want to try out. They describe them as a white/white 5700k and a white/warm 5700k? They are P2 bin but 0E and 40E?
Hello, just add r100 to the driver and get about 119000 cd in nw verison with liitokalas 26650 fully charged
Where’s the best place to find these resistors? They are 0603 resistors correct?
I’d like to join the question…
Woo Hoo, i just fitted a E2 3C led to my UT02 / 5 tail amps, looks real sweeet now
dave
did u get your from cutters.com.au?
yep on a board , swapped out the led only, thought id practice on the UT02 first before i do the MF02
so they have genuine E2 3C?
few members here have question about them
u bought some, what do u reckon ? they look ok 2 me
got my order yesterday but yet to test them out.
will do lux reading this weekend. Im expecting higher lux reading than stock LED from MF02
is your UT02 NW or CW ? and hav u modded the resistor yet ? how many amps at tail ?
mine was NW and that was considerably cooler than the MF02 in NW . the MF02 seems more like 4000 so it will def get a E2 3C
pls post your before and after figures when youv checked them
cheers Dave
i have UT02 NW and CW
as well as two Astrolux MF 02 throwers
will swap them all and check the lux ready this weekend
So not modded then ?
which tint did u prefer in the UT02 ?
