If its OK I can equip them with the PSMN3R0-30YLDX FET
its the same as in the BLF Q8
and costs 0.6$ less
The 26mm Board will be a 30mm one sanded to 26mm
that will be ok ,make it 30mm as I will make the light to suit
shoot me a pm with total costing thanks…
Is it possible to get a TA Q8 driver flashed with TK’s Anduril?
If so I’d like one or two (depending on price):
(1)46mm Q8 Anduril no calibration, PO=(2B), SD=2.8V, 16AMC
(1)46mm Q8 Anduril no calibration, PO=(2B), SD=2.8V, 8AMC
Could you post or PM me the price in Euro’s and the price for shipping to Belgium in Euro’s please.
Would it be possible to get 8AMC’s seperatly if I want to add some to the 2nd driver?
it is possible to add the other firmware if you supply me the hex for it
as I am not familiar with Anduril I cant calibrate it like I am used in Narsil
OK, I’ll ask around if there is a Anduril hex file for the Q8. I’ll let you know as soon as I got it, if not I’d buy them anyway flashed with latest version of Narsil. Cheers.
It doesn’t look like there’s a HEX file for a FET+N+1 availlble for Anduril. So the latest version of NarsilM will do.
Do the siwtch LEDS blink while crossing from 1AMC to N AMC to FET?
Also, from what I understand (wich is as good as nothing) I cannot just add extra AMCs without recalibrating the driver software?
The Indicator LED blinks out after you stopped ramping which bank is active
You can add extra AMC7135s
The ramping table is a good start and gives good results on most lights,
it depends also how much the FET current is, like a single LED can draw on 17mm 2.45A from AMCs and 6A from FET
while a quad board draws 2.45A from AMCs and 12-15A from FET
for quads the ramping in FET will be proportional bigger,
the SRK sized have 5.6A AMCs to about 20A FET
but the steps in FET are the same its still smooth
ok thanks for explaining.
So I’m stil up for
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 16AMC
(1)46mm Q8 Narsil no calibration, PO=(2B), SD=2.8V, 8AMC
Just a heads up, Lexel. It looks like the 2nd generation of Astrolux MF01 have a new wiring pattern on the mcpcb (along with a new driver design). We will have to see if the TA driver can be compatible with it.
